Tổng hợp các điều cần biết về SHSH và Cách sử dụng TinyUmbrella - Cập nhật v7.00
Cũng ko được Bác ơi . Mình đã tắt mọi chương trình rồi . Mình dùng rất nhiều bản Tiny , kể cả bản mới nhất . hix.. hix
Hic, thế thì em chịu rồi, bác dùng tinyumbrella làm gì vậy
TinyUmbrella 5.01.00
Lưu SHSH cho FW 5.0.1 Final
TinyUmbrella NEW UPDATE !
Welcome to the 'Save SHSH' Family!
With the new iPad 3 and Apple TV 3, it's been quite busy. Add to that all the cool new information surrounding a few new iOS 5.1 jailbreaks and we have quite the party.
TinyUmbrella now has support for saving 5.1 SHSH for Apple TV 3 and the iPad 3 (all versions). As of now we still cannot restore them but we are working on getting that working from a bunch of angles. I'll let you know more when I do.
Save your SHSH!
vừa vào trang tiny đã thấy có update đã lưu thành công shsh 5.1 ACE nhanh tay nào
Notcom release Tinyumberella with iPad 2,4 (wifi re-release) support
TinyUmbrella now supports iPad 2,4 for iOS 5.1. Simply connect your new iPad 2 and save your SHSHs!
I've come across some spare time and have started putting more effort into TinyPwn and the rewrite of TinyUmbrella. Thank you all for your continued support and feedback! Your support is my motivation.
Thanks and Save your SHSH!
This is how I roll,back to School
TinyUmbrella v5.10.15 - downgrade iPad 1 ko cần SHSH
If you are one of the first generation iPad users or if you haven’t saved your SHSH blobs yet, TinyUmbrella v5.10.15 is a must have. Why? Because with the new version you can downgrade your device at any time without worrying about the release of the new iOS versions, and this will help you keep your device jailbroken as there is no way you could downgrade to an older ipsw without having saved your SHSH blobs.
The bad news is that downgrading your iPhone 4S. Why? Because till now Apple signs the firmware during the restoration process. But wait, keeping your SHSH blobs saved is a good idea.
TinyUmbrella v5.10.15 is compatible with both Windows and MacOS X. Here are the direct links to the update:
Download TinyUmbrella 5.10.15 for Windows
http://cache.firmwareumbrella.com/downloads/tinyumbrella-5.10.15.exe
Download TinyUmbrella 5.10.15 for Mac
http://cache.firmwareumbrella.com/downloads/TinyUmbrella-5.10.15.pkg
cho mình hỏi có cách nào để lấy SHSH từ server của Cydia về máy ko nhỉ? :-/
Cập nhật TinyUmbrella để hỗ trợ iPhone 4 (GSM) Build iOS 5.1.1 mới
Không rõ lý do Apple phát hành một hơi cập nhật firmware 5.1.1 (GSM) iPhone 4. Điều kỳ lạ về phiên bản này là nó không cập nhật baseband (GSM) iPhone 4 và không có thay đổi liên kết với nó. Trong khi điều này là lạ, Apple rõ ràng là cảm thấy sự cần thiết phải bao gồm một sửa chữa nhỏ cho những người đang được cập nhật firmware iOS 5.1.1, nhưng không nghĩ rằng nó sẽ có giá trị gọi đó là IOS 5.1.2.
Các nhà phát triển của TinyUmbrella, _AT_ NotCom gần đây đã tweet rằng ông đã cập nhật TinyUmbrella phiên bản 5.11.01 để hỗ trợ iPhone (GSM) 4 iOS 5.1.1 Build 9B208 firmware mà Apple lén lút phát hành. Vì vậy, bạn có thể tiết kiệm iOS của bạn 5.1.1 Build 9B208 SHSH bằng cách sử dụng TinyUmbrella 5.11.01 mà không có bất kỳ khó khăn.
Bạn có thể tải về TinyUmbrella 5.11.01 thông qua các liên kết dưới đây:
TinyUmbrella 5.11.01 ( Windows )
TinyUmbrella 5.11.01 ( Mac OS X )
nhờ moin người giúp đỡ
mình cài tinyumbrella v6.01.01 về máy và chạy thì phần mềm báo cannot star TTS sẻvice
DO NOT TRY RESTORING YOUR DEVICE
tiny...
và ko hiện lên gì cả.như vậy là bị làm sao và rất mong a e trong diễn dàn hướng dẫn mình cách khắc phục để mình lấy SHSH restore 4s từ 5.1.1 về 5.1.1
thank các bạn trước!
Không setup dc TU
Mấy bác cho hỏi là mình cái win 8 pro đã cái java 7 update 15 rùi mà sao cái TU này vào no1bao1 là thiếu java hay đại loại gì đó.Mình hok cài dc Tu nên hok tài nào save SHSH dc.Mong các bác hướng dẫn cho.Xin chân thành cảm ơn ^^!
