[WM6] XDA Mobile 6 ROM
support
Lõi cơ bản :
* Windows Mobile 6, OS 5.2.318 Build 15342.4.0.01
* ROM Version: 10.1.0.811 WWE
* ROM Date: 08/11/06
* Protocol: 4.1.13.09
* ExtROM version: Faria V5.0
Software
* Office 2007
* New 8 Button CommManager (yeah only 8 buttons. If you want more then install one of the many 10 or more button ones )
* Transcriber
* VoIP (See next post for instructions to set this up)
* SQLCE
* mUn designed onscreen Keyboard
* HTC X-Button v1.0 (The new 1.5 version has issues with impacting changes on the Today screen so I'm staying with v1.0) and turned on by default
* Mobile Justice (a security app that will send an SMS if an unauthorized SIM is placed in your phone)
* TodayAgenda
* Notepad editor
* Pocket RAR
* SIP Config 2.0.1
* StartClean
* Pocket Screen Capture
* HTC Audio Manager
* CicleBT (Toggle BlueTooth on and off)
* SynchroTime
* 1-Calc Lite
* Total Commander Beta 2.5
* WiFiFoFum 2.2.9
* PIM Backup to 1.9
* Windows Live Search searches via Google
* MoDaCo NoData (so you can turn off data sources)
* WM5torage 1.73
* dotFred TaskManager (with registry editor link)
* Smartskey 0.56 (DPAD is set to 0 in the .ini so the up and down scrolling works in the Phone dialer as expected in WM6)
* SIM Manager
* WM5NewMenu
* SMSDRFix
* DotFred's SoftKeyAppletEx
* DotFred's TaskManager (and registry editor)
* WiFiFoFum
* Regional Settings default to English (United States) and use a slash for the date seperator (M/dd/yyyy)
* Menu sounds work by default
* Pressing the "End Call" button does not disconnect GPRS but minimized the active application. Pressing and holding the "End Call" button for about 5 seconds will do a GPRS Disconnect
* Internet access over ActiveSync (USB) connection works (You must apply a registry fix on your PC first. See the next post for the fix)
Hình ảnh minh họa
Download
Mã:
http://rapidshare.com/files/37288886/XDA_Mobile_6.0.0.zip
Theo mình biết bản XDA 6 sẽ được fix vào tuần sau nên cứ bình tĩnh vậy.Up mãi mệt quá!WM6 sao vẫn cứ lỗi mãi thế nhỉ.Có bác nào thử bản InGeNeTiCs' 15.2.318 OS ở đâychưa?Không biết có sạch không nhỉ?MÌnh chỉ cần ổn định,không lỗi thôi.Còn soft thì cài thêm được,lo gì.
Lõi cơ bản :
Download
Mã:
Tôi dùng bản này khá ổn định, Wifi ngon lành, bật phát một. Pin tiêu tốn bình thường. Giao diện đẹp kể cả lúc khởi động.
Nếu khó DL từ Rapid thì có thể DL theo link của bác Bachikho cho nè
ftp://xda:xda@130.89.126.174:2311/Wi...bile_6.0.0.zip
Ừhm, vote 1 phiếu cho bản này. tui xài trên Cingular 8125 chạy rất ổn định, và nhanh nữa.
-Tôi đã thử bản InGeNeTics rồi so với các bản WM6 khác(faria,nts,core 2.0,pv4,nbd,wbe,pandora) thì bản này sạch,ổn định,nhanh,và ít hao pin hơn nhiều .Chỉ tiếc là nó không có HTC camera,MMS thôi.
Mình thấy core2n chạy hay đấy chứ. ít otons pin
Hiện tại mình vẩn xài bản Core 2.0n nhưng bản này chạy hơi chậm mặc dù rất ổn định, ít hao pin, nên mình chỉnh pp lên 8Mb --> chạy nhanh hơn và rất ổn định
Tiện thể cho e hỏi là mình backup (spb backup) tioanf bộ rùi restore trên rôm khác(cùng 1 máy (Đều WM6) thì có chạy dc ko nhỉ?
Mỗi bản rom nó có cấu trúc khác nhau nên khi bạn backup trên rom này và restore trên rom khác thì nó vẫn chạy được nhưng vẫn có lỗi không tương thích. Tốt nhất là bạn nên cài lại toàn bộ là ok. Theo mình thì bản rom Core2n là ổn định nhất so với các bản khác đến thời điểm bây giờ đó bạn
mình cũng mới sài bản này được 1tuần thấy cũng được lắm!
giao diện: ko có gi fải fàn nàn
tốc độ: không nhanh hơn so với bản crossbow reload
wifi: kết nối tốt
chức năng diện thoại: bình thường
sms: nếu cài mring vào thì sms ko chỉnh rung được. ai biết chỉ mình nhé
mình mới chỉ thấy bàng do thứ thui! hehe newbie mà!!
