Slick - Phần mềm Chat quá quen thuộc!! [Các phiên bản] *Trang 9*
LCG Slick v0.54 S60v3/v5 SymbianOS9.x Signed (Cập nhật #4))
Phần mềm chat của LCG:
Bản mới 0.53 UPDATE 1/10/09:
Version history:
Mã:
0.20 (Sep 7 2007)Initial testing version
0.21 (Sep 11 2007)UIQ version, ...
0.22 (Sep 26 2007)Dialog tabs, file download from url, download manager, ...
 0.23 (Oct 1 2007)Yahoo audibles, UIQ buttons, separate groups for each protocol, group management: create, delete, rename, buddy management: rename, change group
0.24 (Oct 6 2007)MSN protocol
0.25 (Oct 10 2007)Saving message history
0.26 (Oct 14 2007)...
0.27 (Oct 17 2007)protocol logging
0.28 (Oct 23 2007)Option to connect automatically or manually, ...
 0.29 (Oct 26 2007)Copying text from history window, auto-reconnect option, sending nudges (Yahoo)
0.30 (Oct 27 2007)Windows Mobile version, ...
0.31 (Nov 5 2007)Buddy details, text coding option, file transfer on Yahoo
0.32 (Nov 8 2007)File transfer on ICQ and AIM
0.33 (Nov 19 2007)Improved sounds and sound configuration, online/offline notification, MSN offline messages, MSN nudges
0.34 (Nov 23 2007)MSN file transfer, fixed Yahoo crashes, improved S60 T9 writing
 0.35 (Dec 10 2007)Jabber, Google Talk protocols
 0.36 (Dec 12 2007)Jabber+GTalk protocols: SSL, compression, typing notification, fixed Yahoo login problem
 0.37 (Jan 17 2008)Small bugfixes
0.38 (Feb 21 2008)Add/delete buddy, Xmpp priority setting, improved Xmpp compatibility, fixed MSN typing icon
0.39 (Mar 3 2008)Fixed Yahoo add buddy, vibration on SonyEricsson UIQ3 phones, fixed MSN and AIM online buddy detection, fixed ICQ connection problems, fixed Yahoo file transfer
0.40 (Apr 1 2008)Send photo, alternative access point (on Symbian), color configuration  0.41 (Apr 2 2008)Fixed ICQ login, fixed UIQ3 icon
0.42 (Apr 10 2008)Fixed MSN corrupted contact lists, receive offline messages on AIM
0.43 (Jul 19 2008)Improved login in invisible mode, fixed ICQ offline message receive, fixed MSN getting contacts problem
0.44 (Nov 6 2008)Using phone theme (S60 3rd ed, UIQ3), fixed PocketPC keyboard button, fixed Symbian camera taking (menu)
 0.45 (Nov 10 2008)Fixed MSN
0.46 (Jan 30 2009)Fixed ICQ/AIM bug sending empty messages to some IM clients, compatibility with S60 touch-screen phones (N5800)
0.47 (Mar 26 2009)Small fixes, mainly updates for touch screen
0.48 (Apr 24 2009)Fixed Yahoo login
0.50 (Jun 1 2009)Small fixes
0.52 (Aug 18 2009)Small fixes
0.53 (Oct 1 2009)Fixed Yahoo protocol
Tính năng:
* Hỗ trợ các giao thức: ICQ, Yahoo, AIM, MSN, Google Talk, Jabber
* Tin nhắn văn bản
* Biểu tượng yahoo
* Alerts - âm thanh, đèn nền, rung động, thông báo cho cửa sổ hiển thị số tin nhắn mới
* Nhóm và quản lý buddy (thêm, xóa, đổi tên)
* Thông điệp lịch sử
* Gửi và nhận tập tin
* Gửi / nhận tin nhắn offline
* Tập tin tải về được gửi như các liên kết
* Các tính năng khác
DOWNLOAD:
Mã:
[URL="http://www.lonelycatgames.com/?app=slick&page=download&platform=symbian"]http://www.lonelycatgames.com/?app=slick&page=download&platform=symbian[/URL]
slick liên tục nâng cấp nhỉ.Nhưng chưa thấy có tính năng j thêm ha.:p
Bản này fix chỗ mỗi lần đăng nhập hiện "Lỗi cần nâng cấp phiên bản Yahoo ..." gì đó mà, chính lỗi này làm mất các tin nhắn Offline đấy bạn
LCG Slick v0.54 S60v3 S60v5 SymbianOS9.x (05.10.09)
LCG Slick v0.54 S60v3 S60v5 SymbianOS9.x (Cập nhật: 05.10.09)
Slick là messenger ứng dụng cho điện thoại di động. Giao thức hỗ trợ bao gồm ICQ, Yahoo, AIM, MSN, Google Talk, Jabber.
Các tính năng:
* Tin nhắn văn bản
* Emoticons
* File transfer - gửi và nhận tập tin
* Việc gửi / nhận tin nhắn offline
* Tập tin tải về được gửi như là các liên kết
Change Log
0,54 (ngày 05 tháng 10 năm 2009)
* Cố định một số lỗi & "ngắt kết nối" lỗi
ủa,cho mình hỏi cái slick này dung thì rất hay rồi fai nói là gần số 1,nhưng mình đã dùng wa nhìu fien bản và có một lỗi muôn thủa:dùng 1 thời jan rất oke nhưng sau đó toan hiên lỗi "auth...zing fail" chán wa nên lâu lắm k đung đến thang này,toan dung ola,shmessage,mumbuzz..
vậy là so hả các bro,hay tại fan mềm này k miễn fi nó thế
Chán mỗi cái này nó không hiện Contact Detail mà chỉ hiện tên nick thôi, chả nhận ra ai là ai mỗi khi dùng Slick :(
minh down về sao nó hiện The archive is either in un know or damage
Nếu file tại bài 1 thì bạn phải bỏ đuôi .7z, chỉ còn lại .zip trước khi bung né.
Nếu là file tại bài 4 thì chỉ việc dùng winrar bung nén.
Test ok hết đó bạn!
Slick 0.54 việt hóa & mod 1 số icon by .:-=™sockred™=-:.
Nếu các bạn cài vào mà bị lỗi font thì vào : Tùy Chọn \ Hỏi về \ nhấn 800 > xong
sao e cài bản này hiển thị font tiếng việt không được 100%, một số chữ còn lỗi font, tìm thì không thấy Tùy chọn/hỏi về/ nhấn 800, bác kienvp hướng dẫn kĩ hơn đựoc không?
Vào trong Config đánh dấu chọn Dùng Font hệ thống đi :)
Bản này mình mới Việt Hóa xong,nếu bị lỗi font thì vào "Cấu hình" check ô "Dùng chữ mặc định" nha,thanks all :)
Giúp mình với!!! sao mình dùng slick (kể cả bản mới nhất)vào yahoo ko đc trong khi dùng pc thì vẫn vào bình thường,dùng slick của máy thằng bạn vào nick của mình vẫn ok. các pro nào đã từng bị qua bệnh này chỉ giúp mình với xem con máy mình nó bị sao vậy.hjx thank cả nhà.:(
nó bị đứng ở chổ auto... gì đó đúng hok , nếu đúng như vậy thì nguyên nhân là do sever quá tãi , bạn nên quay lại sau . mình đã từng bị như vậy
