VHome - Đổi giao diện điện thoại PRO!! ( Bản v3.95 CN 8/9/2010)
Voyager Home Screen (vHome) v3.73a S60v3 Symbian 9.x Unsigned EN
Voyager Home Screen (vHome) is a free ware helps you customize your S60's home screen with big clock, start menu, weather, news ticker, Google, fav contact, smart dialing, etc.
Key features:
Features like Google, weather, news, Operator logo, big clock are pretty straight forward, if you do not like a certain feature, just press C to disable it. Press left/right on to-do bar and news bar could switch item.
Quick task switch: we use the red end key to switch between running tasks, it's lot easier than pressing home key and then select, also you will never quit java apps like Opera Mini/Gmail by accidentally pressing Red key.
Smart dialing: just type one number for one letter, to find any contact fast. Like 2455 for Bill. You can use this for apps, too. Like 46245 for Gmail. You might find phone's menu a bit useless when you can get to anything from home screen with smart dialing.
Start menu: another way to organize your apps, you can locate an app using smart dialing, and place the app in start menu or home screen shortcut easily. And we support sub-folder in start menu.
MyFav: we scan your call logs automatically and place the people you call/text most frequently in MyFav feature, on the home screen's right selection key (of course you can change this with any app you want). Press left/right key in this, you can see your most used apps, too.
vApps: yeah, we include a mini App store, the seventh shortcut. Not too many apps for now (tell us what you want to see here), we want to gather the best free apps here, all fit your phone model (we test and organize them by screen resolution, MR/FP1/FP2 etc., so you don't have to). Just one click to download, auto install to E:, dead simple. (the list is updated automatically, so check in once in a while).
New app popup: after a new app is installed, you would see a popup asking if you would like to run it now. Save you time digging in to menu to find it.
Web directory: Click web browser, you'll see our directory page. All most popular mobile sites (hopefully). If you don't like it, just turn it off in Start-Settings-More
Keypad Lock: sorry the system's settings would not work, please setup again in vHome. Lock is easy: Start-Lock, much better than old way. Press end key twice to unlock.
Connection: by default, vHome update weather/news each hour, 9:00-23:00 (no update if you disable news and weather), change this in Start-Settings-Connection to suit your needs.
What's new:
0. You can now send twitter from vHome
1. On fp2 models, screen will not flick after quit menu
2. Data counter feature in Start-More
3. vHome now automatically connect to WiFi first
4. Now displays USB indicator
5. Now N95-8G/N96 displays left/right selection key
6. Support left+right selection to lock keypad
7. Support BT key and profile key on E72
8. Support 5730/E75
9. Added vNewsReader for home screen news, it's basically system
browser with page up/down feature. just press 4/6, space or volume key
to turn pages
10. Many other small fixes, updates​
Voyager Home Screen (vHome) v3.73b S60v3 Symbian 9.x Unsigned EN [Update: 28.06.10]
Phần mềm dổi giao diện màn hình chính này đổi luôn tục
Key features:
Keypad Lock: the system's settings would not work, please setup again in vHome. Lock is easy: Start-Lock, much better than old way. Press end key twice to unlock.
What's new:
1.Bug fix: Switch between landscape and portrait mode might cause crash
2.Bug fix: weather icon displays wrong some time( the noon icon)
3.Bug fix: sharing article using vNewsReader might cause crash
4.Several other small fixes
We said we will speed up, and we do mean it expect Facebook feature coming in days!
Link box.net
Link tổng hợp
Doi viet hoa,hay ban en thoi. Man hinh ngang nen Minh ket cai thang nay lam hehe
Chú ý viết bài bằng tiếng Việt có dấu đầy đủ.
Voyager Home Screen (vHome) v3.76a p189 S60v3 SymbianOS9.x Signed Chinese
Voyager Home Screen(vHome) is a FREE ware helps you customize your S60's home screen with big clock, start menu, weather, news ticker,Google,fav contact,smart dialing ,etc.
Features:
Features like Google, weather, news , Operator logo, big clock are pretty straight forward, if you do not like a certain feature, just press C to disable it.press left/right on to-do bar and news bar could switch item.
Quick task switch: we use the red end key to switch between running tasks,it's lot easier than pressing home key and then select, also you will never quit java apps like Opera Mini/Gmail by accidentally pressing red key.
Smart dialing: just type one number for one letter , to find any contact fast.Like 2455 for Bill. You can use this for apps,too. Like 46245 for Gmail. You might find phone's menu a bit useless when you can get to anything from home screen with smart dialing.
MyFav: we scan your call logs automatically. and place the people you call/text most frequently in MyFav feature, on the home screen's right selection key.(of course you can change this with any app you want).press left/right key in this, you can see your most used apps,too.
vApps: yeah, we include a mini app store , the seventh shortcut. not too many apps for now(tell us what you want to see here), we want to gather the best free apps here, all fit your phone model(we test and organize them by screen resolution, mr/fp1/fp2 etc, so you don't have to).just one click to download, auto install to E: , dead simple.(the list is updated automatically , so check in once in a while).
New app popup: after a new app is installed, you would see a popup asking if you would like to run it now. save you time digging in to menu to find it.
Web directory: Click web browser, you'll see our directory page. all most popular mobile sites(hopefully). If you don't like it, just turn it off in Start-Settings-More
Keypad Lock: the system's settings would not work, please setup again in vHome.Lock is easy: Start-Lock, much better than old way. Press end key twice to unlock.
Connection: by default,vHome update weather/news each hour, 9:00-23:00 (no update if you disable news and weather), change this in Start-Settings-Connection to suit your needs.
Link box.net
Link tổng hợp
Voyager Home Screen (vHome) v3.77b [CN] S60v3 SymbianOS 9.x Unsigned
Screenshot from Previous Version
Features:
Keypad Lock: sorry the system's settings would not work, please setup again in vHome.Lock is easy: Start-Lock, much better than old way. Press end key twice to unlock.
Change Log :
Change log not available
Voyager Home Screen (vHome) v3.78a signed version released ENG
Phiên bản mới cho VHome .Và dự báo thời tiết đã quay trở lại
Cho em hỏi làm sao mà em cài xong cái đồng hồ của em nó không hiện giống như trên hình được. Em muốn nó hiển thị giờ theo kiểu Am Pm, nhưng khi chọn được kiểu am pm thì nó lại có chữ số xấu hoắc như là chữ số trong mấy cái calculator Cásio ấy. Ai biết có thể chỉ được không?
Em muốn hiển thị đồng hồ theo kiểu AM PM với phông chữ như hình vậy. Thanks
Copy file Clock có thể tìm thấy trong diễn đàn vào
Rồi bạn tha hồ tìm..hình như có 30 loại clock cho bạn chọn đấy
font chữ thì bạn hỏi bạn ý xem
mình đã chép file trong clock rùi nhưng không có như hình....
Help me pls
