![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
bác nào ranh tiếng anh thi dịch mấy cái này coi có phải la cach up' gsm radio không vậy hic song' yếy quá chán
http://www.xdaflameusers.com/viewtopic.php?id=674
http://www.xdaflameusers.com/viewtopic.php?id=684
http://www.xdaflameusers.com/viewtopic.php?id=703
http://www.xdaflameusers.com/viewtopic.php?id=475
mình dốt tiếng anh quá nên chả hiểu gi hết bác nao giup' suc' với
Hi all!
Manual for recovery bricked FLAME
Symptoms: the device didn't switch on after experiments with an upgrade. Reacted only to power unit connection at the inserted battery - the orange led lights up. At this situation to bring the device back to life, only a flash bootloader (eboot.nb0) by means of interface JTAG is needed and possible.
1. Hardware preparation.
Please disassemble the FLAME and extract board. The detailed instruction
You should make a simple JTAG - cable.
Max lenght this cable is 20-25sm. My variant:
Alsoit is posible to produce some contacts, for example (see foto)
2. Software preparation.
To be required in addition:
1. Micro-SD card and cardreader.
2. Program SDFormatter, download here or here
3. FlameRecoveryTools from Medush , download
4. Diskimage.nb0 - any for FLAME. I extract it from official update
Well, now at all of us it is ready. We begin...
1. Extract FlameRecoveryTools on c:\
2. Run c:\FlameRecoveryTools\giveio_setup.exe (It driver for JTAG-cable). Please make sure that driver is installed and started.
3. Attach JTAG-cable to LPT-port your PC and FLAME board.
4. Plug power cable to FLAME board (or USB-cable from PC).
Warning! Do not press the button-indicator of the inserted accumulator!!!!
5. Open cmd-window. (Start-Run-cmd)
6. Go to c:\FlameRecoveryTools\JFlash_MM\
7. Run Start.bat
If everything is OK, a flash process will start and you should see:
If you see:
Please carefully check up correctness and reliability of all connections, a cause of error may be ONLY in it. Don't try to find missing file or any other program mistakes.
Ok, flash process is finished, verification successful, eboot.nbo has been flashed.
Unplug all, assemble your FLAME, plug AC-cable and turn on power.
Device is starting with error:
If you see message "battery is too low" - please wait for some time...and press reset again ))))
Ok.
8. Put micro-SD card in to your cardreader and run SDFormatter. Select "Full format".
9. Copy the following files to card: diskimage.nb0, eboot.nb0 (for example from my FlameRecoveryTools) end empty files-passwords rerr003a.kez and 1xdtgklo.kez.
10. Put card into device and start upgrade (press and hold soft-buttons (- and -) and press reset.
11. Finish!
Insert the accumulator into place and turn on FLAME.
Enjoy the working device!
If my article has helped you, you can donate me:
WebMoney WMID 205584530674
WebMoney USD - Z177840443105
WebMoney Euro - E685734257524
PayPal: use recipient name "medush@gmail.com" or CLICK HERE
I'm sorry for my bad English...
