namy2k
Lâu lâu muốn chuyển qua Windows Mobile 6.5 và Windows Phone 7 mà vẫn không thể bỏ Android nên mới mày mò tìm ra bản Rom này chạy khá tốt nên giới thiệu với mọi người
Link gốc : http://forum.xda-developers.com/showthread.php?t=957652
Tác giả : AmeriCanAndroid
Rom SD chạy song song WM
OS: Cyanogen CM7 (Gingerbread 2.3.3) 100% HTC-LEO base. Not ported.
BASE: Latest updates to CyanogenMod & Gingerbread 2.3.3 compiled from git. CM7 RC2 progress @cmsrc and eventually @CM7 Changelog WIKI
Kernel: Warrenb213's AmeriCanAndroid Kernel r3.06
(do not try using a nand kernel (zImage). ie: mdj s9.0+ on an sd build, you'll fubar whatever is installed to nand. ie:wm6.5,wp7,nand android)
BOOTSDfromMAGLDR: includes optional rootfs.img that allows to boot build from magldr (!readme! in /sdcard/Android/SDMAGLDR)
SD: no NAND; yet. Currently there are several nand builds available to you. (AmeriCanAndroid will not be offered as a RAM build)
Hosts: audiogalaxy friendly ad-blocking hosts file
DATA: fully functional PPP. (switchable to RMNET - but we do not offer support- SO DONT ASK US)
RTL USERS: rtl support is now included with the build
240LCDdensity: this build is set to 180 lcd density for screen resolution. if you prefer larger icons and fonts, copy the
root folder from /sdcard/android/240buildprop/root<-here to /sdcard/android/root <-here
and reboot.
PARTITIONEDsd & NON: you do NOT have to partition your sdcard to run this build. All you need is a single fat32 partition, however extended features are available to those who sport a partitioned sd card
USER MODIFICATIONS: check post 3 for user modifications such as sense theme and round battery icons.
Cài đặt :
Kiểm tra máy đã có 2.08.HSPL chưa
Nên up những bản Rom Windows Mobile 6.5 của PDAViet đã hỗ trợ tốt cho Android
Format thẻ nhớ theo đinh dạng FAT32
Tải file đính kèm, giải nén, chép Folder \ AmeriCanAndroid \ Android -vào -> \ sdcard \ Android (thư mục gốc thẻ nhớ). Trong thư mục Android, mở file starup.txt ra, sửa "gps_zone=us" thành "gps_zone=vn"
Khởi động vào Windows Mobile, chạy clrcad.exe trước (sẽ không có biểu hiện gì xảy ra) sau đó chạy haret.exe
Mọi việc sẽ diễn ra trong khoảng 5p ( có thể lâu hơn, nên kiên nhẫn đợi ;
Lưu ý :
1/ file data.img mà bản rom này tạo ra là 1G
2/ Mặc định lcd_density của bản này là 180, các bạn có thể thay đổi lại 200 hay 240 tùy theo ý thích (dùng Root Explore)
3/ Bản này đã tích hợp SD CARD FIX FOR READING SPEED, mặc định là 2048 nên chạy khá là mượt
4/ Vào "Spare Parts" uncheck "Compatibility Mode"
5/ Để tắt tình trạng đèn LED sáng hoài, các bạn vào Market download chương trình "LED me know" về sau đó bỏ check phần Compatibility
Các phần đã hoạt động :
Wifi,3G
GPS
Browser với flash chạy tốt
Camera
Tích hợp CyanogenMod setting
USB Mass Storage
Free Ram trên dưới 280M
Vẫn đang test tiếp
Link download bản Update 2/4/2011 : (Dùng cho cả HD2 thường và HD2 T-Mobile) http://www.multiupload.com/JEOONLFEQM /
Link Mediafire : http://www.mediafire.com/?v1it4n12wxp549p
Link download bản Update 6/4/2011
http://www.multiupload.com/GKIXFMCY4S
http://www.mediafire.com/?8gm588e87er516h
04/06/11: Update
-Cập nhật cyanogenmod từ April 2 to April 6
-Cập nhật dữ liệu chỉnh sửa để Rom chạy tốt hơn
and reboot.
Cài đặt :
Lưu ý :
Wifi,3G
GPS
Camera
USB Mass Storage
Vẫn đang test tiếp
![screen1.png](https://lh3.googleusercontent.com/_8KUnnGDunKY/TV7kB-W16nI/AAAAAAAAABQ/K4A1ebRncbU/s512/screen1.png)
![screen2.png](https://lh6.googleusercontent.com/_8KUnnGDunKY/TV7kCJVrxMI/AAAAAAAAABU/ek-FJixgu2U/s512/screen2.png)
![sieuthiNHANH201104049314yzvhmtrmmd315868.jpeg](http://www.upnhanh.sieuthinhanh.com/tmpimages/images/sieuthiNHANH201104049314yzvhmtrmmd315868.jpeg)
![sieuthiNHANH201104049314otc3yzk1mz90080.jpeg](http://www.upnhanh.sieuthinhanh.com/tmpimages/images/sieuthiNHANH201104049314otc3yzk1mz90080.jpeg)
![sieuthiNHANH201104049314mzk4nza4zd91598.jpeg](http://www.upnhanh.sieuthinhanh.com/tmpimages/images/sieuthiNHANH201104049314mzk4nza4zd91598.jpeg)
