XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 19965)
Sonblack
Super V.I.P
PDAVIET ROM WM6.1
CE OS 5.2.19965 Build 19965.1.2.3 PV
=== Only for XDA ATOM/XDA ATOM PURE ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
Mod Medkid
Mod Hoangdat_vista
Trial Mod Lamson
Trial Mod PhamNhatThanh
Trial Mod TranMinhMan
Trial Mod nhocbanme
Trial Mod khacduy1978
Thông tin - ROM Information:
- CE OS 5.2.19965 Build 19965.1.2.3 PV
- Pagepool: 6M
- ROM Version: 20080717C1WWE
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- .NET Compact Framework 2.0.7045.0
- Office Mobile 6.1
- Office Note
- ArcsoftMMS v5.0.31.11
- Windows Media Player 10.3 Build 19965
- Windows Live for Windows Mobile v10.6.0034.0800
- Adobe Reader LE 2.0
- Adobe Flash Lite v2.1
- Advanced Configuration Tool v2.02.0.1.0 by Schap
- ClearTemp v1.0.2 by Vicott Wong
- Task Manager v3.1 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- HTC Sim Manager for Pocket PC v6.49
- Synchro Time v0.94 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Esmertec Java Build ID: 20080428.2.1
- EnlargeStartMenu v1.2.34070.1
- LargeTitleBar v2.35.0.0
- Total Commander CE v2.5 by Christian Ghisler
- Mode SMS (change message display on PPC)
- WKTask v1.1.7.3 (open/close applications fastly)
- PocketRAR v3.71 by Alexander Roshal
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- BatteryStatus Today Plugin v0.05.126 Build 0309 by Chi-Tai Dang
- PHM TrayLaunch
- Pocket Screen v1.3 by JJM. Roseboom
Hướng dẫn - Guides:
Tải file .exe về máy. Chạy nó. Giải nén vào thư mục C:\Windows\Temp. Chạy file Device Software Update Utility.exe từ thư mục này để up rom.
Download the .exe file to PC. Execute it. Uncompress to folder
C:\Windows\Temp. Run file Device Software Update Utility.exe from this folder for flashing rom.
Link đã có sẵn.
The link is available now.
ATOM ROM 19965 - PDAVIET
PASSWORD for uncompress: SONBLACK
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Up cả EXtendedROM để có được giao diện màu đen của Wireless Manager.
Flashing with option "Update Item" is "OS+EXtendedROM" for having black skin of
Wireless Manager.
Chúc vui.
Enjoy it.
Sonblack
Trời không phụ kẻ có lòng . Đợi gần 1 ngày liền . em up luôn đây . Cám ơn anh Sơn .oái chưa có link . huhuhuhu. Anh Sơn cho thêm skin của Windowmedia đi .Cho em chiêm ngưỡng trước vậy ? Em sẽ ấn F5 liên tục;;);;);;);;);;);;)
Canh me mà cuối cùng cũng ko được bóc tem, thứ nhì thôi :))
Cám ơn anh Sơn nhiều vì niềm đam mê của anh
Các e đã ra đi, chỉ còn e Atom ở lại. Nên A Sơn đầu tư wá, 2 bản ROM ra cùng lúc.=D>
Các mem Atom sướng roài!:p:D
Chẳng lẻ kiện bác SONBLACK này nhỉ? cứ up, cứ up, up hoài luôn,....
Khoái thiết, lần đầu tiên xài O2 không biết mua con gì, mua đại con Atom, vừa túi tiền lại dể dùng và dể dọc, không ngờ gặp bác Sơn, cho nhiều bản rom vậy, khoái gần chết. Down về cái up liền nì... mấy hôm nay cài nhiều soft wa, máy chạy hao pin ghê luôn, giờ refresh lại bằng rom mới, ngon ơ... hehe, thanks bán Sơn nhé.
Mạng lỗi quá , chưa down dc . có bác nào up chưa . nhận xét và cho ý kiến đi . chắc fai đến đêm nay e mới up được mất .
đã up thành công lúc 10 pm . Ặc , sung sướng đến phát điên lên mất . bản rom này chạy mượt kinh khủng . còn giao diện thì đừng hỏi ( mới lạ và cực đẹp ) . Giờ tôi chỉ ước có 2 con atom để up thử bản 19960 thôi . Làm thế nào bây giờ ??
Em rất cám ơn anh Sơn . hi vọng trong thời gian tới a sẽ có tiếp những bản rom mới và đẹp.
huhuhu . tạm biệt bản 20266 . không biết khi nào mới gặp lại 20266 đây
MÀ TẠI SAO KHÔNG AI THẢO LUẬN NHỈ ?
Anh Sơn xung quá đi mất, ngang ngửa em :D
Mà kiểu này anh nên đầu tư thêm vài chiếc PPC nữa để thay thế mấy chiếc mới hy sinh đi thôi.
Nhiều ROM mới đẹp quá
Anh Sơn ơi , làm thế nào để bỏ mấy cái biểu tượng word , exel ... ở thanh công cụ bên dưới nhỉ ? Em ít dùng nó nên muốn tắt đi .
Nhận xét về bản rom mới : Ngay từ lúc khởi động đã nghe thấy 1 âm thanh ( lần đầu tiên được sử dụng bản rom có tính năng này ) . click vào các biểu tượng trên thanh công cụ bên trên ( loa , cột sóng ...) sẽ thấy được zoom lên -> dí bút vào mà không sợ nhầm ( đây cũng là cái mới ) . menu start hoàn toàn mới , tiện dụng và đẹp hơn . keyboard không phải là màu đen nhưng sử dụng cảm thấy mềm mại hơn . Các skin khác thì không phải nói rồi ( quá đẹp )
Máy của mình giờ chạy rất nhanh , ổn định .
Về vấn đề pin thì mình không để ý . Các KTV cũng như anh Sơn đã làm hết sức rồi .
1 lần nữa cám ơn anh Sơn
Lại muốn bỏ bớt rồi. Muốn bỏ thì chỉ cho bỏ luôn, bỏ thì đừng tiếc à nha. :O:O:)):))=))=))
Vào Windows\StartUp, xóa bỏ cái file PHM TrayLaunch.lnk rồi Reset lại máy là xong.
Lưu ý là nếu HardReset thì mọi thứ trở lại như ban đầu, muốn bỏ phải làm lại hướng dẫn trên.
Các điều khác: thực ra vẫn là những thứ cũ nhưng version mới hơn mà thôi, từ thời 6.0 kia.
Chúc vui!
Bản rom này khởi động rất nhanh . chỉ vài giây là đã có thể " chỉ trỏ " thoái mái rồi . Tuyệt vời . Bây giờ đang lăn tăn muốn test bản 19960 kia , nhưng bản 19965 này " yêu quá cơ ". huhuhu , hết ngày mai sẽ test bản 19960 , dành phải sau các bạn 2 ngày vậy
TRÙI TRÙI , NHANH WE' ... MONG CHO CON ATOM CỦA BÁC SƠN ĐỪNG CÓ HƯ ( MẤY CON KIA ... EXEC , ATOM LIFE ... HƯ HẾT ĐI ... HE HE ) ĐỂ BÁC ẤY CÒN LÀM Atom Rom mà xài nữa chứ ! Thanks very... much !
Nhiều bản Rom tốt quá, không biết chọn bản nào. Anh Sơn đang cho bọn em đứng giữa một rừng hoa mà hoa nào cũng xinh cũng đẹp hết.
19965 và 20226, cái nào ngon hơn, cái nào mới hơn hả mấy huynh , sao nhìn số 20226 thấy thèm quá , chắc là build trên core mới hơn 1996x rồi ??!!... giờ xài cái nào đây ???
Chỉ số build chỉ mang tính tương đối với từng dòng mà thôi. Còn Atom, các ROM WM6, WM6.1 thì đều được port lại từ các dòng khác. Ở đây build 19960 và 19965 mình có được sau build 20226. Biết vậy đủ ròi. :D
Những bản ROM tới, mình sẽ cho vào các ứng dụng nhỏ trên PPC do chính mình viết (có sự hỗ trợ của Admin Kawaguchi) nhằm tăng các tính năng cho ROM. Hy vọng mọi thứ đều như ý muốn. :-?:-?:-?
