Superrom_1.1WWE
- OS 2.26.10.2 with aku 2.3 (we think that is still better then 3.2)
- GSM 2.25.11 (TỐT HƠN RADIO 2.47.11)
- HTC logo (surprise)
- Splash screen (Windows mobile loading...)
- ExtROM (many things unusuall things)
- IPL/SPL - not included
IN ROM
- Program to browse contacts via Bluetooth
- Total commander
- OmapClock
- ScreenOff
- WM5torage 1.73
- Smartskey
- Default vlack theme
- Dialer vista skin by jimm98y with T9 and big buttons
Skin for WMP ala WMP 11 by Xcilion (my rebuild)
- Voice speed dial settings
- HTC X-button
- Soft key applet
- Many registry tweaks (only universal)
- Cleartype by default
- deleted much unusable things
- Camera patch
- Removed green battery
- Removed MSN
IN EXTENDED ROM
Automatic
- Midlet manager (big program - if you do NOT need it - skip install and install extROM manually)
- CAB, that shows version of extROM
- Setup MMS folder
SMS delivery fix (fix of non-shows names on SMS delivery) SOFT NÀY KẾT HỢP VỚI DỊCH VỤ THÔNG BÁO CUỘC GỌI NHỠ CỦA MOBI,VINA,VIETTEL THÌ RẤT TUYỆT
Manually
(in that section there are programs, what you can manually install from the
shortcut in Start/programs/Install)
- Batti 2.1 (CZech program by "David Andrš" to show battery in upper taskbar - now fixed to english version)
- Wifi g enable (cab with one register to quick enable/disable by uninstall
wi-fi b/g)
- Mchat2.1b (icq client)
- .NET cf2
TCPMP with all plugins included AAC
Windows live messenger
- And configuration cabs to Czech Republic GPRS, but you don´t mind them
All packed to
- 45 MB free ROM (before customization)
- 42.3 MB free ROM (after customization)
- 32.2 MB RAM (always)
TRONG ROM SET CPU :252MHz CÁC BẠN NÊN CHỈNH LẠI 180 MHz THUI
http://fenix.metronet.cz/johnny/download/ppctuning.org_Superrom_1.1WWE.exe
