[TViX 6500A/7000A]: Firmware mới 1.3.132 (Chạy đĩa Blueray BDMV)
oldman61
http://demod.dvico.com/PreRelease/tvix_M-6x00_1.3.132.zip
Supporting HDMV files (UJukebox function)
1. The main feature of this firmware is to select a certain audio track or subtitle out of several sorts of those when playing HDMV structured files stored in the HDD.
2. This version of firmware doesn't support all functions of ‘BDMV’ folder, especially the files with profile 1.1 and 2.0 due to the limitation of the hardware.
3. The folder structure should be the same as the original one, otherwise TViX doesn’t playback your HDMV files properly, protected files and the files with HDMV region code either.
4. The ‘Popup Menu’ when pressing the ‘Menu’ button of the remote control while watching HDMV files is either original graphic menu that the title supports or simple menu that Dvico made.
5. There are two ways to playback HDMV files
A. In case that you set the ‘Smart Navigation’ to ‘Smart’ in the TViX Setup Page, HDMV files automatically playback with selecting the main folder.
B. In case that you set the ‘Smart Navigation’ to ‘Normal’ in the TViX Setup Page, you need to select ‘index.bdmv’ files in the HDMV folder.
6. Possible to add the subtitle that HDMV files doesn't’t have.
A. If you want this additional subtitle to be default one, put the file on the same folder index.bdmv located and name must be ‘index.xxx’, for example, index.smi.
B. Possible to change to the additional subtitle while watching by using the ‘Function’ button on the remote control.
(Như vậy là các bác nào ngày xưa đau đầu với vấn đề phụ đề Việt cho Bluray thì bây giờ có thể an tâm thưởng thức rồi)
7. To change a subtitle language to another one while watching, either press the ‘Menu’ button or the ‘Subtitle’ button on the remote control.
8. To change audio track, press the ‘Audio’ button on the remote control.
9. To go to another chapter, press’ |◀◀’ or ‘▶▶|’ on the remote control or you can press 'Go to' key on the remote.
10. You can use 100 times this version of firmware. The TViX automatically counts down from 100, but it counts one in spite of playing HDMV files 10 times unless you boot the TViX.
*** Possible to play HDMV structured files compressed by ISO format, but you’ve got to select the file even if setting the ‘Smart Navigation’ to ‘Smart’.
Setting the UJukebox Mode in the TViX Setup Page.
1. Set to the ‘Lite’.
Dvico simple menu pops up always.
2. Set to the ‘Basic’
The original graphic menu appears that the title supports. And Dvico simple menu pops up in case of the HDMV files with the menu TVIX don’t support.
HDMV files in IFO folder structure and ISO files.
Most HDMV files stored in IFO folder structure mainly consist of ‘BDMV’ and ‘Certificate’ folder. As explained above, there are two ways to playback the HDMV files, Smart Navigation and selecting index.bdmv. For stable performance, we recommend not to change the folder structure.
Files in ISO format must be selected to be played even if setting ‘Smart Navigation’ to ‘Smart’. ISO files may playback smoothly when played through the network.
Caution.
*** An HD audio receiver and HDMI 1.3 cable are necessary to playback HDMV files.
*** In the TViX Setup page, set the ‘Audio’ to ‘Digital’, ‘HDMI Audio’ to ‘On’, and ‘HD Audio Pass Through’ to ‘On’.
*** It may not work properly in case of no 1.3 HDMI cable, HDMI to DVI connection and analog video mode.
*** Playing HDMV files in public places is strictly prohibited due to the laws and regulations related with license.
*** We recommend to set the ‘Auto Switch’ in the TViX Setup page to either ‘NTSC/1080p24Hz’ or ‘NTSC/PAL/1080p24Hz’, otherwise the resolution of subtitle and menu may not be clear or vivid. It’s one of the hardware limitations.
