UNLOCK BOOTLOADER - ROOT & CÀI RECOVERY CHO N1
This recovery is for the HTC Nexus One
Features
* full ADB access in recovery mode
* Awesome Care-Bear version! (Blame packetlss for talking me into it ) *NEW in v1.6.0
* Busybox v1.15.3 *NEW in v1.6.0
* Kernel with ext3 + ext4 support *NEW in v1.6.0
* HW-Key navigation (Trackball + Volume-key) option
* Extended menu :
o Reboot system now :: reboot your phone
o USB-MS Toggle :: enable/disable USB mass storage (use when the phone is connected to your PC)
o Backup/Restore
+ Nand backup :: Make a Nand backup, the following partitions are NOT included :
# Recovery (to avoid restoring old version)
# Cache (no need to backup imo)
# Misc (no need to backup imo + restore issues on some phones)
# Splash1+2 (no need to backup imo + restore issues on some phones)
+ Nand + ext backup :: Make a Nand + ext backup *NEW in v1.6.0
+ Nand restore :: Restore a Nand backup
+ BART backup :: Make a BART backup (Nand + ext) *NEW in v1.6.0
+ BART restore :: Restore latest BART backup *NEW in v1.6.0
o Flash zip from sdcard :: Flash a zip update file from your sdcard
o Wipe
+ Wipe data/factory reset :: Wipe /data and /cache
+ Wipe Dalvik-cache :: Wipe Dalvik-cache both on /data and ext *NEW in v1.6.0
+ Wipe SD:ext partition : Wipe the ext partition on your sdcard *NEW in v1.6.0
+ Wipe battery stats : Wipe the battery stats in /data
+ Wipe rotate settings : Wipe the sensor settings in /data
o Partition sdcard
+ Partition SD :: Interactive SD partitioning
+ Repair SD:ext :: Repair the ext partition *NEW in v1.6.0
+ SD:ext2 to ext3 :: Convert ext2 to ext3 *NEW in v1.6.0
+ SD:ext3 to ext4 :: Convert ext3 to ext4 *NEW in v1.6.0
o Other
+ Fix apk uid mismatches :: Does extacly that
+ Move apps+dalv to SD :: Moves all apps and Dalvik-cache to sdcard (This will NOT enable apps2sd!) *NEW in v1.6.0
+ Move recovery.log to SD :: Moves the recovery log file to your sdcard. (Use when you want more detailed recovery log information)
o Power off :: Powers off your phone
* Scripts available via adb :
o Nandroid v2.2.1 : enter "nandroid-mobile.sh" to start.
o BART v1.0.1 (Backup and Restore Tool) : enter "utility" to start. *NEW in v1.6.0
o switchrom.sh V1.1 : enter "switchrom" or "u" to start. *NEW in v1.6.0
o sdparted v0.6 : enter "sdparted" to start.
Change-log:
v1.6.0
* Fixed mkyaffs2image-arm-uclibc which will hopefully fix the "losing root" issues after a nandroid restore (a big thanks to packetlss for the help on this one)
* Updated busybox to v1.5.3
* Recompiled kernel to fully support ext3 and ext4
* Added lots of ext-features + scripts to stop the a2sd nagging
* Created a carebear version after the idea of packetlss. Be aware that this version contains some "ultra-secret" features!
Chi tiết tại đây
Download
Cài đặt:
Chạy file install-recovery-RA-nexus-v1.6.0.bat
bác Quang ơi cho e hỏi, cái driver cài sao vậy, e dow về rồi mà ko bít cài, trình độ IT e hơi kém, PC của e nó ko kết nối dc với con N1 khi vao bootloader...hic
máy mình Vào được chế độ Fastboot thấy có chữ trắng *** UNLOCKED *** trên nền màu đỏ ở trên cùng màn hình tức là máy đã unlock bootloader
nhưng khi Vào dòng RECOVERY thấy hiện ra hình dấu chấm than là sao hả bác quang
Câu trả lời rất đơn giản: Bạn chưa cài thành công RECOVERY !!!
Chưa có Recovery thì sẽ xuất hiện dấu chấm than đấy.
Hiện đã có bản 1.6.0, bạn hãy tải về và cài lại xem sao.
Thường khi kết nối lần đầu máy với PC, nó sẽ đòi bạn cài Driver, khi đó dẫn đường tới thư mục USB_Driver để PC tự tìm và cài Driver cần thiết.
Sau đó thì lần sau sẽ không đòi Driver nữa.
Tại sao bạn nói N1 ko kết nối với PC ở chế độ Bootloader?
Khi kết nối nó chỉ đòi Driver (nếu chưa cài) chứ có kết nối gì đâu???
lần đầu kết nối nó kêu cài UsB driver, luc đó e nhấn bậy bạ gì đó rồi nó qua lun,giờ thì nó ko báo cần driver nữa nhưng mà hình như nó ko nhận N1, mong bác chỉ giúp e...hic,trình độ IT của e kém quá mong bác thông cảm
dạ sẵn cho e hỏi lun,con N1 coi phim định dạng nào vậy bác, và bác có chương trình chuyển phim nào ngon thì cho e xin,và phim định đạng nào là đẹp nhất màn hinh nó 800x480 vậy mình chuyển phim theo 800x480 dc ko,chân thành cám ơn bác
dạ e xem lại rồi, đúng là PC ko nhận N1 trong chế độ fastboot, mà giờ khi cắm vào PC nó ko báo cần driver USB nữa, giờ làm sao cài lại driver vậy bác quang ơi
khi đánh lệnh fastboot devices thì nó báo 'fastboot' í not recognized á an internal ỏ ễtrnal command,oprable progame ỏ batch file
khi đánh lệnh fastboot-windows.ễ oem unlock thì nó báo < waiting for device >
Mong bác hướng dẫn dùm, lần đầu tiên xài android nên e gà quá
Đọc kỹ các bài đầu là chạy được thôi, có 3 chu trình cần làm.
Xem phim trên N1 thì MP4, 3GP hay AVI đều được cả, miễn là cài trình hỗ trợ thích hợp.
kaka cuối cùng cũng unlock dc, nhờ ông anh qua chỉ cài lại driver USB rồi làm theo hướng dẫn thì ok hết, thanks bac Quang nhìu :D
MÁY em vẫn chưa vào được RECOVERY mà giờ thì bị lỗi wifi rồi các bác có cách nào o vậy
Con N1 coi phim định dạng nào vậy bác, và bác có chương trình chuyển phim nào ngon thì cho e xin,và phim định đạng nào là đẹp nhất màn hinh nó 800x480 vậy mình chuyển phim theo 800x480 dc ko,chân thành cám ơn bác
Sẽ giới thiệu chương trình về convert video cho N1 có thể nói là best, có sẵn profile cho N1 luôn.
Chưa vô được Recovery nhưng đã unlock bootloader được chưa? liên hệ wildcathcmc qua skyper sẽ có hướng dẫn trực tuyến :D
Change-log :
v1.6.2
* New unyaffs binary patched by Koushik Dutta and Packetlss to fix the "losing root"-issue and incorrect file-time after a Nandroid restore
v1.6.1
* New dump_image binary (by Brainaid) patched by Packetlss to fix the "bad blocks"- Nandroid restore issue. (This will not fix old corrupted Nandroid backups! Please make new backups!!)
* New mkyaffs2image binary
* New flash_image binary
* Reverted to the old green text color
* Switched the Nexus logo to a Green Carebear with Nexus One logo (Thanks Montalbert!)
v1.6.0
Chi tiết tại đây
Download
Cài đặt:
Chạy file install-recovery-RA-nexus-v1.6.2.bat
cho xin so đt được o bạn mình o có skype
Quan trọng nhất là khi kết nối lần đầu N1 với PC, PC sẽ đòi Driver cài đặt, các bạn phải dẫn đúng đườn link tới thư mục chứa Driver là xong.
Các bước còn lại thực hiện rất đơn giản: Unlock Boot, Recovery và hack ROOT đều thực hiện từ FASTBOOT cả.
cám ơn bác quang và đồng chí Tuấn Anh 0984.033.533 . mình đã thành công và đang up bản benta v10 của bạn. khi nào ra hn alo 0988558830 mình cùng đi uống cafe nhé
Bác Quang và bác TA hướng dẫn cho em chi tiết cách khác phục lỗi của bác nhimyeu với em cũng bị như vậy không có cách nào unlock đc! hic hic
Lỗi của bạn nhimyeu gặp phải chỉ là chưa biết cách cài DRIVER cho PC khi kết nối N1 với PC thôi mà.
Quá trình cài đặt Driver có gì khác đâu, giống hệt như khi các bạn lắp thêm thiết bị mới cho PC.
Khắc phục xong thì mọi việc còn lại rất đơn giản.
Mình Unlock theo như bạn hướng dẫn thì bị mất wifi.Bây giờ làm thế nào đây?hjx
