TP.HCM Samsung I9301I Unlock / TV Ok !
Taki7610
Unlock_GSM
- Root được tiếng việt được :D
To connect GT-I9301I phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Go to dial window.
11. Enter "*#9090#" number.
12. Set "Diag config" to "USB" value.
13. Restart phone.
14. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM62
Selected model: GT-I9301I
Mode: Normal
Phone model: GT-I9301I
Firmware compiled date: Mar 31 2014
Firmware compiled time: 12:00:00
Firmware released date: Jun 19 2014
Firmware released time: 19:15:09
Phone IMEI: 352750-06-941355-1
SW version: M8626A-AAAANAZM-1.0.4050
Please, press "OK" button on the phone to allow USB debugging..
Detected phone model: GT-I9301I
Firmware compiled date: Tue Aug 12 16:25:56 KST 2014
PDA version: I9301IXXUANH1
CSC version: I9301IDBTANF2
SW version: I9301IXXUANF2
Phone IMEI: 352750069413551
Phone SN: RV1F811F3VW
Android version: 4.4.2 (KOT49H)
Cheking Root
Phone is Rooted
Reading security backup, please wait...
Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9301I-352750069413551-28-09-2014_13-40-40-.asec file
Deactivating MSL...
MSL deactivate successfully
Phone will restart now
After phone being rebooted and powered on perform the following steps:
1. Disconnect USB cable.
2. Wait for 1-2 minutes.
3. Connect phone via UART cable to the Box.
4. Note: phone screen must be active
Connecting to phone, please wait...
Found phone on COM5
Phone connected successfully
Unlocking phone. This can take some time. Please wait...
Phone is successfully unlocked
To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!)
To connect SC-01C phone you have to perform the following steps:
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When the message appears press "Yes".
5. Connect USB cable to the phone.
6. Press "Read Info" in software.
To connect SC-02C phone you have to perform the following steps:
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#7284#" number.
7. Set "USB" radio button to "PDA" value.
8. Press Home button.
9. Go to dial window.
10. Enter "*#9090#" number.
11. Set "Diag config" to "USB" value.
12. Restart phone.
13. Press "Read Info" in software.
To connect SC-02E phone you have to perform the following steps:
2. Go to Menu->Settings->Developer options.
7. Set "UART" radio button to "MODEM" value.
8. Go to "Qualcomm USB Settings".
9. Select "RNDIS+DM+MODEM".
10. Press Home button.
11. Go to dial window.
12. Enter "*#9090#" number.
13. Select "DM/UM over HS-USB".
14. Restart phone.
15. Press "Read Info" in software.
Selected port: COM53
Selected model: SC-02E
Phone was not found on the selected port!
Searching for USB diagnostic port...
Connecting to phone on COM53
Mode: Emergency
14. Restart phone.
13. Restart phone.
Phone IMEI: 352607060137557
Cheking Root
Phone is Rooted
Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9301I-352607060137557-28-09-2014_14-00-46-.asec file
Deactivating MSL...
Found phone on COM5
Writing new phone IMEI...
IMEI successfully repaired.
Please, restart the phone to apply changes
