WM 6.5 21806 WWE/FR
rontre1
WM6.5 5.2.23001 (Build 23001 FB)10E WWE Clean
http://www.mediafire.com/ks20 :)
Rom information:
2009/06/08
KS20 WM6.5 CE OS 5.2.21806 (Build 21806 FB)10E WWE/FR Clean
Change log:
-build update from 21234 to 21806. Old issues still remain.
-Driver upgrade From 10D to 10E
Guys, Spocky found something about the driver reload issue. Apparently it's a 3G issue, so the trick is to change the bandwitch setting in phone settings from automatic to GSM 900/1800. Basically your phone will now only be connected to 2G, and GSM reloads should be over. But this also means you'll need to turn this setting back to automatic to be able to run apps that need faster connection (3G,3G+). This is temporary and I'm sure by the time I'm writing this, Spocky has almost found out a definitive patch that he'll release within his forthcoming 6.1/6.5 roms (raising the pressure, mate ^_^)
Programs:
-Office 6.1 (word,ppt,excel)
-OPAL_TaskManager_2_1_34837_5
-NetCF3.5
-WOW HD
-Pim Backup
-start menu in 3 rows without honeycombs
Fixed:
-First boot issue fixed. calibration comes first and when done, initapp starts.
-internet key is fixed (relinked)
-camera and Sim issues fixed and verified
-IE8 back
-Simtoolkit added for dual Sim support
-SIP change is working (tested with Resco keyboard)
-UC compliancy enabled: Procedure:
-1.put all your cabs in a folder named "Cabs" in the root of your SD card,
-2.use "SDConfig_Builder" in Spocky's Kitchen to create a working "SDConfig.txt" that you'll save in the root of your SD card,
-3.click on the "SDAutoRun shortcut" in Start Menu > System
-4.when procdure is done, Soft Reset your phone.
Tips:
-To see pictures located on SD card directly from Titanium menu, put them in a folder entitled "pictures".
-to uncheck titanium go to Start>settings>today>items and uncheck "windows default".
Good news:
-Camera 100% working
-SDHC support
-SIP changing ok
Các pác tự dịch nhá ^^:p
có ai thử chưa zậy?Cho ý kiến nha...ko biết thời gian sử dụng là bao lâu nữa...khi up con Rom này.
bận quá chưa có thời gian thử, mình cóp bên forum XDA. Ai thử rồi cho tham khảo ý kiến với.
Vừa cập thêm bản Build 21820 FB.
mình mới up ROM Build 21820 .pin duoc 2 ngay,ram 36mb, mọi thứ hoàn hảo, cảm ứng ngon ,có 1 điều ko hài lòng duy nhât là nó cứ báo PIN sắp hết. :((
cám ơn ý kiến đóng góp của bạn.
Update thêm bản 23001. Chưa thử, chờ tin ae :|
Mình mới vừa up ROM Build 23003 WWE vào tối hôm qua, chạy mượt mà, giao diện đẹp, mọi thứ good !
thế à, bản của mình up build 23001, pin chỉ đc có 2 ngày, cứ báo hết pin hoài.
bản 23003 có những lỗi đó ko bạn.
mình up xong,xài thử thì thấy 99% ok,chỉ có cái tôi là nhận thẻ chập chờn:(
làm gì có vụ nhận thẻ chập chờn bạn. khi tắt màn hình thì máy cũng nghỉ lun, ko nhận thẻ nhớ, bật lên thì mới load lại. wm version nào cũng vậy thui.
mình up xong, 99% ok, nhưng khi khởi động hay có câu "backup battery very low" mặc dù pin còn phân nửa
LỖI CHUNG CỦA BẢN ROM 6.5
Tui đã up nhiều bản rom 6.5 cho ks20 nhưng tui thấy lỗi dò sóng sau khi để đt stanby khoảng 30 phút làm tui rất bực mình, nhiều khi ngta gọi cho mình mà tới hồi chuông thứ 3, thứ 4 mình mới biết là có cuộc gọi đến.
Không biết ai có cao kiến gì không nhỉ???
tui vẫn xài 6.0 nguyên gốc. kệ nó ko bằng a bằng e mà chắc hix. vì bit con này ko do HTC sản xuất mu lị
bên LG ko biết cái bộ phận nâng cấp phần mềm có thường xuyên cải tiến hem nữa.Đợi thêm thôi.^^.
Tôi đồng tình với bác SUMCAT. Ban đầu dùng bản 6.0 của Pháp rồi chuyển qua Tiéng Anh. Giờ vẫn ổn định lại đẹp nữa.Hihi
