Taki7610
Unlock_GSM
![](http://i988.photobucket.com/albums/af7/luanhongha/ScreenHunter_003_zps8a17d630.jpg)
Mã:
To connect SM-N900 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
To connect GT-I9500 phone you have to perform the following steps:
Platform: Samsung Android
Selected port: COM19
Selected model: GT-I9500
ADB server killed.
Proper android device not found. Make shure that "USB debug" option on the device is turned on.
Repairing network failed.
Selected port: COM352
Detected phone model: GT-I9500
Firmware compiled date: Wed May 28 23:23:46 KST 2014
PDA version: I9500XXUFNE7
CSC version: I9500OLBFNE2
SW version: I9500DXUFNB2
Phone IMEI: 357138053931157
Phone SN: RF1D45EJGGR
Android version: 4.4.2 (KOT49H)
Repairing network. Please wait, this can take some time...
Phone will restart now
Network is successfully repaired.
To connect GT-I9300 phone you have to perform the following steps:
2. Go to Menu->Settings->Developer options.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Connect usb cable to phone.
6. Go to dial window.
7. Enter *#9090# number.
8. Set speed to 115200.
9. Reboot phone.
10. Press "Read Info" in software.
Selected port: COM353
Selected model: GT-I9300
ADB server killed.
Phone unlocking failed
Detected phone model: GT-I9300
Firmware compiled date: Thu Jan 16 23:53:58 KST 2014
PDA version: I9300XXUGNA5
CSC version: I9300TENGNB1
SW version: I9300XXUGNA8
Phone IMEI: 353718051215861
Phone SN: RV1C6216L3Z
Android version: 4.3 (JSS15J)
Checking Root:
Phone is Rooted.
Reading security backup, please wait...
Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9300-Unknown22-06-2014_10-16-15-.asec file
Cheking security type...
New security type is detected
Executing exploit...
Exploit has been executed successfully
Unlocking phone. This can take some time. Please wait...
Phone is successfully unlocked
To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!)
