* Fixed a bug in the preview area in the Theme Manager.
* Added the ability to set the background of an "upper" toolbar separately from the toolbars that appear near the bottom of the screen.
* Fixed a bug where the close/ok button and window title could be updated for a non-visible window.
* The start menu shortcuts for WisBar actions will now launch WisBar if the program is not already running.
* Fixed a bug where the cascading start menu would disappear when called by a hardware button.
* Fixed the transparency in the skinned volume dialog.
* The "Plugins" settings page now displays "No items in this view" if there are currently no available plugins.
* Fixed a bug where the start menu sounds would play when there were no sounds defined.
* Fixed a bug where program icons would disappear from the running task list.
* WisBar now uses ClearType when the system's ClearType setting is turned on.
* Added an option to hide all of the buttons on an application basis.
* Fixed a bug in the Theme Manager where the pressed state for taskbar buttons couldn't be changed.
