Windows Mobile 6.5 21159 Testing 02/12/09
hix, up giùm bạn mà nó cứ đề 100%. checking file...... chờ mãi=>póttay lluôn
joshkoss! what's happening to this project???
Hello joshkoss,
I have noticed that the last time you updated this ROM was on Mar 10, it's almost a month passed but did not see anything new on this one.
Is it in the back burner now or are you just busy? Wish to hear from you!
Cheers,
Hello joshkoss,
Cheers,
Sorry Man, I've bought a kaiser and have been building kaiser roms now.. that said today I did finish a 21198 build for hermes and will update post 1 with it momentarily.
Thanks BassPlaya for the pics!!!
Glad to hear from you (sure many here are too!)
You are building Kaiser's ROM now, is that mean Hermes will be "lame"?
i have a question when you will built 21202 for hermes, we are appriciated for your room, it really good=D>
still can NOT install any other keyboard softwares, that a huge bugs man !!!!
I will have a cleaned light version out tonight.. i'll update the post with it then :) try that one.. it's based on a lot cleaner oem and will probably fix that issue.b-)
