Tomal v8.71] WM6.1 New Build: 21028.1.6.1
Ủa phần âm thanh của điện thoại lớn hay nhỏ là do Radio mà péc .
nếu là radio thì khỏe rùi,lúc trước mình đã thử nhiều bản Radio cuối cùng dùng bản 1.09 là thấy ổn định nhất. khi dùng bản rom 8.2 thì k co hiện tượng này, chỉ khi nâng lên 8.7 rồi 8.71 mới có hiện tượng này.
[Tomal v8.71] WM6.1 New Build: 21028.1.6.1
The Core of WM6.1 Pro - CE OS 5.2.21028 (Build 21028.1.6.1).
Features of v8.71:
-- *FingerKeyboard support
-- *HomeScreen UI for Today
-- *IE6 Mobile
-- *Adobe FlashLite 3.1
-- *WkTask 1.2.0.2 (by waku) Task manager
-- *Total Commander 2.51
-- *TodayAgenda 1.15 today plugin
-- *Adobe Reader LE 2.5
-- *File-Dialog changer (for file browser enhancement)
-- *Voice notification & ringtones
-- *Storage Manager
-- *Notepad Mobile
-- *FingerScroll support
-- **FingerMenu Enhancement
-- **Resource Proxy for dynamic caching
-- Touch sensitivity enhancement
-- Programs Icon enhancement
-- Black Theme
-- Advanced Config tool v3.3 (by Schap) with custom config
-- Memory Manager / Auto hibernate
-- Network Connection Wizard (operator settings)
-- DF's Task Manager / Registry Editor 3.1
-- SD/SDHC driver switch-over tool (thanx OllieD for coding support)
-- TCPMP 0.72 (with FLV support)
-- Camera Application (Build 25626)
-- Performance/overclocking applet (default 624 MHz)
-- DF's PIM Backup 2.8 (for contact, sms/mms etc. backup)
-- SynchroTime (by Grachov) for Internet time sync
-- PocketRAR 3.80 (with .zip/.rar association)
-- NetCF 3.5
-- Enhanced boot process management
-- MortScript (scripting support)
-- Some performance tweaks
-- 17.5 MB Flashdisk on Regular and 25MB Flashdisk on Lite build
-- 6MB PagePool for 64MB device.
-- Should work on G3/G4 both devices
*Not available in LITE build
**Not available in 64MB build
Code:
IMPORTANT NOTES:
Please do the DOC format before flashing this rom or you may suffer from unwanted issues.
Refer my signature for the wiki, where you can learn about DOC format.
Build v8.71 Regular (128MB device only):
http://vidmes.com/xda/Uni/ROMs/Tomal...ULAR_128MB.exe
Build v8.71 Regular (64MB device):
http://vidmes.com/xda/Uni/ROMs/Tomal...GULAR_64MB.exe
(Trích từ xda-developers , bài của Tomal)
Link 4shared (do mình upload) :
http://www.4shared.com/file/98050118/a3b88b0d/TML871_WM61_21028_REGULAR_64MB.html
Nhận xét sau khi xài:
1. Phần important note - format doc: chỉ thực hiện khi up có vấn đề / vì mình đã thử up lui tới khoản 8 lần rồi mà không sao cả.
2. Hiện chưa tìm được lồi nào, nhưng mình vẫn cảm thấy sau khi disable (gỡ hoàn toàn phần khởi động tự động) Wktask thì Rom càng tuyệt vời hơn
3. Bản này đã fix lỗi chập chờn (nhất là blueTooth) của bản 8.7 REGULAR trước đây
4. Nhanh, ổn định và chưa bị treo hay phải reset lại phát nào sau 2 đêm và 2 ngày xài (vọoc cài thử lui tới 8 lần cơ)
5. Không bị xung đột với bất cứ phần mềm nào mình dùng tới giờ này (kể cả games)
6. Kết nối internet (opera, diamond tv,Sbp online, internet explorer,... ) thật tuyệt. Phone, nhắn tin,... hoạt động không lổi (mình dùng thử cả Radio 1.15 hoặc 1.17)
Đây là một bản Rom chạy tốt các bạn nên thử up wa và ưng ý có thể dùng wa.
Bon weekend,
Chúc vui.
Thân.
Hình minh họa theo yêu cầu : (lưu ý hình sau khi đã cài ct)
Chào thân ái.
kèm theo pm nào vậy bạn, có thể cho mình biết không, thanks.Nếu có link down thì hoàn hảo luôn.
