XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 19972)
Sonblack
Super V.I.P
PDAVIET ROM WM6.1
CE OS 5.2.19972 Build 19972.1.2.7 PV
=== Only for XDA ATOM / ATOM PURE ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Lamson, TranMinhMan, Hoangdat_vista
Trial Mod PhamNhatThanh, khacduy1978
VIP Medkid, nhocbanme, nhattoai
herg62123, poorlyduck from xda-developers
Thông tin - ROM Information:
- CE OS 5.2.19972 Build 19972.1.2.7 PV
- Pagepool: 6M
- Rom date: November 20, 2008
- ROM Version: 20081120D4WWE
- Transcriber included.
- Manilla 2D with Black Skin also included.
- Remove all help files.
- XIP & SYS from latest original rom of HTC Elfin
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- AudioManager v2.0 Build 1820.1321 (Elfin)
- JBlend Java v3.3.5 Build 20081015.1.1 (Jade)
- Outlook Enhancement (Elfin)
- Picture Enhancement (Elfin)
- Comm Manager v2.7.2.8
- ArcsoftMMS v5.0.31.63 (Elfin)
- Acrobat PDF LE 2.5 (Elfin)
- Enlarge Start Menu (Mod from Elfin)
- Enlarge TitleBar (Elfin)
- YouTube (Elfin)
- Manila2D v1.00.1819.2926
- HTC Sim Manager for Pocket PC v6.58
- .NET Compact Framework 3.5.7283.0
- Office Mobile 6.1
- Office Note
- HTC Album (automatically run)
- Google Maps (automatically run)
- Opera Browser (automatically run)
- SIPChange (automatically run)
- Windows Media Player 10.3 Build 19972
- Advanced Configuration Tool v3.3 by Schap
- Pocket RAR v3.80 by Alexander Roshal
- ClearTemp v1.1 by Vicott Wong
- PIM Backup v2.8.0.0 by FdcSoft
- Pocket Screen v1.3 by JJM. Roseboom
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.1.7.3 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
Hướng dẫn - Guides: Vui lòng đọc kỹ - Please read carefully
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn - The link is available now
Link nằm trong file đính kèm ở cuối bài - Link put under attached file at the end of this post
UP ROM VỚI TÙY CHỌN "OS+ExtendedROM".
FLASH THE ROM WITH OPTION "
OS+ExtendedROM".
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Cuối tuần vui vẻ!
Have a good weekend!
Sonblack
em sẽ là người đầu tiên ! hix lần đầu được xé tem! huhu mừng quá!rom anh sơn cái nào cũng mượt ! chúc a sơn luôn luôn mạnh khỏe! canh refresh trang từ 9h50 đến giờ để mong là người đầu tiên thưởng thức rom của a Sơn cuối cùng đã thành công!
-Ai vào down rom mà không thanks a Sơn up rom nổ Đt ráng chịu nha!hihi!
@All: Tối nay sẽ lại có ROM mới 19972.1.2.7 từ rom ship HTC Elfin, YouTube có sẵn chạy phà phà, loại bỏ S2U2, S2P, DialPad màu đen, thay bằng DialPad của Elfin và nhiều thứ khác nữa. Giao diện vẫn là màu đen nhưng sửa đổi bên trong nhiều thứ...
Anh Sơn ơi, bản mới đừng bỏ S2P bỏ S2U2 đc rồi.S2P nghe nhạc pro mà nhẹ nữa dễ xài.
Rom mới
Lại có bản mới roài anh Sơn, mai em dow sớm up liền>cảm ơn anh nhiều=D>
thanks sonblack but i have been complaining from so much time that a2dp doesnt work on the rom made by you except for rom build 19213 . it had bugs but a2dp worked
Thank you for your feedback, but I only make rom and I don't have any device for testing A2DP, please send one to me for test in advance :D I understand but I haven't any condition for finishing everything in the rom. Anyway, thank you so much!
Anh Sơn có thể chỉ em cách chuyển sang giao diện màu xanh được không, giao diện màu đen ra ngoài trời khó nhìn lắm
hehe, đai ca SƠN muôn năm, mặc dù em mãi mãi là người down sau, nhưng vẫn dzui, thank anh SON
Kô vui thì đừng có Down :D (đùa thui) chúc cả nhà ngủ ngon. UP Rom để thứ 7 8 cuối tuần đi chơi.Cuối tuần vui vẻ nhá mọi người.
bạn muốn chuyển giao diện thì bạn qua đây http://pdaviet.net/showthread.php?t=33963 tải cái M2DC về cài vào thẻ nhớ! trong topic đó có 1 số thame bạn tải thame mà bạn thích chép vào thẻ nhớ dùng M2DC để chuyển thame . bên đó có hường dẫn cụ thể đó!
Bận quá bây giờ mới lên thank bác sơn được và Down về vọc.
tối qua đợi lâu quá ngủ quên mất
có ai up rồi thì cho tui hỏi chút. bộ nhớ Program và RAM còn nhiều không?
em cài nhiều soft cần lắm. bản 20758 trống nhiều thế mà em cài con 7MB thôi
chúc bác sơn có sức khỏe tốt
THANKS!!!!
THANKS!!!!
do bản này a Sơn bỏ 1 ít chương trình như M2DC, s2u2,s2p nên bộ nhớ còn trống nhiều lắm bạn! chạy mượt mà êm ái ! đặc biệt coi you tube không lag , buff còn nhanh hơn cả con PC của mình luôn hehe!:D
Bản này có M2DC mà, sao bác lycucu lại nói không có M2dc
tại bạn không hiểu rõ rồi bạn thử vào coi lại rom 20931 đi nó có M2DC và Manila2D ! cái mà bạn nói là Manila2D còn M2DC là chương trình để thay đổi thame cho Manila2D đó bạn!nếu thấy đúng thanks cái nha :D
Sao diễn đàn có nhiều người đòi hỏi thật vô lý lam khổ người build rom như bác SON ko ah.S2U khóa màn hình rất tuyệt khỏi bị cấn phím khi để túi mà lại đẹp.M2DC giúp tinh chỉnh lại Manila thay đổi các tap. Toàn những soft được coi là cần thiết cho ppc.hy vọng mọi người chỉ nên post những lỗi của rom.bác sơn build rom là để cho cộng đồng chứ ko phải cho riêng 1 người nếu bạn ko thích thì có thể tắt đi ko sài.
Anh Sơn & mọi người có thể cho mình hỏi,có cách nào để phân biệt bản ROM nào của anh Sơn có chức năng Touch mặc định sẵn trong bản ROM.Vì thấy anh Sơn ra ROM liên tục & luôn có 2 bản ROM song hành,1 có kèm chức năng Touch,1 thì k có(như topic ROM kĩ niệm 2 năm thành lập PDA của anh Sơn ấy).
cám ơn.
