WM6.1 ROM - PROPHET CE OS 5.2.20769 (Build 20769.1.4.5 PV)
Sonblack
Super V.I.P
PROPHET MANILA V2.5
===== Core 5.2.20769 Build 20769.1.4.5 PV =====
Lời cám ơn - Thanks:
Super Mod PhamQuang
Super Mod BatKid
Admin Kawaguchi
Adv. Mod Dvha79_ddt
Mod Lamson, TranMinhMan, Hoangdat_vista
Trial Mod PhamNhatThanh, khacduy1978, nhattoai
VIP Medkid, nhocbanme
herg62123, poorlyduck from xda-developers
Thông tin ROM - Information:
- Core 5.2.20769 Build 20769.1.4.5 PV
- ROM Version: 2.20.8.50 WWE
- ROM Date: 7/12/08
- Transcriber included.
- Manilla 2D with Blue Skin also included.
- XIP & SYS from latest original ROM for Touch HD.
- Compress "LZX" standard.
- No bigstorage.
Hình minh họa - Illustrative Images:
Các chức năng chính - Main Functions:
- CE OS 5.2.20769 Build 20769.1.4.5 PV
- Internet Explorer 6 for Windows Mobile
- AudioManager v2.0 Build 1820.1321 (Elfin)
- JBlend Java v3.3.5 Build 20081015.1.1 (Jade)
- Outlook Enhancement (Elfin)
- Picture Enhancement (Elfin)
- Comm Manager v2.7.2.8
- ArcsoftMMS v5.0.31.63 (Elfin)
- Enlarge Start Menu (Moderate from Elfin)
- Enlarge TitleBar (Elfin)
- Manila2D from Elfin (Moderate)
- HTC Sim Manager for Pocket PC v6.58
- .NET Compact Framework 3.5.7283.0
- Windows Media Player 10.3 Build 20769
- Office Mobile 6.1
- HTC Album (Moderate from Elfin)
- SIPChange (automatically run)
- Advanced Configuration Tool v3.3 by Schap
- Pocket RAR v3.80 by Alexander Roshal
- ClearTemp v1.1 by Vicott Wong
- PIM Backup v2.8.0.0 by FdcSoft
- Pocket Screen v1.3 by JJM. Roseboom
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.2.0.0 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
Link tải ROM - Download link:
Link đã có sẵn - The link is available now
Link nằm trong file đính kèm ở cuối bài - Link put under attached file at the end of this post
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download ROM, the members use both Username and Password are PDAVIET
Giải nén file ROM với password:
SONBLACK
Uncompress ROM file with password: SONBLACK
Máy của bạn cần được HardSPL trước khi Up ROM này!!!
Your PPC has to HardSPL before flashing this ROM!!!
Sonblack
Cuối cùng thì mong đợi cũng đã thành hiện thực.
Cảm ơn bác Sonblack nhiều nhiều!
Em đã up và đang test.
Nhưng khi up có vấn đề là cứ đến 83% thì nó báo đỏ và dừng lại rất lâu mới chạy tiếp.
Em cứ tướng làm sao định rút cáp ra.
Các bạn lưu ý nhé!
Các bạn lưu ý nhé!
Bản này có đưa một số ứng dụng vào trogn Ext_ROM , thường bản ROM có Ext_ROM thường đến khoảng 79-85% nó hơi lâu một chút
nhìn cái lít Soft tích hợp vào Rom của bác Sơn mà hoa cả mắt!!! hì
ko bik nặng nhẹ ra sao nhưng trước hết lấy cáp ra nào....b-)
em đã chạy thử thanks bác nhiều chạy rất nuột. Giao diện đẹp thôi rồi cảm ơn bác nhiều.
cầu trời prophet của tui hư để ông Sơn làm rom diamon =)) hối hận khi bán prophet wóa :| bít zậy để lại uprom của anh Sơn già :p
Muốn dành lời chúc mừng đến cao thủ Sonblack vào đúng giây phút giao thừa.Chúc mừng anh em Prophet có thêm một phong cách ROM mới.Chúc mừng Sonblack.
thank mod alot . sẳn mod cho em xin hỏi sau khi hardSPL xong mình up rom có phân biệt rom G3 với G4 ko? nếu phân biệt thì làm sao biết được rom của G3 & G4. em ko biết mong mod giúp đỡ ;;)
Mình dùng thử bản rom này và thấy lỗi nhỏ là sau một thời gian thì thẻ nhớ không nhận. Phải rút ra cắm lại ai có gặp trường hợp như mình không?
*Lúc nào cũng phải để ý tới G3 & G4.
* Khi Hard SPL nhận biêt G3 & G4 như thế nào thì vẫn vậy khi PPC boot nhìn màn hình thấy IPL/SPL 2.xxxx0 là G3, IPL/SPL 2.xxxx1 là G4. Nếu HardSPL rồi thì thấy SPL 2.G3.4PDA & SPL 2.G4.4DPA
Dear Mr. Sonblack....
Can I edited this rom for my tailor made rom version? :)
thanks a lot :)
Lâu quá không vào khu vực Prophet vì con Qtek bán mất rùi :((.
Hôm nay lại thấy bản ROM mới của pác SonBlack, hoan hô pác SonBlack đã trở lại với Prophet =D>
Tất cả đều mượt tuyệt vời, màu xanh chủ đạo theo phong cách WM7, wifi/gprs/bluetooth đều ok, chưa phát hiện ra lỗi gì sau 1 tuần test. Tuy nhiên có 1 vấn đề nhỏ là thỉnh thoảng bị mất keyboard như khi kích hoạt ctr SMS Security trong TouchFLO (h.1), phải vào Program chạy ctr để keyboard hiện ra (h.2), sau đó quay lại màn hình TouchFLO thì mọi chuyển ok (h.3). Có thể do đụng phần mềm chăng:-?? AE có ai bị giống mình ko?
Bản này mượt, đã test từ hôm qua, hết 2 cục "bin" chưa thấy gì bất thường!
TKS
Em vẫn bị vấn đề về thẻ nhớ có phải tại thẻ đểu không bạn ơi. Tiện mọi người tư vấn cho mình cái thẻ phù hợp với em Neo. Loại nào thì được 1Gh hay 2Gh và của hãng nào nhé. Thanks all
