XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 20748)
Sonblack
Super V.I.P
PDAVIET ROM WM6.1
CE OS 5.2.20748 Build 20748.1.4.0 PV
=== Only for XDA ATOM/XDA ATOM PURE ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Medkid
Mod Hoangdat_vista
Trial Mod Lamson
Trial Mod PhamNhatThanh
Trial Mod TranMinhMan
Trial Mod nhocbanme
Trial Mod khacduy1978
Thông tin - ROM Information:
- CE OS 5.2.20748 Build 20748.1.4.0 PV
- Pagepool: 6M
- Rom date: September 7, 2008
- ROM Version: 20080907C5WWE
- High Speed ROM.
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- .NET Compact Framework 3.5.7283.0
- Office Mobile 6.1
- Office Note
- ArcsoftMMS v5.0.31.11
- Windows Media Player 10.3 Build 20748
- Adobe Reader LE 2.5
- PHM TrayLaunch
- Advanced Configuration Tool v3.0.0.0 by Julien Schapman
- ClearTemp v1.0.2 by Vicott Wong
- Task Manager v3.1 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- HTC Sim Manager for Pocket PC v6.55
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Esmertec Java Build ID: 20080704.5.1
- Pocket Screen v1.3 by JJM. Roseboom
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.1.7.3 (open/close applications fastly)
- PocketRAR v3.71 by Alexander Roshal
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- Some changes from my previous rom (build 20721)
Hướng dẫn - Guides:
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn.
The link is available now.
ATOM ROM 20748 - PDAVIET
PASSWORD for unpack: SONBLACK
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Cuối tuần vui vẻ!
Have a good weekend!
Sonblack
Sung sướng khi được ăn ốc trước tiên ( các bác lo đổ vỏ nhé ... =)) ) , cuối cùng thì ta cũng được up Rom !
Chà chà không biết "Some changes from my previous rom" cụ thể là những gì nhỉ , hồi hộp quá ... :-??
Thanks pác Sơn Đen =D>=D>=D>
Quá nhanh, quá chóng mặt ! Muốn sặc ! Vì buil ROM mà cứ như đi gặt !
hix, mình mới up 20721 tối qua, bây giò vào lại thấy cái mới, hix tình sao giờ ^^
Thanks anh
ái chà hay quá,tối nay lại có rom mới để phá rồi, thank anh Sơn nha
ặc ặc xài rom kia chưa mỏi mắt đã có bản mới rùi sao . nhanh zaj.hi hi . cám ơn anh Sơn nhiều nha
Công nhận các pác nhà ta vui tính thật. Nhìn không mà la í ới, tới lúc có rom thì chí chóe. Ngán thì tẩn ngẩn. Ứ biết đâu mà lần. =))
Chờ đi, link sẽ có như đã hứa, spam là delete nhé :)
nhìn pro wá em chờ suốt chưa thấy link
Bạn nôn nóng, còn mình build chắc ngồi rung đùi bây giờ chắc. Có ghi rõ thời gian cập nhật link mà bạn (chưa gần tới trước 24 giờ mà) :D (Sonblack)
Đã edit cho có dấu tiếng Việt. Post bài phải bằng tiếng Việt có dấu nha bạn.
Lại Bản Rom mới à!!!
Hi vọng Bác Sơn! đừng có nóng nhé!!! Dù sao cảm ơn!!! Bác nhiều!!! Mình sẽ tiếp tục ủng hộ "thank's!!!!" để khích lệ tinh thần đóng góp niềm đam mê của Bác!!!!
ATOM ROM 20721 - PDAVIET: ngày 02/09/2008:
WKTask v1.1.7.... (open/close applications fastly)
không có ngôn ngữ việt mong Bản này có!!!
HÍC EM MỚI ĐAU NGỒI CẢ BUỔI CHIỀU TẦN NGẦN NỬA MUỐN CHỜ UP BẢN ROOM MỚI NỬA MUỐN UP BẢN Core 20748 VÀO ĐI LẠI ĐẾN 4,5 LẦN CHỜ BÁC SONBLACK UP LÊN LINK MỚI ĐỢI LÂU QUÁ ĐÀNH UP BẢN CŨ VỪA ĐANG UP DỞ QUAY LẠI ĐÃ THẤY BÁC ĐƯA LINK LÊN RỒI.ĐÀNH VẬY CỨ DUNG THỬ VÀI NGAY NGHIÊN CỨU RỒI UP BẢN ROOM MỚI CỦA BÁC VẬY. :).ĐÃ CÓP VÀO THẺ BẢN MỚI CỦA BÁC LÚC NÀO CHÁN THÌ UP SANG BẢN MỚI.CÔNG NHẬN EM THICH NHẤT Ở DÒNG ANTOM NÀY LÀ UP TRỰC TIẾP TỪ THẺ QUÁ TIỆN LUÔN. CÁM ƠN BAC NHÉ
Thank's!! Bác Sơn!!!!
Dowload xong rồi mình chuẩn bị Up đây!!!! Cảm ơn!!!!! Ngồi canh chừng miết mới thấy link!!!!!!!
Dowload xong giải nén nó báo lổi này::::
Đúng pass mà chỉ bun ra có mấy file::::???
[QUOTE.....................
...............[/QUOTE]
password was wrong, you must unpacked rom file with SONBLACK
Mình cũng bị lỗi đó, nhưng đánh lại pass lần thứ 3 thì được, up xong rồi!
làm thế nào đây anh sơn ơi ko up dc hichic
Mình vẫn up bình thường. Đã xong rồi, đang ngồi test.
1. Bạn tải file bị lỗi, tải lại đi
2. Bạn phải dủng đúng pass, có viết hoa SONBLACK
