WM6.5 ROM V03 (Core 21202) - LG KS20
PhamQuang
Manager
ROM WM6.5 V03 - LG KS20
=== CE OS 5.2.21202 Build 21202.5.0.0 ===
Phiên bản ROM WM6.5 V03 dành cho LG KS20:
- Phát triển và chỉnh sửa phiên bản V01 & V02 đã giới thiệu.
- Thay đổi XIP và SYS từ WM6.5 (Core 21202) được sưu tầm từ XBETA.
- ROM có thể coi là hoàn toàn Clean.
Phiên bản V03 được phát triển trên cơ sở V02 với sự thay đổi Build mới cho nên hệ thống chạy nhẹ nhàng, mượt mà hơn. Các chức năng cơ bản hoạt động bình thường.
LINK TẢI ROM V03 (KS20):
* RapidShare:
Mã:
http://rapidshare.com/files/218201462/LG-KS20__WM6.5__V03__B21202.rar
Mã:
[I]Pass.: [COLOR="Silver"]PhamQuang[/COLOR][/I]
First to flash :)
Still pb with:
- lgcamera.exe the file from the kis20.4 not replaced so we can take a photo
- no sdhc support included
- wait cursor bigger than in v01 like in v02
- the wallpaper (fixed with another wm6.5 tsk qvga)
- icones on the start menu are too large and it is not clear pixel (fixed with http://forum.xda-developers.com/showthread.php?t=498936)
- keyboard impossible to put another input
- battery warning
i continu to test it ;)
NEW pb : the led blink in blue every +- 5 sec without reason i haven t íntall anything ...
ty
is this Firmware faster than the others ?
real good work!! better than all other 6.5 bulds! i like them!
THANKS!!!
good work bro. Just need to solve the battery problem and lg camera + several icon issiues and the keyboard problem. I think that it's going to the best rom for ks20 based on wm6.5 ever... ;)
Thanks! UIs and Applications are work very well, but keyboard and power loss about 10% per hour are the main problem in this release.:-?
The battery draining speed is monstrous... Too bad. Going back to KisS... But still waiting for a future release of wm6.5
Yes i confirm pb with battery draining and maybe linked to the blue led blinking every 5 seconde ... maybe ok in v04 bd 21500 :D
confirm it s linked to the wifi driver
Spb keyboard can work well in this wm6.5. Camera problem can be fixed by replacing the proper camera.exe. But tremendous battery loss is still inveterate. zzz.
PhamQuang are you planning to work on this rom trying to repair those problems? Or the beta wm 6.5 still makes it unrepairable??
Hi,
Âfter flashing with this rome this is not working:
Port Setting → 1. Diag Setting → 1. USB Set for Diag → “OK” → “Back”.
(Port Setting → 1. Diag Setting →) 2. USB Switching → “LG Composite -DUN, DIAG”.
Any idea how to fix this??
Thank you
This is one of the poblems in this rom. The only way is to flash it back to previous rom by setting emergency mode and after flashing change port setting again and restore nv2...
Các bác cho em hỏi sau khi uprom WM6.5 thi không có sóng (ban đầu có sóng),check lại thì IMEI NO ACTIVE_, bluetooth NO ACTIVE_...có cách nào khắc phục không các bác ?
Trường hợp của bạn là do sau khi Up rom máy chưa được Restore NV2 nên không có sóng và Imei, bạn cần Up lại Rom ở chế độ E-mode và sau đó Restore NV2 cho máy!
