TỔNG HỢP CẬP NHẬT CÁC ỨNG DỤNG!
Tổng hợp, cập nhật các ứng dụng!
Screenshot v3.00 S60v3 SymbianOS9.x Unsigned
Ứng dụng chụp ảnh màn hình.
27641d1201613687-29-01-08-screenshot-v3-00-s60v3-symbianos9-x-unsigned-screenshot0040wc3.jpg
Jbak TaskMan Unsigned v0.96
Ứng dụng hỗ trợ quản lý các ứng dụng đang chạy...
Features:
Find and start the desired application by pressing '#' key and typing the first letters of its name.
Create shortcuts in the Launch Menu to start applications, open documents or for specific tasks.
Get full information about running programs and free memory left on the phone (RAM, Phone memory and Memory card).
Switch to or Close any application. (Yes, it can close Gallery & Music player too)
Run Jbak Taskman by pressing and holding Menu button (like the built-in Task manager).
Lock keypad from any screen.
Reboot your phone.
AnimSprite v2.22 update
Ứng dụng cho phép đưa ảnh động ra màn hình chờ. Đặt ảnh vào thư mục e:/data/animsprite. Bản cập nhật!
28133d1202107800-04-02-08-hot-animsprite-v2-22-update-signed-n-unsigned-20070907_eb8aeba
RotateMe v2.0 Unsigned Final Version
Phần xoay màn hình giống iphone Phiên bản chính thức :D
SmartSettings v1.00 Beta1 S60v3 Unsigned
Ứng dụng bây giờ mới có trên s60V3.
Smart Settings is designed to protect your phone and make its appearance unique. It combines the possibility to lock the keyboard, prevent from using the phone's 10 digits Master Code in case of lost, customize lock messages and access easily the most common applications (by exactly 2 keystrokes).
Unique features:
Start Menu: It provides a way to customize your phone so that it looks in your own unique way. You can use these set of features for quick access of the your favourite applications. For them you can chose speed keys (1-9). After, these applications will be accessible by the Left Selection Key + Their Speed Key.
Easy Unlock: Forget the boring Unlock + * and choose the most convenient unlock combination for yourself, your phone was never that cool
Security: You can disable the Master Security Code, so no one can unlock your phone in just a few seconds.
[hide]Download
[/hide]
Thực hiện qui định mới của diễn đàn.
Threat này sẽ là nơi tổng hợp, cập nhật các ứng dụng cho S60v3.
Yêu cầu:
- Các ứng dụng được giới thiệu trong thread này sẽ là các bản Trial hay Freewares.
- Tuyệt đối không tuyên truyền, phổ biến các ứng dụng đã được bẻ khóa.
- Không được yêu cầu, đề nghị hay thắc mắc về ứng dụng trong thread này.
- Mọi vấn đề thắc mắc xin liên hệ qua PM (tin nhắn cá nhân) cho tác giả của bài post.
BĐH SYM
