XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 20753)
Sonblack
Super V.I.P
PDAVIET ROM WM6.1
CE OS 5.2.20753 Build 20753.1.4.0 PV
=== Only for XDA ATOM/XDA ATOM PURE ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Hoangdat_vista
Trial Mod Lamson
Trial Mod PhamNhatThanh
Trial Mod TranMinhMan
Trial Mod Medkid
Trial Mod nhocbanme
Trial Mod khacduy1978
Also thank to Author of Prophet Green Edition Clean ROM (Green Skin)
Thông tin - ROM Information:
- CE OS 5.2.20753 Build 20753.1.4.0 PV
- Pagepool: 6M
- Rom date: September 21, 2008
- ROM Version: 20080921C6WWE
- "TOUCH" function included
- Transcriber also included
- High Speed ROM.
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- .NET Compact Framework 3.5.7283.0
- Office Mobile 6.1
- Office Note
- ArcsoftMMS v5.0.31.11
- Windows Media Player 10.3 Build 20753
- Adobe Reader LE 2.5
- PHM TrayLaunch
- Advanced Configuration Tool v3.2.0.0 by Julien Schapman
- ClearTemp v1.0.3 by Vicott Wong
- Task Manager v3.1 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- HTC Sim Manager for Pocket PC v6.55
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Esmertec Java Build ID: 20080704.5.1
- Pocket Screen v1.3 by JJM. Roseboom
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.1.7.3 (open/close applications fastly)
- PocketRAR v3.71 by Alexander Roshal
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- SDAutoRun v2.0 (automatic install cab files from Storage Card)
- Some changes from my previous rom (build 20748)
Hướng dẫn - Guides:
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn
Link nằm trong file đính kèm bên dưới.
The link is available now.
Link put under attached file.
PASSWORD for unpack ROM: SONBLACK
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Chúc vui!
Enjoy it!
Sonblack
Chúc SonBlack có nhiều sức khỏe, cống hiến cho Cộng đồng! Với niền đam mê bất tận!!! Mình thấy giao diện Rom mới rất thích, rất Pro!!! Giống Rom gốc HTC quá!!! Phải nói chưa thấy đã mê rồi!! Cảm ơn tấc cả rất nhiều!!!!
Hihi! có rom mới rồi anh em ơi! sớm quá! trước 10h00 đêm nay rồi.thanx bác SONBlack
hjhj !!! wá đã lun ... tối nay lại là 1 đêm nhọc nhằn ... rom mới wá tuyệt ... thanks bác SonBlack ...
cuối cùng thì bản ROM mới cho Atom của anh Sơn cũng đã xuất hiện.
Xin chân thành cảm ơn những đóng góp của anh cho PV nói chung và room Atom nói riêng..!!
ROM dòng nào khi vào bếp nấu cũng như nhau cả (như anh Sơn nói), nhưng 1 số thành viên cũng muốn biết anh nấu từ dòng nào, như những ROM được nấu và post trên các diễn đàn thì phần thông tin về ROM luôn có ghi ROM được nấu từ dòng nào.
Nếu em có nói thừa thì anh xóa bài đi nhé. Cảm ơn anh
Điều bạn nói không chính xác. Làm trực tiếp từ rom dòng đó thì mới ghi rõ, còn từ các nguồn khác sẽ không có thông tin từ dòng nào. Bạn tìm tất cả các diễn đàn thử xem mình nói đúng hong?
Đây chỉ là build beta của Microsoft đưa ra để test mà thôi. Còn thông tin cụ thể từ dòng nào thì sao đây. Còn ở đây đâu có dump ra từ ROM ship của dòng nào đâu thì răng mà biết.
Nói đến test thì sẽ có ngày hết hạn dùng. Tuy nhiên, các KTV ROM của PDAVIET đều đã xử lý điều này để anh em xài thoải mái. Điều này quan trọng hơn hay từ dòng nào quan trọng hơn? Nếu bạn biết được tôi lấy từ một dòng nào đó thì cũng đâu có bê nguyên si qua được, chỉ lấy core và build thôi. Những thứ khác có khi lấy hoặc không. Ngay cả giao diện thì cũng mod lại từ nhiều nguồn chứ đâu phải của riêng một dòng nào. Vậy trả lời sao đây?
@All: Các bạn sẽ thấy những thay đổi nhỏ nhưng rất đáng kể ngay sau khi bạn cân chỉnh màn hình. Hãy để ý cái ngày mặc định của ROM nhé. Công lao là của ROM Dev Dvha79_ddt đấy. Bản ROM nào cũng thế không chỉ của mình mình không đâu, của tất cả anh em KTV build ROM của PDAVIET đấy.
Ngồi đợi Rom mới háo hức như đang chờ đón giờ phút giao thừa năm mới vậy cà.hihi
CỨ ngoi chờ dòng download hiện lên ko để ý dòng nhỏ ở dưới. Bây gio khui hàng duoc roi
Chelsea - MU = 1-1 , BUỒN THÚI RUỘT CHO CHEL NHƯNG VỀ NHÀ ĐƯỢC AN ỦI BỞI ROM MỚI !
Nhìn cái giao diện đúng là tông mình thích , cám ơn anh Sơn nhiều lắm =D>
Phát hiện lổi rồi đây!!
Up Rom xong gần 11h đêm!!! Test sơ sơ!! Cài lại 1 số Ứng dụng thức luôn tới sáng: ha ha!!!
Phát hiện lổi:
Trong Contacts(Danh bạ) Khi copy Số ĐT từ Sim qua Contacts máy:
1. Chỉ thấy tên và số bình thường, nhưng hki gõ tìm 1 tên mình cần gọi thì chỉ thấy tên không thấy số, khi chọn tên cần gọi đó thì không có chức năng Call vào phần Edit thì chỉ thấy tên Không có Số ĐT thêm số ĐT vào thì hiển thị lên tên và số có phím chức năng Call. mấy trăm số ĐT làm sao nhớ sữa cho hết!!!!
2. Mặt định Rom thì Cổng hồng ngoại đã mở đó! bà con!!
3. Sáng mở máy chỉ có 1 lần tự dò sóng.
Nhận xét Bản Rom 20753:
- Quá đẹp!!! bố trí rất Good! DialPad rất đẹp nhưng ảnh người gọi nhỏ quá trong khi còn khoảng trống nhiều.
- Không thấy máy bị treo khi nhận cuộc gọi, vì chưa có nhận cuộc gọi nhiều.
- Pin à!!! rất tốt ít tốn Pin hơn!!
- Mình không sử dụng GPRS nên không cần test. Vì trong CommManager đâu có có Phím chức năng đó!!!
Còn chờ test sau....! Cản Ơn Bác ROM Dev Dvha79_ddt , SonBlack và các thành viên trong PDAviet nhiều lắm!!! Có gì sơ xuất hướng dẫn mình xin cản Ơn!!!
mặc định thì chức năng phone bị tắt. cái SDAutoRun v2.0 (automatic install cab files from Storage Card, tìm không thấy đâu? chi khi HS mới tự khởi động. không tìm thấy để cài đặt? khi chọc vào biểu tượng % PIN trên tákbar không khởi động CT Power prope
Cái ngày mặc định thì tuyệt.
Tuy nhiên vẫn CẢM ƠN SONBLACK nhiều, và sửa lỗi lại cho anh em nhé. càng sớm càng tốt.
Đề nghị bạn không post bài rời rạc nhé (Sonblack)
Bạn nói không chính xác. Đưa SDAutoRun vào để anh em tự thêm SDConfig.txt và các file cab vào trong thẻ nhớ trước. Mình làm sao biết các bạn thích gì? Hữu dụng là để anh em khỏi phải than là cài lại nhiều soft sau khi up rom. Vậy thôi. Ghi thế mà bạn không biết phải làm gì khi trong thẻ nhớ của bạn, bạn có cho gì vào đâu trước khi up rom:)) Đúng hem?
Tìm không ra nên sau khi Reset nó tắt Phone. Vì mặc định SDAutoRun tắt Phone cho đến khi cài đặt xong các file cab.
Còn biểu tượng PIN thì chọt vào vẫn lên nhưng lên cái của ROM gốc ATOM. =))
Túm lại, đây không phải là lỗi (bug). Nếu chỉ tương tự như vậy đã gọi là lỗi thì trong tất cả các bản ROM của mình còn khối thứ là lỗi.
Hi SonBlack,
I flash my xda atom with 20753 rom after that I have seen setting>system Info said "Rom 20060426B1CHT" but in your picture above, "Rom 200809C621WWE. What do i make a mistake? thank in advance.
Hi SonBlack,
So sorry, I made a mistake and now everything is OK if you download and flash again. Very simple, because I forgot adjust it. Once again, thank you. I know and repair it before you said. :D=D>
vậy muốn chỉ định cài file CAb nào đó thì làm sao ho SONBLACK?
Hãy tự tìm hiểu, mình chỉ đưa ROM không có thời gian chỉ dẫn mọi thứ. Hãy sang box Himalaya ROM của PDAVIET có giới thiệu bản 19949 có cái ExtendedROM và tải về mà xem và đọc các hướng dẫn ở đó. Như thế sẽ tốt hơn cho bạn. Link có ngay dưới chữ ký của mình đấy. Lưu ý ở đây chỉ nói về bản ROM, không hướng dẫn sử dụng. :D
Chúc vui.
