Editing the 2nd homescreen - PRE-BETA but got bugs (C6 Homescreen)
I was playing around making my cfw.
I've added the files on extra options on left soft key(adding change background and right selection key).
I guess I'd got this file from jomar. and maybe this is just a bug but it may be used for future development.
When I swipe to hide contents, option to add content is still there.
You can actually add content and it really works.
But when you swipe to show contents its gone again and those added widgets will be located on blank spaces on the widgeted homescreen. So you need blank spaces on the widget homescreen to be able to add contents.
You can try this yourself and see for yourself. sorry i cant add video. but its really true
ill attach the file.
2HS
[DOWNLOAD]http://www.mediafire.com/?elezyc3a07xce66[/DOWNLOAD]
Info :
The second homescreen is the rest
i dont have the clean homescreen mod thats why theres a clock
on the 4th photo you can see that the option on left key is the same
(to prove that that is the 2nd homescreen, you will see show contents instead of hide contents
The widgets are really working. music player is playing also wlan scans.
On 7th photo it says that its full but there are still spaces. that is because there are contents on that spot on the first screen.
The last photo shows that it still the 2nd homescreen but it both displays hide and show contents..
Note: i do nothing to create this. i just discovered it and the view file was just my prediction that had made thats the only file that i changed on the cfw.
HS-1
HS-2
