XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 20275)
Sonblack
Super V.I.P
PDAVIET ROM WM6.1
CE OS 5.2.20275 Build 20275.1.3.3 PV
=== Only for XDA ATOM/XDA ATOM PURE ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Medkid
Mod Hoangdat_vista
Trial Mod Lamson
Trial Mod PhamNhatThanh
Trial Mod TranMinhMan
Trial Mod nhocbanme
Trial Mod khacduy1978
Thông tin - ROM Information:
- CE OS 5.2.20275 Build 20275.1.3.3 PV
- Pagepool: 6M
- Rom date: August 20, 2008
- ROM Version: 20080820C3WWE
- High Speed ROM.
- Based on the 20273 ROM but some changes
Hình minh hoạ - Illustrative Images:
Mọi thứ còn lại như bản 20273 Ver 2
The others as build 20273 Ver 2
Các chức năng - Main functions:
- .NET Compact Framework 3.5.7283.0
- Office Mobile 6.1
- Office Note
- ArcsoftMMS v5.0.31.11
- Windows Media Player 10.3 Build 20275
- Adobe Reader LE 2.5
- PHM TrayLaunch
- Advanced Configuration Tool v3.0.0.0 by Julien Schapman
- ClearTemp v1.0.2 by Vicott Wong
- Task Manager v3.1 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- HTC Sim Manager for Pocket PC v6.53
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Esmertec Java Build ID: 20080704.5.1
- Pocket Screen v1.3 by JJM. Roseboom
- Total Commander CE v2.5 by Christian Ghisler
- WKTask v1.1.7.3 (open/close applications fastly)
- PocketRAR v3.71 by Alexander Roshal
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
Hướng dẫn - Guides:
Chỉ cần tải file .exe chứa ROM và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it, then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn.
The link is available now.
ATOM ROM 20275 - PDAVIET
PASSWORD for unpack: SONBLACK
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Chúc vui!
Enjoy it!
Sonblack
hehehe. lại là người đầu tiên rồi . chuẩn bị lại up rom thôi .
a Sơn làm việc không biết mệt mỏi . Cám ơn a
Anh ơi , cho thêm vài cái ảnh nữa đi anh
hix, anh SƠn làm em nhức nhối miết, ROM cũ đang xài ổn định thì lại có ROM mới liền ..
EM phục anh sát đất .. hix
Chúc anh luôn dồi dào sức khỏe ..để phục vụ anh em PV..hihihihi:D
chưa có links. :)
chắc là dòng HTC Diamond hả anh Sơn Black?
Dòng nào thì cũng vậy thôi mà! Dù sao cũng đã xào nấu trong bếp roài thì đâu còn origin đâu, bận tâm làm gì!
Đã là ROM vào bếp thì dòng nào chả được miễn là nó chạy tốt trên con Atom là ok òi! :)):)):))
cái skin theme hình Global ngầu wá ..hix .. anh SƠn làm em nôn nao :D
Anh post thêm vài cái hình để illustrate nữa nhé anh :D
Rom đã sẵn sàng .Down bè là 50,64 MB . Chắc là chuẩn rồi . Mọi người click thank a Sơn rồi down nhé ,
@ anh Sơn : anh thông cảm . e sốt ruột quá
=))=))=))=))úp rom lien tuc liên liên tuc chùi sướng wes thank a sơn=D>=D>=D>=D>=D>=D>=D>=D>
Úp xong rồi . nhìn đẹp quá .Máy chạy ầm ầm .Mọi người nên tận hưởng từ lúc bắt đầu hardreset nhé . không có gì để chê bản rom này . StartMenu lại thay đổi giống 20270 rồi . Vui quá . Em sẵn sàng không restore file backup để cài lại tất cả các ứng dụng vì bản rom này
Mà không hiểu anh Sơn chạy đâu rùi nhỉ . Không biết bản down về có chuần không nữa .
hix .. anh SƠn ơi, cái ROM này để name là : "OS2073_V2_ATOM "<== anh có up lộn file ko nè ??
thì em lo xa ấy mà thấy cái tên PDAVIET_ROM_WM61_OS20273_V2_ATOM thì em tưởng anh up trùng tên với bản ver 2 của ROM 20273 thui :D
==>> sorry anh , em down lộn file ..hix .. nôn nóng wá đó mà
You look like the arrow dynamic and never stop to develope to make your rom the best. Thankkkkkkkkkkk..............
hix em vọc bản 20273 V2 chưa đã nữa là có thêm bản mới rồi, cám ơn anh Sơn nhiều, em đi up đây....
Chắc chết !!!
Vợ em nó lại đánh em cho xem !!!
Ngày thì đi làm, tối lại Up ROM rồi cài soft! Khuya lên giường thì lại lăn ra test ....
Chết mất thôi !!!
Thank for everything. But I try 20273 in camera function the screen was alway flicking and can not set the resolution over 640X480 because PPC can not save picture.
Anh Sơn ơi . Bản rom này em thích lắm . Đã lâu rồi em mới thích thú như vậy. Rom chạy mượt mà , giao diện thì thôi rồi . Không có gì để phải phàn nàn . Những ứng dụng a tích hợp rất thiết thực . E sử dụng hết chức năng của rom luôn.
Em chúc a luôn khỏe và có những bản rom pro nhất.
Em muốn hỏi thêm là những bản rom trước đây a build thì a sẽ làm gì với chúng ? em thấy rất tiếc .
Có lẽ các mem atom là người hạnh phúc nhất vì có anh . Nghiện rom mới cũng là do a cả
Em cám ơn a . atom như 1 gia đình nên e mong muốn a đừng thay đổi điện thoại nha a
Không bỏ đâu trừ khi nó die mà anh hết cách cứu. Còn chỉ có mua thêm thôi, build nhiều dòng mà, nhưng hiện tại phải lo cho gia đình... Mỗi người mỗi cảnh mà, có giống ai đâu, ế vợ chắc rồi :)):)):)) Những bản rom cũ ấy à, cho vào sọt rác thôi, cái sau phải hay hơn cái trước kia mà. Còn lại thì đều nằm trên host của PDAVIET hết roài, giữ trong máy thì không còn chỗ để build cái ROM mới hơn. Rom riết nên nó ròm. :D:D:D
