TỔNG HỢP CẬP NHẬT CÁC ỨNG DỤNG!
GhostS60 V1.0
Backup các file đăng ký, config trước khi format. Sau đó có thể phục hồi lại để không mất công đang ký.
Ứng dụng chạy trên nền python.
File config, đăng ký của các phần mềm:
* Default apps:Adobe Reader:
***/Private/20001bb9/20001bb9.ini (configuration file);
* Quicksheet:
***/Private/200002c2/quicksheet.ini (configuration file);
* Zip manager:
***/Private/2000023d/zipmanager.ini (configuration file);
* VideoEditor:
***/Private/10208a29/ManualVideoEditor.ini (configuration file);
* ImageEditor:
***/Private/101ffa91/ImageEditor.ini (set. file);
***/Private/101ffa91/PluginStorage.ini (configuration of plugins);
* Radio:
***/Data/radiostations.db (set. file of the stations);
***/private/101ff976/visualradio.ini (configuration file);
* browser:
***/Private/101F8530/Coocies.dat (kookies);
***/Private/100012a5/DBS_101FD685_BrowserSavges.db (File of the saving pages);
***/Private/100012a5/DBS_101FD685_BrowserBookmarks.db(book-marks, before copying kill a process *FavouritesSrv.exe*, maybethe phone will hang up);
* Calendar:
***/Private/10003a5b/Calendar (set. file );
Notes:
***/Private/100012a5/DBS_101F8878_Notepad.dat (file of the notes);
* Apps from Lonely Cat Games:For registration in all of applications answers:
с:/Private/100012a5/DBS_100065ff_Contacts.cdb ( before copying kill a process *CNTSrv.exe*)
* LCG Jukebox:
!:/private/a0000bcc/MusicPlayer/config.txt (configuration file);
* ProfiMail:
!:/System/Data/ProfiMail/config.txt (configuration file);
!:/System/Data/ProfiMail/accounts.bin (This file is responsible for the setup of your account - your mail servers);
!:/System/Data/ProfiMail/mail/ (folder with the m*es*** headers of m*es from the accounts)
!:/system/data/profimail/m*es.bin (responsible for incoming*** outgoing m*es);
* X-plore:
!:/private/a0000bcd/Explorer/config.txt (configuration file);
!:/private/a0000bcd/Explorer/QuickDirs.bin (file is responsible for the labels);
!:/private/a0000bcd/Explorer/Assoc.bin (file is responsible for the association);
* Slick:
!:/System/data/Slick/accounts.bin (account`s configuration);
* SmartMovie v4.x
!:/private/a000b868/SmartMovie/config.txt
!:/Private/a000b868/xl_config.kls (configuration file);
Apps from Epocware:
* It is intended for the licensed possessors of these applicationsHandy Calculator:
***/private/2000cec6/HandyCalculator.ini (file of registration);
* Handy Calendar:
***/private/20004ec1/HandyCalendar.ini (file of registration*** of configuration);
* Handy Clock:
***/private/200013A4/HandyClock.ini (file of registration);
***/Epocware/HandyClock/Settings.ini (configuration file);
* HandyConverter:
***/private/20007fab/HandyConverter.ini (file of registration);
* HandyProfiles:
***/private/2000A4B2/HandyProfilesServer.ini (configuration file*** file switching profile);
***/private/2000A4B1/HandyProfiles.ini (file of registration);
* HandyShell:
***/private/20013B7B/HandyShell.ini (file of registration*** configuration *apps*** contacts*);
***/private/20013B78/HandyShellServer.ini (configuration file);
* HandyTaskman:
***/private/20004EBB/HandyTaskman.ini (file of registration*** configuration);
* Handy Weather:
***/private/2000139F/HandyWeather.ini (file of registration);
***/private/2000139D/DownloadServer.ini (file of registration IMEI on a server);
***/Epocware/HandyWeather/Settings.ini (configuration file of cities);
* Apps from SmartphoneWare:BestBlacklist:
!:/data/BBlacklist/BestBlacklist.db (file of registration);
!:/data/BBlacklist/BestBlackList.ini (configuration file);
* BestTimer:
!:/private/20012550/Timer_reg.reg (file of registration);
!:/private/20012550/Timers (file of timers);
* BestProfiles:
!:/Private/200095E7/BestProfiles.reg (file of registration);
!:/Data/SmartphoneWare/BestProfiles/settings.dat (Schedule profile switching);
* FSCaller:
!:/private/2000FE63/FSCaller.reg (file of registration);
!:/private/2000FE63/FSCaller.dat (configuration file);
* Best private conversation:
!:/Smartphoneware/BPC/Rules.dat (configuration file);
* System :ActiveFile:
!/:system/data/ActiveFile/Settings/general.ini (configuration file);
* N82smart:
***/Data/N82smart/n82smart.ini (configuration file);
* Smart Settings:
***/private/2000e18c/SmartSettingsSettings.ini (file of registration*** configuration);
* SlideHelper:
***/private/ebe74ca5/SlideHelper.ini (configuration file);
* FreeCallSprite
***/private/e3527aab/FreeCallSprite.ini
***/Data/FreeCallSprite/FreeCallSprite.dic
***/Data/FreeCallSprite/FreeCallSprite.cfg (configuration file );
* Vibrate call:
!:/private/200143DA/regfile.txt (file of registration);
!:/private/200143DA/VibrateCall.ini (configuration file);
* Killme:
!:/ private/EAFE014C/ (folder with a list of programs: protected , removable, unusual, reserved );
* JbakTaskMan:
!:/System/data/JbakTaskMan.ini (all config. of app);
* TaskSpy:
***/private/2000713a/taskspy.ini (configuration file);
* Тracker:
!:/Private/200095EB/Tracker_reg.reg (file of registration);
!:/Private/200095EB/note.txt (notes);
!:/Private/200095EB/options.dat (configuration file);
!:/Private/200095EB/recent.dat (hot keys);
* PowerBoot:
с:/Private/20008A14/PowerBoot.cfg (list of the programs for an autostart);
* Switch off:
***/Private/2001b52e/SOServerSettings.ini (configuration file);
* Kaspersky Mobile Security v7.x
***/private/200112C4/Settings.kls (configuration file);
***/private/200112С4/b.dat (bases of ***s);
* Kaspersky Mobile Security v8.x
***/private/2001CFC6/settings.kls (configuration file);
***/private/2001CFC6/b.dat (bases of ***s);
PhonePhreak.Software.SmartLight.v1.6.S60v3.S60v5.SymbianOS9.x
Giữ sáng màn hình.Bản cập nhật
Animation Menu V0.1
Thêm hiệu ứng động cho các icon Menu.
Cách dùng:
Tự tạo file c2z.rmp chép vào E:\Patches
Vào RomPatcher apply và add to start file rmp này.
Chọn hiệu ứng
Khởi động lại máy là ok
Shaanxi Haocheng XCLOCK v2.0 S60v3 SymbianOS9.1 Unsigned
Ứng dụng hẹn nhắc nhở với 5 lựa chọn: theo sự kiện, theo ngày, theo tháng, theo ghi nhớ...
Boot Partner v0.1
Ứng dụng hỗ trợ thay đổi màn hình khi khởi động với 2 lựa chọn Sony và WinXP. Ứng dụng chạytrên nền python và megapymodule. máy phải hack.
Hỗ trợ: E51, E71, E90, N82, N95, N95 8G, N78, N79, N85, N96
GyPSii v1.0
GyPSii là một ứng dụng với các chức năng tìm bạn bè, khám phá địa phương, những chức năng chính:
* PlaceMe - ghi lại một khoảnh khắc trong cuộc sống của bạn và chia sẻ nó với bạn bè của bạn và các thành viên GyPSii. Gởi hình ảnh, video hoặc âm thanh và up lên mạng. GyPSii có thể tìm thấy địa điểm của bạn từ GPS của bạn để những người khác có thể nhìn thấy, vị trí của bạn sẽ được hiển thị trên điện thoại di động của bạn bè và trên trang web.
* SpaceMe - chỉ cho bạn thấy bạn bè của bạn ai đang ở vị trí gần bạn nhất, xem nơi họ đang ở trên một bản đồ và liên hệ với họ.
* ExploreMe - khám phá những gì xung quanh vị trí hiện tại của bạn, xem hình ảnh, video, phát âm thanh được ghi lại. Chia sẻ những gì bạn đã được tìm thấy với bạn bè của bạn.
* FindMe - chỉ cho bạn thấy bạn đang ở đâu ngay trên trên bản đồ.
Hãy khám phá nhé:
Dmitriy Tarasov BlackList Mobile v1.60 S60v3 SymbianOS9.1 Unsigned Cracked
BlackListMobile is a tool used to block incoming calls and sms from contactsadded to BlackList. Please add contacts you wish to ignore in"Contacts" menu. You also can provide url of sms-gate (for example"smsgate.com") to block messages sent from this url.
Set applicationstate to "On" to activate blacklist functionality. You can see blockedincoming events log in "BlackList log" menu. Click particular event tomore info. It is reccomnded to set autostart option to "On" in"Settings" menu.
"Block hidden" menu option is used to blockincoming calls from hidden numbers. "Block unknown" menu option is usedto block incoming calls and sms from contacts not in your address book
Key Features:
* Blocks incoming calls and sms from the contact listed in the blacklist
* Allows you to block sms, sent to the sites, as well as promotional sms
* There is an opportunity to lock neopredelyaemyh numbers (with the service "Calling line identification restriction)
* Can not lock the room from the address book
* Has a simple interface, the payment directly from a smartphone
http://www.mediafire.com/?mq1gnzqintm
FlyingBird Software FlyingMoney v1.12.7 S60v3 SymbianOS9.x Cracked-DiL
Bản update V1.12.7 Công cụ quản lý tài chính cá nhân!!
Flying Money Manager for s60 ver.3 is your personal and business money and budget manager . It's proven that using Flying Money Manager is a lot easier than keeping track of all paper receipt..
Your Intuit Quicken and MS Money handheld companion.
* Track your personal and business expenses, deposits and transfers, scheduled and other transactions associated with your bank accounts in a easy and intuitive way;
* Generate customized Reports for integration with Excel for further analysis.
Main features
Start menu: easy to star and navigate.
Account balances at a glance
View account's registry
Budgets: setting up and reports
Scheduled Transactions: weekly, monthly, etc. automatically generated on the due dates
Memorized/Regular Transactions.
Finance information security. Encryption. Password-protection.
Multiple currencies support; currency exchange history.
Search Transaction tool.
Reporting tool with export to MS Excel
Split of Transaction across multiple categories
Forecasting of future account balance.
Reminders for scheduled Transactions.
Customizable Expense and Income Categories.
Back-up and Restore your financial data.
Support of multi-currencies transactions.
Account balancing: purging transactions;
Account balancing: adjusting the current balance ( UIQ 3 only)
Export/Import of QIF, OFX, QFX files for integration with the finance software like MS Money, Quicken etc.
Whats New:
Version v1.12(7) features new landscape mode for budget and regular reports.
Now you can see all the needed information on your phone screen.
Download http://www.mediafire.com/?mjzdulm23el
Deutsche_grammatik
PM tra nhanh ngữ pháp tiếng Đức trên Mobile, nội dung rất phong phú. Tất hữu ích cho ae nào đang học tiếng Đức
Red Five Labs Net60 v2.10 S60v3 S60v5 SymbianOS9.x-illusion
PM hỗ trợ cài các ứng dụng .NET mà không cần thay đổi thiết bị Symbian
PHẦN MỀM THAY ĐỔI HOẶC TẮT TIẾNG CAMERA
SoundCamalcon3gro - No Camera Sound Patch - (for Rompatcher)
LƯU Ý : Máy phải hack và phải cài được pm RomPatcher nhé . Vì pm này chạy với RomPatcher
Cách sử dụng : sau khi tải về giải nén ra các bạn làm như sau :
1- Đặt file patch (.rpm) vào E:/patches
2- Đặt 4 file sounds (.wav) vào thư mục E:/system/Sounds/digital
(các bạn có thể tạo thư mục đó). Nếu muốn tắt âm thanh camera thì để thư mục trống
3. Bây giờ có thể bật " enable the patch " trong RomPatcher
Pm chạy được trên :
-N82 v10
-N95-1 v30
-N95-3
-N96 v12.043 - tôi đã thử và làm việc rất tốt
-N82 v30
Với pm này các bạn có thể tắt hoặc thay đổi âm thanh chụp ảnh . Các bạn hãy khám phá nhé . Chúc vui !!!
Psiloc.TotalForwarder.v1.0.S60v3.SymbianOS9.1.Unsi gned.Read.NFO-illusion
Phần mềm tự động chuyển tiếp các cuộc gọi, sms đến 1 số dt định sẵn
Download
Mocap Phone v1.0
PM làm ảnh động từ chuyển động của cơ thể (hỗ trợ các máy có Accelerometer)
DeskCountDown v1.2.3
PM hiện thị và tính toán giúp bạn những ngày lễ,những ghi chú từ hôm nay đến ngày đó là bao nhiêu ngày...Bản cập nhật
