TỔNG HỢP CẬP NHẬT CÁC ỨNG DỤNG!
PullFace J2ME camera software
Phần mềm chỉnh sửa ảnh
[hide][/hide]
Microsoft Mobile (Java) giúp bạn làm điều ấy thật dễ dàng trên điện thoại S60V3 với giao diện đẹp giống như bạn đang thực hiện với Microsoft Word, đặc biệt là vẫn giữ nguyên định dạng gốc. Các bạn thử xem nhé
http://www.mediafire.com/?xslwsmxu2ap
CellTrack version 1.05 *opensigned*
Ứng dụng hỗ trợ xem các thông tin về các thiết bị điện thoại kết nối: mạng...
CellTrack is a program to collect some phone information about the cell you are connected to - like the net monitor. For more information about GSM net search the web.
attachment.php
AutoTheme 1.0.0 S60v3 SymbianOS9.1
Tự động chuyển theme theo thời gian hoặc profile.
Magic Message Manager
Ứng dụng quản lý tin nhắn: lọc, sắp xếp, giấu tin...
Magic Message Manager is a great software to sort (filter) any incoming and outgoing message. It filters emails, SMS and MMS messages, beamed files and can do any action using powerful filters. You can sort your messages, hide private messages, delete unwanted email or SMS spam, transfer messages and files to specific folders, forward messages to another phone number, automatically clean your message box, receive notifications about unread messages and do much more.
With Magic Message Manager you can organize your messages and files for easier access. Magic Message Manager can help you to categorize all messages at one action. Not only with messages, you can now save beamed files to any place.
Magic Message Manager can help you to protect confidential messages from unwanted eyes. All the sensitive messages can be hidden automatically and then be read only with right password.
Magic Message Manager can notify you about unread messages. Now you don't need to unlock the phone to check what you could have missed.
Magic Message Manager can also transform any phone number found in SMS to more readable form, including not only the phone number, but also the contact's name.
Another useful feature is that Magic Message Manager allows to play different message sounds depending on message senders.
[FONT=arial,sans-serif]vnphonedir_3.301signed
[/FONT]​
Tính năng chính
[/FONT]
[FONT=arial,sans-serif] : hiển thị địa chỉ khi nhận cuộc gọi.
Tính năng phụ là khi gọi đi cũng hiện lên địa chỉ luôn
[/FONT]
[FONT=arial,sans-serif]Danh sách các cuộc gọi đến
[/FONT]
[FONT=arial,sans-serif]Nhấn phím "Ẩn" để thóat ra[/FONT]
Phím lên/xuống để xem danh sách
Phím phải/trái để chuyển chức năng
Phím "#" để sửa dữ liệu
Phím màu xanh lá cây để thực hiện cuộc gọi
Danh sách các cuộc gọi đi
Nếu bạn có 1 danh sách dài các số điện thọai, hãy thêm vào trong file 00.txt (nằm trong 00.zip). Chú ý : ngăn cách giữa số điện thọai và địa chỉ bằng phím TAB.
[FONT=arial,sans-serif] Chức năng tra số điện thọai
[/FONT]
[FONT=arial,sans-serif]Dùng phím 0-9 và phím "C" để nhập số
Phím * hoặc select/center để tra
Phím lên/xuống để tra số tiếp theo
Phím "#" để sửa địa chỉ
[/FONT]
[FONT=arial,sans-serif]Sửa thông tin thỏai mái ở đây, nhưng tốt nhất theo định dạng đầu từ viết Hoa, vd : [/FONT][FONT=arial,sans-serif]"Đây Là Định Dạng Đầu Từ Viết Hoa"
Nếu nhập liệu tốt, sau này tìm kiếm danh bạ cá nhân sẽ nhanh và chính xác.[/FONT]
Unicode: hỗ trợ nhưng không nên dùng vì chức năng tìm kiếm + import/export
không hỗ trợ unicode
[FONT=arial,sans-serif]Danh bạ cá nhân
[/FONT][FONT=arial,sans-serif] Phím C để xóa số điện thọai
[/FONT]
[FONT=arial,sans-serif]Dùng các phím 0-9 để tìm/lọc thông tin
VD: hình bên đang tìm các số có "CA" ở vị trí bất kỳ
chú ý: do SQL trên điện thọai không hỗ trợ hàm LOWER nên bộ lọc phân biệt chữ HOA và chữ thường. Để tìm kiếm dễ dàng, nên nhập thống nhất theo kiểu "Đầu Từ Viết
[/FONT][FONT=arial,sans-serif]Hoa"
[/FONT]
Phím * để chuyển chế độ tìm từ vị trí bất kỳ sang tìm từ ký tự
[/FONT][FONT=arial,sans-serif]đầu tiên
[/FONT]
[FONT=arial,sans-serif]Nếu chọn "Yes", bạn sẽ xóa số này khỏi danh bạ của riêng mình.[/FONT]
Export Data
chức năng lưu tòan bộ danh bạ cá nhân của bạn vào file E:\DBDT\import.txt. Hãy cất file này vào nơi an tòan, hoặc gửi cho bạn bè.
Import Data: để phục hồi dữ liệu của bạn từ file import.txt. Nếu nhận được file import.txt của bạn bè, hãy copy vào E:\DBDT để thêm vào danh bạ hiện có của bạn.
Số điện thọai trùng sẽ bị ghi đè nên nếu muốn giữ số cũ của bạn, hãy export trước, import của bạn bè, rồi import lại của bạn lần nữa.
Hướng dẫn thay giao diện SKIN:
[FONT=arial,sans-serif]1. Xác định kích thứơc màn hình. Vd: E61 là 320 (x240).
2. Tìm hình em gái xinh đẹp chỉnh (resize) lại thành 320x240
3. Đổi tên thành 320-1.jpg copy vào E:/dbdt
[/FONT]
Nhấn Thank để thấy Link tải file !
[hide="hide"]Download Click Here![/hide]
Nguồn: hieuvpn!​
Calendar Flashlite
Lịch flash cho điện thoại của bạn
[HIDE="click thanks"]http://www.badongo.com/vid/607753[/HIDE]
VibrateCall V 1.0 SIGNED (Shareware)
Ứng dụng mới. Bản shareware, dùng trong 30 cuộc gọi. File đã sign.
Chức năng: khi bạn thực hiện cuộc gọi, bình thường bạn phải chờ reng chuông chờ trong quá trình chờ bắt máy. Khi cài PM này vào, khi thực hiện cuộc gọi, bạn ko cần phải để máy vào tai để chờ trả lời mà lúcnày máy sẽ rung, khi nào người bên kia bắt máy thì máy sẽ hết rung, lúc này mình sẽ đưa lên nghe.
Hỗ trợ: Nokia N95(8GB), N82, N81(8GB), N76, E51, E90, 6290, 6120, 6121, 6110, 5700
Broov Aroma
Aroma sẽ ko thể cho người sử dụng truy cập vào tính năng hoặc thông tin cá nhân của nó trên máy đt
[hide][/hide]​
AnimSprite Lite 2.22
Ứng dụng hỗ trợ hiển thị ảnh động ra màn hình desktop. Áp dụng làm logo động...
Nếu đã cài các version cũ thì các bạn phải remove và xóa folder c:\data\animsprite
