Touch3G WM6.5 ROM V32 (Core 21901) & V33 (Core 21916) ★ MANILA 2.0 (UPDATE)
Em cũng bị trường hợp này. Có bác nào giúp em với :(
mình giải quyết được rối. Bạn cứ up v32. xong rồi bạn up tiếp v33 th2 sẽ không cần align screen nữa vô thẳng Home today luôn.
Thanks for this very good ROM.Anyway I found 2 Bugs:-
- Can not align the screen.It always stay in the loop.
- By long pressing End key, can not run Endkey program.
Is this happened only me or anyone else ?
Thanks again for really excellent ROM I 've ever flashed for Jade.
Bhumdech,Bangkok
Bhumdech,Bangkok
Hi
"Can not align screen" >>> You must flash v32 first. Then you flash v33. The problem is solved.
"By long pressing End key, can not run Endkey program" because of Rom. But it doesn't matter.
Where can I find v32? rapidshare file was deleted!
Excelent ROM but don't like "align screen endless loop.."
You should contact to Mr. PhamQuang to get v32.
Thanks by your reply.
I'm new on this forum. I came here from http://forum.xda-developers.com and I couldn't find how to send a message to Mr. PhamQuang.
Can you please guide me to that?
Thanks
Thanks
Thông tin phần cá nhân của Phạm Quang có đầy đủ địa chỉ email mà (bên dưới tên cá nhân đó)! Nếu chịu khó chút bạn sẽ thấy địa chỉ email của Phạm Quang là:
PhamQuangPV@hotmail.com
Hoặc Pham_Quang_PV@yahoo.com
Hello,
I am Portuguese, so i am sorry for writing in English...
I have installed this great ROM but have a problem with Bluetooth and my car-kit!
Just the first call is 100%, the next calls the car-kit just stays muted and the sound goes out only in the phone.
Can anybody help me with this?
My Phone is HTC Touch 3G, of course... and the car-kit is a Parrot 4100 i think... built in a Citroen C4 Picasso!
PS: I have search in the forum but found nothing that help me.
Thank you very much!
sao bộ nhớ trong con touch 3G của tui chỉ có 88,3 mb nhỉ. vào thế giới di động thấy ghi là 450mb lận :(. ai giải thích giùm vs. tks
bị lỗi rồi anh quang ơi, lỗi align screen, anh làm ơn cho em bản V32 để em up trước sau đó mới up lên V33 cái ạ
a quang ơi. cook room mơi đi a!!!
e voc hoài mà k có j voc nữa.với lại sao chay lau nó lại bị sai time
Do máy bạn có lẽ bị lệch cảm ứng thôi chứ lỗi Align Screen không có đâu bạn..
Lỗi này là chính xác đó! Mình cũng mới up thử. Xong ngon lành đến bước Align thì không thể làm xong! tường máy bị hỏng cảm ứng(trước đó dùng tốt), up lại bản khác lại không bị!
anh ơi Quang ơi làm 1 bản rom mới nghịch đỡ buồn đi à. mọi ng` mong tin a lắm
lâu ngày vào đây mà k có rom mới. hixx. bác quang cook rom win7 cho e nó đi bác.
hay androi cung dc...nan nỉ bác nun đó
