WM6.1 Slim Edition v3.0 - BUILD 19400 UPDATE(24/04/08)
binhlerhm
A no-frills and stable WM6.1 for the Wizard with basic applications. Built off the new 19400 build circulating around. Extremely stable and uber-fast!
ALPHA RELEASE [V3.0]! New build!.Entirely new XIP/ SYS sections
Application List:
Core OS build: 19400
Sys section: 19199 AKU 1.0
* HTC Album
* HTC Camera
* Total Commander CE
* BT Explorer
* WiFiFoFum
* Office 2007 + OneNote
* Touch Dialer
* Touch Duo Commmgr
* Alt-Tab + Smartskey
* DotFred TaskMgr
* PocketXpdf
* NetworkWizard
* HTC AudioManager
* Btcrawler
* Bug Fixes + Annoyance removal
* Minimal footprint!
* Incorporated my own Calibri fixes..it looks great!
* WLAN G-Mode enabled!
* Touch Scroll only (cube sucks up ton of space)
* Arcsoft MMS 4.02
ISSUES:
* MMS Fix! http://ifile.it/unxmrv8
* Reverting back to Tahoma fix below.
* Disable Threaded SMS without losing notifications
OS only! No EXTROM/IPL/SPL included!
-It is slightly smaller than other RUUs, but it works, trust me.
---Slim v3.0-------------------------------------
Entirely new build, so version number is incremented. Will post screenshots at some point.
+New XIP/SYS sections
+Some new rebased drivers
link rapidshare + ifile.it
[HIDE="http://pdaviet.com/showthread.php?do=post_thanks_add&p=294762"] http://rapidshare.com/files/110080618/Slim_v3.0a.rar.html
http://ifile.it/4mjfrge[/HIDE]
đang down về test thử.hiih.ko hiểu sao máy mình ko Syns contact với PC đc.Ko bít bị lỗi gì nữa.
Thanks bạn nhìu
* Sao AudioManager không phát được nhạc. Mỗi lần play là nó báo thiếu bộ nhớ ?
Mặc dù tui đã tắt hết các chương trình khác.
Nếu dùng WM10 để chơi thì không sao !
* Trong setting có TouchFlo, nhưng không sử dụng được.
Bác nào biết xin được chỉ giáo. :)
