XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 19971) FINAL EDITION
Sonblack
Super V.I.P
PDAVIET ROM WM6.1
CE OS 5.2.19971 Build 19971.1.2.6 PV
=== Only for XDA ATOM/XDA ATOM PURE ===
(Final Edition)
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Hoangdat_vista
Mod TranMinhMan
Trial Mod Lamson
Trial Mod PhamNhatThanh
Trial Mod Medkid
Trial Mod nhocbanme
Trial Mod khacduy1978
Many thanks to herg62123, poorlyduck, A_C and greatbal from xda-developers
Thông tin - ROM Information:
- CE OS 5.2.19971 Build 19971.1.2.6 PV
- Pagepool: 6M
- Rom date: October 09, 2008
- ROM Version: 20081009C8WWE
- Ported from latest original ROM of HTC Opal
- Transcriber included.
- Manilla 2D with Blue Skin also included.
- Remove all help files.
Hình minh hoạ - Illustrative Images: (Updated)
Các chức năng chính - Main functions:
- AudioManager v2.0.1819.2129 (HTC Opal)
- Audio Booster (HTC Opal)
- JBlend Java (HTC Opal)
- Outlook Enhancement (HTC Opal)
- Picture Enhancement (HTC Opal)
- Comm Manager v2.7.1.8 (HTC Opal)
- Manila2D v1.00.1819.2926 (HTC Opal)
ArcsoftMMS v5.0.31.50 (HTC Opal)
- S2U2 v1.22 by A_C
- ClearTemp v1.1 by Vicott Wong
- HTC Sim Manager for Pocket PC v6.57
- .NET Compact Framework 3.5.7283.0
- Office Mobile 6.1
- Office Note
- SunHigh Windows Media Player 10.3 Build 19971 (Mod)
- Advanced Configuration Tool v3.2.0.0 by Julien Schapman
- Task Manager v3.1 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.1.7.3 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- SDAutoRun v2.0 (automatic install cab files from Storage Card)
Extended ROM bao gồm các file sau (Extended ROM included the files as follows):
1. Album_2.0_1818.3032.cab
2. Album_Video_fix.cab
3. GoogleMaps_compressed.CAB (Mod)
4. Opera_v9.5_Build_2392_QVGA_WWE.cab (Mod)
Hướng dẫn - Guides: Vui lòng đọc kỹ - Please read carefully
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn.
Link nằm trong file đính kèm bên dưới.
The link is available now.
Link is put under attached file.
ONLY FLASH ROM WITH OPTION "OS ONLY". THAT'S ENOUGH!
Để một số ứng dụng trong ROM có thể hoạt động tốt, bạn phải đặt thư mục Cabs và file SDConfig.txt (nằm trong file nén chứa ExtendedROM) trong thư mục gốc của thẻ nhớ trước khi up rom hoặc trước khi PPC reset sau khi up rom thành công.
In order to run well some utilities in my ROM, you have to put folder "Cabs" and file "SDConfig.txt" (ExtendedROM compressed file inside) in original folder of storage card before you flash the ROM or before PPC reset after flashing ROM successfully.
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Chúc vui!
Enjoy it!
Sonblack
e xin cái tem . Cám ơn a Sơn rất nhiều .
Bản rom này mang tính đột phá hoàn toàn . htc diamond đã trôi vào dĩ vãng .
Giao diện cực đỉnh và luôn luôn cập nhật. Theo mình được biết thì Manilla 2D khi tích hợp vào rom thì chạy cực mượt , khác hẳn khi cài đặt thông thường
Đẹp quá !!! Nhìn mà phê mà chưa thấy link làm người thứ 2 hix hơi bùn
công nhận bác này nhanh thiệt, canh nãy giờ quên 1 chút bị bác hốt mất.
Em thích màu này, tuy không nổi bật nhưng màu sắc dễ chịu.
Trời .... giao diện đẹp quá ! Chết ... vì sung sướng mất thôi !
Thank bác Sơn nhiều ! :O
Xin lỗi mọi người nhé! Lẽ ra mọi thứ giờ đã hoàn tất, nhưng chiều nay có việc gia đình đột xuất nên giờ mới post bài. Đến sinh nhật của Man BatKid mà còn hem đi được. Sorry chú Ninh nhá!
Cứ thong thả, hôm nay có ROM luôn, trước 12giờ. Ha ha!
Nói chung ROM chạy ổn, có điều như cunxinh nói ở dưới Free RAM thấp xuống. He he, được cái này mất cái kia đấy nhé, chứ cái nào cũng được hết thì Sonblack giờ này đâu ngồi làm ROM. Hơ hơ!
CHÀI FREE RAM CÒN 10m THUI :)):)):)):)):)) NHƯNG BẢN ROM NHINH RAT TUYET VỜI HEEE CHƠ TEST ROM NÀO;;);;);;)
đẹp thật đấy canh từ tối đến giờ. nhưng cái này hình như cài mặc định thì không thể thay đổi được theme thì phải. cám ơn bác nhé híc vọc room sướng nhất lúc này đây
Trời ơi trước 12h Hic. Chờ từ 7h chiều đến giờ còn hẹn 12h nữa chắc Em chết quá Anh Sơn ơi. Dù sao thì cũng cám ơn bác, đã giúp cho cộng đồng PDA O2 Atom của tụi em có những thứ tốt nhất cho chú dế bẻ bỏng đáng iu của tụi em. Thank bác dài dài.
chưa biết chạy thế nào nhưng cái giao diện này thuộc loại đẹp nhất từ trước tới nay rồi
ac ... ko lọt vào top 10 ... ban rom này phải nói là giao diện đỉnh nhất từ trước tới nay ... free ram con 10mb thui ...oc oc ...ko biết phải vậy ko ta ... nhưng nói chung bản rom này rất tuyệt ... thanks anh Sơn và anh em trong PDA rất nhìu ...
5. GoogleMaps_compressed.CAB
6. Opera_v9.5_Build_2392_QVGA_WWE.cab
7. WindowsLive_NoIM_0409.cab
8. YouTubeQVGA 1_5_1819_1531.cab
ko nhất thiết phải có nếu bác nào không thích có thể bỏ đi cho đỡ nặng máy.
HÍC EM có bản giao diện chỉnh sửa theo ý mình một chút rất đẹp .bác son à em có ý kiến thế này bác mở thêm một box để anh em pots giao diện của mình lên nếu anh em nào có giao diện đẹp thì lấy giao diện đó làm nền cho những bản sau ý bác thế nào.
vợ dục mấy lần đi ngủ rồi híc cứ mải up room chắc 3 bữa vợ bỏ mất
Chưa chắc đâu à nha! :)) Chưa vọc hết Manilla rồi!
Trời ơi, vừa mới up bản 20775 được vài ngày đã ra bản mới, bác Sơn đẻ rom như lợn con, nhanh quá. Bản này tôi ko thích màu sắc lắm, nhưng cấu trúc giao diện lại rất đẹp. Nếu nó có màu đỏ đậm hoặc xanh như 20775 thì tốt quá. Thôi cứ dùng bản cũ, chờ mọi người dùng xong đánh giá rồi up cũng được vậy.
Góp ý nhỏ: mỗi bản rom bác Sơn up lên, bác có thể viêt thêm cái history được ko? VD: bản 19971 so với các bản 19xxx đã thêm cái gì, cũng như bản 20775 so với 207xx có thêm cái gì, như vậy ai cũng biết mỗi bản nâng cấp sẽ như nào để cùng đánh giá, vì như này chỉ đánh giá được giao diện và biết rom mới hơn. Máy của tôi hợp rơ với bác nên bản nào cũng giống nhau, thích là cứ thế cài ko phải lo vấn đề gì cả^^
Không viết history gì cả. Các chức năng (gồm soft nào) đã nói lên tất cả. Chẳng ai ở không để làm cái chuyện so sánh rom của chính mình. Bạn thích thì bạn cứ so sánh sao lại bảo người khác phải chỉ ra cho bạn??? Muốn ăn thì vào bếp, chẳng ai bưng đưa cho đâu! :)):)):))
Các bác nhà Atom hối quá, up nhầm file chứa link, tẩu hỏa gùi! =))=))=)) Các bác vào tải lại cái link đi nha. Miễn thắc mắc nữa nha. :D
đang đêm khuya các bác bàn tán nhỏ nhỏ để người ta còn ngủ,bản rom đẹp quá a s ơi.thanks a s đã rất tận tình để tụi e đc thõa mãn,chúc a mạnh khỏe!!!
Usb transfer Fail là sao bác Sơn ơi.....
Hỏng lẻ giờ chỉ up rom hả chòi. Khởi động máy rồi làm lại đi!
Em đã down chính xác file Rom trước khi bác up file text lên kìa ...
Link cũng giống như mấy Rom kia thôi , có điều thay chữ 19971 vào chỗ tương ứng , down mà cũng khó khăn dữ vậy
. Tình hình là ổn rồi , Rom đẹp quá ... chạy vù vù nè , chắc test tới sáng luôn quá , hic hic ...
BÁC SƠN UI CHO CHÁU HỎI ÚP CẢ 2 BẢN ROM VÀ EXROM HẢ BÁC HAY CHỈ ÚP ROM THUI;;);;);;)
BẠN ÚP ROM THUI HAY ÚP CẢ EXOM
