XDA ATOM EXEC - PDAVIET ROM WM6.1 (Core 19971)
Sonblack
Super V.I.P
PDAVIET ROM WM6.1
CE OS 5.2.19971 Build 19971.1.2.6 PV
=== Only for XDA ATOM EXEC ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Hoangdat_vista, TranMinhMan, Lamson
Trial Mod PhamNhatThanh, khacduy1978
VIP Medkid, nhocbanme
Many thanks to herg62123, poorlyduck, A_C and greatbal from xda-developers
Thông tin - ROM Information:
- CE OS 5.2.19971 Build 19971.1.2.6 PV
- Pagepool: 6M
- Rom date: October 14, 2008
- ROM Version: 20081014B5WWE
- Ported from latest original ROM of HTC Opal
- Transcriber included.
- Manilla 2D with Blue Skin also included.
- Remove all help files.
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- AudioManager v2.0.1819.2129 (HTC Opal)
- Audio Booster (HTC Opal)
- JBlend Java (HTC Opal)
- Outlook Enhancement (HTC Opal)
- Picture Enhancement (HTC Opal)
- Comm Manager v2.7.1.8 (HTC Opal)
- Manila2D v1.00.1819.2926 (HTC Opal)
ArcsoftMMS v5.0.31.50 (HTC Opal)
- S2U2 v1.22 by A_C
- ClearTemp v1.1 by Vicott Wong
- HTC Sim Manager for Pocket PC v6.57
- .NET Compact Framework 3.5.7283.0
- Office Mobile 6.1
- SunHigh Windows Media Player 10.3 Build 19971 (Mod)
- Advanced Configuration Tool v3.3.0.0 by Julien Schapman
- Task Manager v3.1 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.1.7.3 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- SDAutoRun v2.0 (automatic install cab files from Storage Card)
Extended ROM bao gồm các file sau (Extended ROM included the files as follows):
1. Album_2.0_1818.3032.cab
2. Album_Video_fix.cab
3. GoogleMaps_compressed.CAB (Mod)
4. Opera_v9.5_Build_2392_QVGA_WWE.cab (Mod)
Hướng dẫn - Guides: Vui lòng đọc kỹ - Please read carefully
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
ONLY FLASH ROM WITH OPTION "OS ONLY". THAT'S ENOUGH!
Để một số ứng dụng trong ROM có thể hoạt động tốt, bạn phải đặt thư mục Cabs và file SDConfig.txt (nằm trong file nén chứa ExtendedROM) trong thư mục gốc của thẻ nhớ trước khi up rom hoặc trước khi PPC reset sau khi up rom thành công.
In order to run well some utilities in my ROM, you have to put folder "Cabs" and file "SDConfig.txt" (ExtendedROM compressed file inside) in original folder of storage card before you flash the ROM or before PPC reset after flashing ROM successfully.
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Chúc vui!
Enjoy it!
Sonblack
Úi , Mình được bóc tem rồi . Mặc dù là dân tình của atom thế mà .... hihihi
Cám ơn a Sơn .
nhìn thấy thèm quá nhưng k sao tải ROM về đc vậy nhỉ, nhờ bác Sonblack chỉ cho E cái, cám ơn Bác nhìu
Quay lại lấy link từ bài đầu tiên nhé! Xong rồi! Cám ơn mọi người đã quan tâm.
Mọi người hãy đọc kỹ bài giới thiệu ROM, sẽ không là thừa đâu, mọi vấn đề liên quan đến việc up bản ROM này đã được đề cập, mình sẽ không trả lời các câu hỏi liên quan đến link và cách up rom đâu nhé!
bản rom này quả là quá tuyệt . em ngồi test mãi nhưng ko thấy có lỗi j cả....thank bác SonBlack
BÁC SƠN ĐỈNH NHẤT QUẢ ĐẤT,BÁC GIÚP ANH EM DIỄN ĐÀN NHIỀU QUÁ,KHÔNG CÓ BÁC CHẮC 1 SỐ DÒNG PPC MUA VỀ CHỈ ĐỂ NGẮM,CẢM ƠN BÁC SƠN RẤT NHIỀU
bác ơi cái program ít quá sao còn có hơn 9 m vậy
Bạn cài nhiều soft quá chứ gì, sau khi up rom và cài 4 file cab đã nói ở trên vẫn còn khá nhiều để chạy chương trình: Storage trên 78MB và Program trên 15MB.
có cach nào program lớn hơn không bác,hay có bản rom nào mà program lớn không bác,đúng là em cài nhiều soft lắm ,mà máy atom exec này có xài thẻ minisd 4g không hả bác
Cách duy nhất là đừng ham hố cài hầm bà lằn vào ROM, chỉ có vậy thui à!:D
Tôi đã up xong rồi. Chạy ngọt quá. Nhưng gắn Super sim của mobifone vào bấm kiểm tra tài khoản xong là nó báo mất sóng liền à.
Mới thấy bác có thêm bản rom mới. Để load về up xem sao.
Cám ơn anh SONBLACK nhiều nhé
Có cách Program lớn hơn là: đừng dùng TuochFlo 2D trong Today thì Program (Ram) tăng lên 20M chạy nhanh liền!!!!
