V3 -thingonaspring.5.2.1933.18533.REALVGA
linhlk
thingonaspring release v3, các bạn cùng test nhé=D>
New RealVGA ROM Based on 5.2.1933-18533_070
New for v3
- A2DP works nicely
- Boot registry heavily modified and stripped down
- Rebuilt driver set (modular where possible, favouring the faster drivers)
- Rebuilt basic apps (contol panels, camera, media support)
many DLLs updated, many dud files removed
- Startup splash and other GFX optimised for size and speed
- HTC storage manager control panel ripped from JWrightmcps
select SD or SDHC card support
- Better caching of imgfs blocks - faster
- VijayCandellaLite by Vijay555
press the lightbulb button and use the phone as a flashlight
- New black theme
- HTC Network Plugin - mount shared drives over network
- Camera memory bug fix by JWrightmcps
prevents camera use when mem <10mb
This version comes in 2 packs. There's a "Standard" ROM, and a kitchen.
This time the kitchen also comes with a load of optional modules so you can build in the features you want.
OEM Packages in the "Standard" ROM
- Arcsoft MMS - MMS support
- Black Theme - Menubars and backgrounds black
- GSPlayer - High quality MP3 player
- Network Plugin - mount windows shares
- Network Wizard - sets up your phone for your phone operators network
- HTC Storage Settings - choose SD or SDHC driver, export SD over USB
if your card does not mount on 1st boot, change drivers in the control panel and reboot
- GoogleMaps
- PIMBackup - backup contact, email, calendar...
- SMSBackup - backup SMS messages
- PocketNotepad - text editor
- VOIP - a rehash of the default MS Voip stack using Schnapp's VOIPSetup
- PocketRAR - archiver
- RealVGA - switch DPI
- TaskMgr - edit registry, view admin info about tasks, services etc
- TCPMP 0.81 - movie player
- TotalCommander2 - file manager
- VijayCandella
use the phone's camera light as a flashlight - press the lightbulb button
- XPDF - view PDF docs
Optional OEM Packages in the Kitchen
- All the above
- Alternative SDIO driver
FAST SD support, Shaky SDHC support
Replaces the HTC_Storage_settings package
- USB HDD
export SD card as USB disk, useful when using the fast SD card driver
- FlashPlugin
play flash SWF files in IE.
- MSVoicecommand
voice control for you phone
- PBar
NNCoung's task/connection/memory/battery monitor/controller. It rocks.
- Performance - control panel to overclock your system.
- HTCHome Plugin - launch apps from the today screen
- BT Stowaway Mouse/keyboard support
- BT FTP support
- BT SIM support
- Screen rotation service - icon on today screen
- Wireless Manager Service
- Streaming video - play some RTSP content
- Symbol Pad
- HTC Task Manager - similar to pbar, but not as nice IMHO
- WMP Today plugin
- HTC Zip - archive manager
- HTC Comm Manager - nicer comm manager, only good for 192DPI
Optional SYS Packages in the kitchen
- Some aspects of the OS are removed from the "standard" ROM, but can be reinstated in the kitchen
- windows update/marketplace
- transcriber
- customer feedback
- entertainment (bubblebreaker and solitare)
- Original MS VOIP package - replaces my one
link down:
Mình cũng không down được từ rapidsare, bạn vui lòng up lên host khác nhé !Thanks
Important notes :
Before flashing ANY 5.2.19xx-based ROM your phone should be fully unlocked and SuperCID, otherwise it may lock up or crash randomly.
theo như dòng trên thì Mình thấy tác giả khuyên mọi người unlocked và SuperCID trước khi up Rom này để tránh crask.
bản này sao ko thấy có boot image và màn hình lúc mới vô xám xịt ..Nhưng đc cái chạy rất ngon .Có cái VGA gì đó ko bít để làm gì
bản này còn bị lỗi Backlight nữa ...nếu ko cắm sạc là màn hình ko sáng đc hic hic..Chạy thì nhanh nhưng lỗi gì từa lưa
Mình đã dùng thử bản ROM này, có một số nhận xét:
- Tốc độ nhanh, bộ nhớ nhiều
- Phần mềm tích hợp đều là những phần mềm cần thiết (tuy nhiên version hơi cũ: PIM Backup v1.19, Pocket RAR 3.60, Total Commnader 2.0..)
- Không có Storage clean nên cũng hơi bất tiện khi muốn format)
Nhìn chung đây là bản ROM dùng được...
Hi, Thingonaspring vừa cho ra bản Rom mới có Version là 3.1, không biết có gì mới hơn không, xem giao diện qua ảnh minh hoạ thì thấy cũng được, cũng muốn thử nhưng DL mãi không được, có bạn nào DL được, up thử thì cho ý kiến xem.
V3.1 - thingonaspring.5.2.1933.18533.REALVGA
New for v3.1
- Faster display driver for more responsive UI
- Faster WLan driver
- PIMbackup 1.9 and SMSBackup replaced with PIMBackup2.50
- OLECE300.dll added to the rom, fixes some 3rd paty apps like isilo
- A few small tweaks to power management
- Better BTFTP package ripped from Ivan's ROM
- HTC Home today plugin - multi-function today plugin ripped from Kaiser and modded to store its icons+resources in ROM instead of storage.
V3.1 Kitchen is here, extract it to C:\ :-
http://rapidshare.com/files/75441228/1933.18533_Thingonaspring-kitchen.v3.1.7z.html
Hôm nay mình đã down lại được từ Rapid rồi, để mình tải về rồi up lên host khác cho mọi người cùng test bản Rom này nha !
maý mình chưa uncloc liêụ có bị gì ko nhỉ. cho mình vài lời tham khảo với.
New for v3.1
:D :D :D
mình vừa up xong nè, bạn tải về đi nha ! =)) =)) =))
http://www.4shared.com/file/31682359/33cf1ccd/193318533_Thingonaspring-kitchenv31.html
Tác giả khuyến cáo không UP bản 3.1 này, có thể die Uni đó!
thingonaspring nói:
Warning - I just woke up to find my UNI dead - white screen.
The screen remains blank even in bootloader mode - NOT GOOD.
I have no idea what the cause is, but until I have more clues - DO NOT USE v3.1. If it's the cause of the failure I do not want to break your UNI too.
DO NOT USE V3.1
Tôi vừa kiểm tra lại, thấy tác giả đính chính lại thế này:
This will give you a laugh
I have found the cause of my dead UNI.
The cause was not 3.1.
The cause was my girlfriend :)
She tried to use the phone to make a call, but rotated the screen in the wrong direction, grinding plastic and contacts all the way round.
The uni now works again (with a wobbly screen).
Chắc là không có vấn đề gì đâu.
Kì vậy ta? sao một chủ đề lại có 2 ý kiến trái ngược nhau vậy, uni chỉ có 1 nếu có chuyện gì là khổ lắm đây. Có bác nào úp rồi cho em biết với
Tôi tải bản này về, giải nén bằng Soft 7zip theo yeu cầu nhưng thấy lạ là ra một loạt thứ của các chuyên gia build Rom thì phải còn file nf thì không tìm đâu ra cả, có bạn nào bị tương tự không? Các file như sau:
OEM
OEM_Options
ROM
SYS
SYS_Options
TOOLS
1_Reloc
2_buildOS
3_buildROM
pkgcommon.dll
Tại chủ của Topic lúc giới thiệu đã đưa link nhưng lại...nhầm! Các bản của thingonaspring thường có 2 link: 1 là link ROM và 2 là link KITCHEN để ai có nhu cầu có thể tham khảo và build lại theo ý mình, cái mà bạn down là kitchen đó! =))
Tác giả cũng vừa ra tiếp bản 3.11 đó:
thingonaspring nói:
New for 3.11
- Fixed GPRS, that was an embarrasing bug, apologies to all.
- Made ALLEDMgr.dll and NLEDDrv.dll modular - I've been trying to do this for a while, but couldn't seem to find the right modular drivers. Today it suddenly works.
Ai có nhu cầu có thể down và UP thử! :-?
Link ROM: http://rapidshare.com/files/75602077/1933.18533_Thingonaspring.ROM.v3.11.7z.html
Link Kitchen: http://rapidshare.com/files/75605374/1933.18533_Thingonaspring-kitchen.v3.11.7z.html
Nhìn kỹ kẻo lại down nhầm! :p
Một vài nhận xét sau khi dùng thử bản này:
- Extended_Rom (Storage) không còn hiện diện nữa, tác giả hình như đã cố tình không chia bộ nhớ của máy ra làm nhiều ổ đĩa nữa. Trên máy chỉ hiện diện Main mamory và Storage card thôi. Đây cũ là cái mới và khác các bản rom hiện hành.
- Sau khi cài rất nhiều các phần mềm thì Bộ nhớ còn tương đối lớn (22,22m và 25, 26m) có tụt giảm nhưng tương đối bền.
- Không có chỗ để chỉnh đèn ngầm của bàn phím cứng (Đây là cái dở nhất của Rom này).
- Sau khi HR Rom đã bỏ đi một số bước như: đặt múi giờ, chỉnh ngày, tháng giảm thời gian set up cũng là cái hay (nhận xét cá nhân).
- Còn lại mọi thứ bình thường.
tác giả mới ra bản 3.2
NEW VERSION 3.2 thingonaspring.5.2.1933.18533.REALVGA
New for 3.2
- Call answering stability fixed
- Speakerphone fixed
- SD/SDHC Driver unified. Fast and compatible SD drivers now merged into one driver. Note that SDHC is the default so if your card does not detect on first boot, then change to the "standard" driver and reboot.
- Performance application added to settings tab. Allows you to over/underclock your device. Default is all clock management disabled.
Important notes :-
Beasty has informed me that using the flash bulb for long periods can cause the thing to burn out - so please only use candella for short periods. If you're really worried about it, disable the lightbulb key under "settings -> buttons" and assign it to some other function or <NONE>.
tác giả khuyên rằng trước khi up các bản ROM 5.2.19xx thì phải unlocked and SuperCID,
Here's the v3.2 ROM (please mirror it if you can) :-
ROM3.2
http://rapidshare.com/files/75917173...M.v3.2.7z.html
V3.2 Kitchen is here, extract it to C:\ :-
http://rapidshare.com/files/75922026...n.v3.2.7z.html
Note that both are compressed with 7-ZIP www.7zip.org. It's way more efficient than ZIP and it's free.
__________________
