<?xml version="_defaultstyle.0" encoding="UTF-8"?>
<mf xmlns="http://www.nokia.com/mf/2.0">
<effectdefinitions path="c:\resource\effects\" max_transition_cache_size="1000000" max_cache_size="500000">
<effect name="app_activate_common_citystyle" file="AppActivate_city.kml"/>
<effect name="app_exit_common_citystyle" file="AppExit_city.kml"/>
<effect name="appshell_exit_citystyle" file="AppShellExit_city.kml"/>
<effect name="folder_close_citystyle" file="AppShellFolderClose_city.kml"/>
<effect name="folder_open_citystyle" file="AppShellFolderOpen_city.kml"/>
<effect name="app_start_common_citystyle" file="AppStart_city.kml"/>
<effect name="app_start_rect_common_citystyle" file="AppStartRect_city.kml"/>
<effect name="app_start_switch_common_citystyle" file="AppStartSwitch_city.kml"/>
<effect name="app_start_switch_rect_common_citystyle" file="AppStartSwitchRect_city.kml"/>
<effect name="startup_exit_citystyle" file="StartupExit_city.kml" wanted_frame_time="100"/>
<effect name="screensaver_deactivate_citystyle" file="Screensaver_city.kml" />
<effect name="comp_optionsmenu_main_citystyle" file="CompOptionsMenuMain_city.kml"/>
<effect name="comp_optionsmenu_main_cascade_citystyle" file="CompOptionsMenuCascade_city.kml"/>
<effect name="comp_taskswapper_citystyle" file="CompTaskSwapper_city.kml"/>
<effect name="comp_numberentry_citystyle" file="CompNumberEntry_city.kml"/>
<effect name="comp_toolbar_citystyle" file="CompToolbar_city.kml"/>
<effect name="comp_touch_toolbar_citystyle" file="CompTouchToolbar_city.kml"/>
<effect name="list_common_background_citystyle" file="ListCommonBackground_city.kml"/>
<effect name="list_common_item_citystyle" file="ListCommonItem_city.kml"/>
<effect name="list_appshell_background_citystyle" file="ListAppShellBackground_city.kml"/>
<effect name="list_appshell_item_citystyle" file="ListAppShellItem_city.kml"/>
<effect name="grid_appshell_background_citystyle" file="GridAppShellBackground_city.kml"/>
<effect name="grid_appshell_item_citystyle" file="GridAppShellItem_city.kml"/>
<effect name="comp_contextmenu_citystyle" file="CompContextMenu_city.kml"/>
</effectdefinitions>
<effect name="app_activate_common_defaultstyle" file="AppActivate_default.kml"/>
<effect name="app_exit_common_defaultstyle" file="AppExit_default.kml"/>
<effect name="appshell_exit_defaultstyle" file="AppShellExit_default.kml"/>
<effect name="folder_close_defaultstyle" file="AppShellFolderClose_default.kml"/>
<effect name="folder_open_defaultstyle" file="AppShellFolderOpen_default.kml"/>
<effect name="app_start_common_defaultstyle" file="AppStart_default.kml"/>
<effect name="app_start_rect_common_defaultstyle" file="AppStartRect_default.kml"/>
<effect name="app_start_switch_common_defaultstyle" file="AppStartSwitch_default.kml"/>
<effect name="app_start_switch_rect_common_defaultstyle" file="AppStartSwitchRect_default.kml"/>
<effect name="startup_exit_defaultstyle" file="StartupExit_default.kml" wanted_frame_time="100" />
<effect name="layout_switch_defaultstyle" file="LayoutSwitch_default.kml"/>
<effect name="layout_switch_Start_defaultstyle" file="LayoutSwitchStart_default.kml"/>
<effect name="layout_switch_Exit_defaultstyle" file="LayoutSwitchExit_default.kml"/>
<effect name="screensaver_deactivate_defaultstyle" file="Screensaver_default.kml" />
<effect name="screensaver_activate_defaultstyle" file="Screensaver_default.kml" />
<effect name="comp_optionsmenu_main_defaultstyle" file="CompOptionsMenuMain_default.kml"/>
<effect name="comp_optionsmenu_main_cascade_defaultstyle" file="CompOptionsMenuCascade_default.kml"/>
<effect name="comp_taskswapper_defaultstyle" file="CompTaskSwapper_default.kml"/>
<effect name="comp_numberentry_defaultstyle" file="CompNumberEntry_default.kml"/>
<effect name="comp_toolbar_defaultstyle" file="CompToolbar_default.kml"/>
<effect name="comp_touch_toolbar_defaultstyle" file="CompTouchToolbar_default.kml"/>
<effect name="list_common_background_defaultstyle" file="ListCommonBackground_default.kml"/>
<effect name="list_common_item_defaultstyle" file="ListCommonItem_default.kml"/>
<effect name="list_appshell_background_defaultstyle" file="ListAppShellBackground_default.kml"/>
<effect name="list_appshell_item_defaultstyle" file="ListAppShellItem_default.kml"/>
<effect name="grid_appshell_background_defaultstyle" file="GridAppShellBackground_default.kml"/>
<effect name="grid_appshell_item_defaultstyle" file="GridAppShellItem_default.kml"/>
<effect name="comp_contextmenu_defaultstyle" file="CompContextMenu_default.kml"/>
<effect name="comp_errornote_defaultstyle" file="CompErrorNote_default.kml" />
<effect name="comp_warningnote_defaultstyle" file="CompWarningNote_default.kml" />
<effect name="comp_informationnote_defaultstyle" file="CompInformationNote_default.kml" />
<effect name="comp_confirmationnote_defaultstyle" file="CompConfirmationNote_default.kml" />
<effect name="comp_waitnote_defaultstyle" file="CompWaitNote_default.kml" />
<effect name="comp_query_defaultstyle" file="CompQuery_default.kml" />
<effect name="comp_popup_default_defaultstyle" file="CompPopupDefault_default.kml" />
<effect name="comp_systemnotify_defaultstyle" file="CompSystemNotify_default.kml" />
<effect name="comp_systemnotify_battery_defaultstyle" file="CompSystemNotify_battery_default.kml" />
<effect name="comp_sequence_first_defaultstyle" file="CompSequence_first_default.kml" />
<effect name="comp_sequence_mid_defaultstyle" file="CompSequence_mid_default.kml" />
<effect name="comp_sequence_last_defaultstyle" file="CompSequence_last_default.kml" />
<effect name="no_effect" file="noeffect.kml"/>
<effect name="app_activate_common_jingstyle" file="AppActivate_jing.kml"/>
<effect name="app_exit_common_jingstyle" file="AppExit_jing.kml"/>
<effect name="appshell_exit_jingstyle" file="AppShellExit_jing.kml"/>
<effect name="folder_close_jingstyle" file="AppShellFolderClose_jing.kml"/>
<effect name="folder_open_jingstyle" file="AppShellFolderOpen_jing.kml"/>
<effect name="app_start_common_jingstyle" file="AppStart_jing.kml"/>
<effect name="app_start_rect_common_jingstyle" file="AppStartRect_jing.kml"/>
<effect name="app_start_switch_common_jingstyle" file="AppStartSwitch_jing.kml"/>
<effect name="app_start_switch_rect_common_jingstyle" file="AppStartSwitchRect_jing.kml"/>
<effect name="startup_exit_jingstyle" file="StartupExit_jing.kml" wanted_frame_time="100"/>
<effect name="layout_switch_jingstyle" file="LayoutSwitch_jing.kml"/>
<effect name="layout_switch_Start_jingstyle" file="LayoutSwitchStart_jing.kml"/>
<effect name="layout_switch_Exit_jingstyle" file="LayoutSwitchExit_jing.kml"/>
<effect name="screensaver_deactivate_jingstyle" file="Screensaver_jing.kml" />
<effect name="screensaver_activate_jingstyle" file="Screensaver_jing.kml" />
<effect name="comp_optionsmenu_main_jingstyle" file="CompOptionsMenuMain_jing.kml"/>
<effect name="comp_optionsmenu_main_cascade_jingstyle" file="CompOptionsMenuCascade_jing.kml"/>
<effect name="comp_taskswapper_jingstyle" file="CompTaskSwapper_jing.kml"/>
<effect name="comp_numberentry_jingstyle" file="CompNumberEntry_jing.kml"/>
<effect name="comp_toolbar_jingstyle" file="CompToolbar_jing.kml"/>
<effect name="comp_touch_toolbar_jingstyle" file="CompTouchToolbar_jing.kml"/>
<effect name="list_common_background_jingstyle" file="ListCommonBackground_jing.kml"/>
<effect name="list_common_item_jingstyle" file="ListCommonItem_jing.kml"/>
<effect name="list_appshell_background_jingstyle" file="ListAppShellBackground_jing.kml"/>
<effect name="list_appshell_item_jingstyle" file="ListAppShellItem_jing.kml"/>
<effect name="grid_appshell_background_jingstyle" file="GridAppShellBackground_jing.kml"/>
<effect name="grid_appshell_item_jingstyle" file="GridAppShellItem_jing.kml"/>
<effect name="comp_contextmenu_jingstyle" file="CompContextMenu_jing.kml"/>
<effect name="comp_errornote_jingstyle" file="CompErrorNote_jing.kml" />
<effect name="comp_warningnote_jingstyle" file="CompWarningNote_jing.kml" />
<effect name="comp_informationnote_jingstyle" file="CompInformationNote_jing.kml" />
<effect name="comp_confirmationnote_jingstyle" file="CompConfirmationNote_jing.kml" />
<effect name="comp_waitnote_jingstyle" file="CompWaitNote_jing.kml" />
<effect name="comp_query_jingstyle" file="CompQuery_jing.kml" />
<effect name="comp_popup_default_jingstyle" file="CompPopupDefault_jing.kml" />
<effect name="comp_systemnotify_jingstyle" file="CompSystemNotify_jing.kml" />
<effect name="comp_systemnotify_battery_jingstyle" file="CompSystemNotify_battery_jing.kml" />
<effect name="comp_sequence_first_jingstyle" file="CompSequence_first_jing.kml" />
<effect name="comp_sequence_mid_jingstyle" file="CompSequence_mid_jing.kml" />
<effect name="comp_sequence_last_jingstyle" file="CompSequence_last_jing.kml" />
<effect name="app_activate_common_hazestyle" file="AppActivate_haze.kml"/>
<effect name="app_exit_common_hazestyle" file="AppExit_haze.kml"/>
<effect name="appshell_exit_hazestyle" file="AppShellExit_haze.kml"/>
<effect name="folder_close_hazestyle" file="AppShellFolderClose_haze.kml"/>
<effect name="folder_open_hazestyle" file="AppShellFolderOpen_haze.kml"/>
<effect name="app_start_common_hazestyle" file="AppStart_haze.kml"/>
<effect name="app_start_rect_common_hazestyle" file="AppStartRect_haze.kml"/>
<effect name="app_start_switch_common_hazestyle" file="AppStartSwitch_haze.kml"/>
<effect name="app_start_switch_rect_common_hazestyle" file="AppStartSwitchRect_haze.kml"/>
<effect name="startup_exit_hazestyle" file="StartupExit_haze.kml" wanted_frame_time="100"/>
<effect name="layout_switch_hazestyle" file="LayoutSwitch_haze.kml"/>
<effect name="layout_switch_Start_hazestyle" file="LayoutSwitchStart_haze.kml"/>
<effect name="layout_switch_Exit_hazestyle" file="LayoutSwitchExit_haze.kml"/>
<effect name="screensaver_deactivate_hazestyle" file="Screensaver_haze.kml" />
<effect name="screensaver_activate_hazestyle" file="Screensaver_haze.kml" />
<effect name="comp_optionsmenu_main_hazestyle" file="CompOptionsMenuMain_haze.kml"/>
<effect name="comp_optionsmenu_main_cascade_hazestyle" file="CompOptionsMenuCascade_haze.kml"/>
<effect name="comp_taskswapper_hazestyle" file="CompTaskSwapper_haze.kml"/>
<effect name="comp_numberentry_hazestyle" file="CompNumberEntry_haze.kml"/>
<effect name="comp_toolbar_hazestyle" file="CompToolbar_haze.kml"/>
<effect name="comp_touch_toolbar_hazestyle" file="CompTouchToolbar_haze.kml"/>
<effect name="list_common_background_hazestyle" file="ListCommonBackground_haze.kml"/>
<effect name="list_common_item_hazestyle" file="ListCommonItem_haze.kml"/>
<effect name="list_appshell_background_hazestyle" file="ListAppShellBackground_haze.kml"/>
<effect name="list_appshell_item_hazestyle" file="ListAppShellItem_haze.kml"/>
<effect name="grid_appshell_background_hazestyle" file="GridAppShellBackground_haze.kml"/>
<effect name="grid_appshell_item_hazestyle" file="GridAppShellItem_haze.kml"/>
<effect name="comp_contextmenu_hazestyle" file="CompContextMenu_haze.kml"/>
<effect name="comp_errornote_hazestyle" file="CompErrorNote_haze.kml" />
<effect name="comp_warningnote_hazestyle" file="CompWarningNote_haze.kml" />
<effect name="comp_informationnote_hazestyle" file="CompInformationNote_haze.kml" />
<effect name="comp_confirmationnote_hazestyle" file="CompConfirmationNote_haze.kml" />
<effect name="comp_waitnote_hazestyle" file="CompWaitNote_haze.kml" />
<effect name="comp_query_hazestyle" file="CompQuery_haze.kml" />
<effect name="comp_popup_default_hazestyle" file="CompPopupDefault_haze.kml" />
<effect name="comp_systemnotify_hazestyle" file="CompSystemNotify_haze.kml" />
<effect name="comp_systemnotify_battery_hazestyle" file="CompSystemNotify_battery_haze.kml" />
<effect name="comp_sequence_first_hazestyle" file="CompSequence_first_haze.kml" />
<effect name="comp_sequence_mid_hazestyle" file="CompSequence_mid_haze.kml" />
<effect name="comp_sequence_last_hazestyle" file="CompSequence_last_haze.kml" />
<effectdefinitions path="c:\resource\effects\" max_transition_cache_size="1000000" max_cache_size="1000000">
<effect name="folder_close_nseries" file="AppShellFolderClose_nseries.kml"/>
<effect name="folder_open_nseries" file="AppShellFolderOpen_nseries.kml"/>
<effect name="grid_appshell_item_nseries" file="GridAppShellItem_nseries.kml"/>
<effect name="comp_optionsmenu_main_cascade_nseriesstyle" file="CompOptionsMenuCascade_nseries.kml "/>
<effect name="comp_optionsmenu_main_nseriesstyle" file="CompOptionsMenuMain_nseries.kml"/>
<effect name="app_activate_nseries1" file="AppActivate_nseries1.kml"/>
<effect name="app_exit_nseries1" file="AppExit_nseries1.kml"/>
<effect name="appshell_exit_nseries_1" file="AppShellExit_nseries1.kml"/>
<effect name="app_start_nseries1" file="AppStart_nseries1.kml"/>
<effect name="app_start_rect_nseries1" file="AppStartRect_nseries1.kml"/>
<effect name="app_start_switch_nseries1" file="AppStartSwitchRect_nseries1.kml"/>
<effect name="app_start_switch_rect_nseries1" file="AppStartSwitchRect_nseries1.kml"/>
<effect name="layout_switch_Astrostyle" file="LayoutSwitch_Astro.kml"/>
<effect name="layout_switch_Exit_Astrostyle" file="LayoutSwitchExit_Astro.kml"/>
</mf>
