Phần Mềm Bảo Mật
Guru.Phone.Guardian.v1.00.S60v3.SymbianOS9 .1.Incl.Keyg(e)n.Patch-BiNPDA
Hổ trợ các dòng máy : Nokia 5500, Nokia E50, Nokia E60, Nokia E61, Nokia E62, Nokia E70, Nokia N71, Nokia N73, Nokia N75, Nokia N80, Nokia N91, Nokia N92, Nokia N93, Nokia N95, Nokia 3250, Nokia N Series, Nokia E Series, Nokia E65, Nokia N76, Nokia N93i, Nokia E61i, Nokia N73 Music Edition
Chức Năng :
* Remote mobile lock and unlock with lock SMS
* Phone Guardian becomes active (locks the mobile, emits the siren) when a different SIM card is inserted or on lock SMS
* Operator specific and location information is automatically sent to the number specified, including the number of SIM, IMSI and CellID numbers
* Siren option can be put on and off
* Uninstall possible only with password
* Phone lock is independent from phone restart
Download:
http://www.ziddu.com/download/14888018/symbian.guru.phone.guardian.v1.00.s60v3.zip.html
Ghi Âm Cuộc Gọi (2 chiều)
Chức Năng :
* Play record. You can change the volume with joystick left/right arrows while a record is being played. To change speaker from loud to quiet or vice versa set an option Play volume in Settings dialog to a corresponding value;
* Call a contact or a phone number. If the highlighted record has a phone number, you can dial it even without exiting CallRecorder - just press Call button or select this command;
* Send via Infrared/Bluetooth/Email/MMS you can send the recorded conversation with the help of this command;
Phím Nóng
* Xem danh bạ nhanh bằng Phím nóng '*'
* Xem nhanh các file ghi âm đã lưu bằng phím '5';
* Ngừng ghi âm 'C';
* Xóa tất cả các file đã ghi : 'Pen+C');
Download:
http://www.ziddu.com/download/14888025/rock.your.mobile.call.recorder.pro.v1.10.s60v3.zip.html
BTwebcamera s60 v3
ứng dụng này là dùng DT thay webcam.kết nối qua bluetooth
Download:
http://www.ziddu.com/download/14888030/dungdtlamvc.rar.html
Ứng Dụng Xem TV trên Mobile
ROK TV mobile TV
Download:
http://www.ziddu.com/download/14888076/roktvrt200rc17s60_certified_185.zip.html
Smartphoneware.Best.Alarms.v1.0.S60v3.SymbianOS9.1 .incl.Keyg(e)n-HSpda
Bạn đã chán với giao diện hẹn giờ đơn điệu của máy , đây là công cụ hổ trợ đắc lực cho bạn
Download:
http://www.ziddu.com/download/14888090/smartphoneware.best.alarms.v1.0.s60v3.symbianos9.zip.html
ThemeDIY for N73 N80 N93
Hãy tự tay làm 1 theme (chủ đề) cho chính cú "Dế iu" của bạn nhờ ứng dụng tạo theme trên mobile
Download:
http://www.ziddu.com/download/14888099/themediy_for_n73_n80_n93_861.zip.html
Giấu Tin Nhắn
muốn giấu tin nhắn của bồ..mà ko nỡ xóa đi..hãy làm như sau
bạn cần pm ActiveFile down ở dưới
sau khi cài..tìm và mở chương trình Messaging Explorer = cách nhấn Option/tool/Messaging Explorer
chọn file muốn ẩn..nhấn options/set/hide là ..thế là xog
muốn hiện làm tương tự..nhưng chọn unhide
Download:
http://www.ziddu.com/download/14888135/ActiveFile_3rd_v1.25.rar.html
Symbianguru AutoThemes v1.0 S60v3 SymbianOS9 Unsigned c.r.a.c.k.e.d -OPDA
ứng dụng tự động đổi Theme theo thời gian
Download:
http://www.ziddu.com/download/14888214/s.v1.0.S60v3.SymbianOS9.UnsignedC.r.a.c.k.e.d-OPDA.rar.html
Ứng dụng cắt nối nhạc trên mobile
Download:
http://www.ziddu.com/download/14888263/mp3editor.zip.html
---------- Bài thêm lúc 09:17 ---------- Bài trước là lúc 08:56 ----------
Ứng dụng Chụp X-Quang nè (khỏi cần đi BV chụp hén )<= Đi lừa con nít cũng vui
download:
http://www.ziddu.com/download/14888348/xray.zip.html
Moccatroller v1.5 - remote control PC applications
Ứng dụng điều khiển PC từ xa
Download:
http://www.ziddu.com/download/14891330/MoccatrollerMobile_1.5.zip.html
Tong hop cac phan mem cua Hang Smartphoneware
Đây là tổng hợp các phần mềm của Hãng SmartphoneWare ,tất cả đều là bản full có kèm phần mềm lấy Key ở tệp tin KEY ALL SOFTWARE_SmartPhoneWare.zip nhé !
Download:
Batterysaver60_3_1_00.zip: http://www.ziddu.com/download/14891404/Batterysaver60_3_1_00.zip.html
Best.MessageStorer.v1.03.sisx.zip: http://www.ziddu.com/download/14891405/Best.MessageStorer.v1.03.sisx.zip.html
Bestalarms_s60_3.zip: http://www.ziddu.com/download/14891401/Bestalarms_s60_3.zip.html
Bestblacklist_s60_3_v_2_01.zip: http://www.ziddu.com/download/14891406/Bestblacklist_s60_3_v_2_01.zip.html
Smartphoneware.Best.Blacklist.v3.2.S60v3.S60v5.SymbianOS9.x.Unsigned.*****ed-FoXPDA.sis.zip: http://www.ziddu.com/download/14891403/0v3.S60v5.SymbianOS9.x.Unsigned.Cracked-FoXPDA.sis.zip.html
Bestcalculator_s60_3_v_1_06_sw.zip::
http://www.ziddu.com/download/14891532/Bestcalculator_s60_3_v_1_06_sw.zip.html
Bestconverter_s60_3_v_1_00.zip ::
http://www.ziddu.com/download/14891530/Bestconverter_s60_3_v_1_00.zip.html
Bestcrypto_s60_3.zip ::
http://www.ziddu.com/download/14891531/Bestcrypto_s60_3.zip.html
Bestkeylocker_S60_3_0_v_1_01_0_signed.zip:
http://www.ziddu.com/download/14891528/Bestkeylocker_S60_3_0_v_1_01_0_signed.zip.html
File Type: zip Bestmenu_s60_3_v_1_00.zip:
http://www.ziddu.com/download/14891529/Bestmenu_s60_3_v_1_00.zip.html
Còn cái này là phần mềm lấy KEY của các phần mềm SmartPhoneWare ----->>>>> Tình hình này thì chắc SmartPhoneWare chỉ có khóc thui !
http://www.ziddu.com/download/14891481/KEYALLSOFTWARE_SmartPhoneWare.zip.html
Phan mem bảo vẹ Ung Dung
Chức năng : Bảo vệ ứng dụng bằng Password .Khoá thiết bị và gửi tin nhắn ngầm báo mất trộm máy đến 1 số điện thoại đã được lập trình trước khi sim bị đổi ( Gửi tin nhắn với nội dung báo Sim đã bị đổi và số serial sim đã lắp của người đánh cắp )
Nhớ Sign phần mềm or Hackphone thì mới cài được nhé
Download:
http://www.ziddu.com/download/14891584/Handy.PhoneguarunsignS60v3.zip.html
