XDA ATOM EXEC - PDAVIET ROM WM6.1 (Core 20764)
Sonblack
Super V.I.P
PDAVIET ROM WM6.1
CE OS 5.2.20764 Build 20764.1.4.3 PV
=== Only for XDA ATOM EXEC ===
Lời cám ơn - Thanks:
Super Mod PhamQuang
Super Mod BatKid
Admin Kawaguchi
Adv. Mod Dvha79_ddt
Mod Lamson, TranMinhMan, Hoangdat_vista
Trial Mod PhamNhatThanh, khacduy1978, nhattoai
VIP Medkid, nhocbanme
Member demen72
herg62123, poorlyduck from xda-developers
Thông tin - ROM Information:
- CE OS 5.2.20764 Build 20764.1.4.3 PV
- Pagepool: 6M
- Rom date: December 28, 2008
- ROM Version: 20081228B7WWE
- Well supported A2DP
- Transcriber included.
- Manilla 2D with
Blue Skin also included.
- Remove all help files.
- XIP & SYS from original ROM of BlackStone
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- AudioManager v2.0 Build 1820.1321 (Elfin)
- Outlook Enhancement (Elfin)
- Picture Enhancement (Elfin)
- Comm Manager v2.7.2.8
- ArcsoftMMS v5.0.31.63 (Elfin)
- Enlarge Start Menu (Moderate from Elfin)
- Enlarge TitleBar (Elfin)
- YouTube v1.5.1820.2325 (Elfin)
- Manila2D from Elfin (Moderate)
- HTC Sim Manager for Pocket PC v6.58
- .NET Compact Framework 3.5.7283.0
- Windows Media Player 10.3 Build 20764
- Office Mobile 6.1
- Office Note
- HTC Album (Moderate from Elfin)
- Google Maps (automatically run)
- Opera Browser (automatically run)
- SIPChange (automatically run)
- Advanced Configuration Tool v3.3 by Schap
- Pocket RAR v3.80 by Alexander Roshal
- ClearTemp v1.1 by Vicott Wong
- PIM Backup v2.8.0.0 by FdcSoft
- Pocket Screen v1.3 by JJM. Roseboom
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.2.0.0 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
Hướng dẫn - Guides: Vui lòng đọc kỹ - Please read carefully
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn - The link is available now
DOWNLOAD ROM
UP ROM VỚI TÙY CHỌN "OS+ExtendedROM".
FLASH THE ROM WITH OPTION "
OS+ExtendedROM".
Chúc vui vẻ!
Enjoy it!
Sonblack
cám ơn ban rom mới của A.SƠN!
Năm mới chúc anh em em hạnh phúc-thành đạt.
Cám ơn nhé! Hôm wa tôi mở hàng rùi, bản cũ chưa sử dụng hết ,đã có bản mới rùi .Thiệt là Pro đó nghe!
Chúc Anh nhiều Sức Khỏe và Vui Vẻ!
Rom 20764 em up không được
nó báo lỗi: !!!Please use DSUU in OS mode and sync with PC first !!!
usb transfer fail
Có bác nào biết chỉ giúp em với.
Xin cảm ơn
usb transfer fail
Xin cảm ơn
Có thể do bạn chưa cài ActiveSyn trên PC:-?
Cũng có thể bạn up rom bằng cách vào bootloader của Atom Exec trước.
Thử uprom bằng cách connect với PC trực tiếp bằng ActiveSync đi bạn.
Mình xin hỏi mình đã up rom của bạn nhưng với các bản rom WM6 khác nhau khi mình bài bộ font tiếng Trung CE.Star.2.8 đều bị liệt cảm ứng, hard reset mới hết không biết tại sao? dù đã down version mới nhất cho WM6 trên homepage. Mong bạn xem qua xin cảm ơn
Bạn cho mình xin file cab của bộ font tiếng Trung đó nhé để kiểm tra.
Anh có thể hưỡng dẫn vào bootloader của Atom Exec cho em với
Em vào trực tiêp trên máy tính uprom xong vân phiên bản cũ. Anh có cách nào khác không.
Em xin cảm ơn
Boot loader
Em xin cảm ơn
Bạn nhấn phím camera và Power cung 1 lúc, sau đó lấy bút chọc đít 1 cái là vào Bootloader ngay.
Tuy nhiên theo kinh nghiệm của tớ thì tình trạng của cậu không phải do up trực tiếp mà do cậu không giải nén File vào thư mục: C:/windows/temp và up từ đó nên bị như vậy. Túm lại phải giải nén vào đó rồi Up thi máy sẽ báo phiên bản chính xác. Lưu ý, trước khi giải nén thì bạn nên vào thư mục C:/windows/temp và xóa hết những gì của bản Rom mà lần trước bạn up đi.
Chúc thành công!
Bro Sonblack ơi up rom của bro cài thêm chương trình hỗ trợ chơi game flash thì màn cảm ứng không dùng được nữa đành phải gỡ đi !!!!!!!!!!!
Có lẽ ctr TouchFlo bị đụng với ctr Flash Player bạn àh!:D Nếu thích dùng touch có lẽ phải chấp nhận vậy!:p
Bạn ơi mình post link rồi đó bạn chek dùm chưa vậy mong bạn chiếu cố dùm, với mình thiếu mỗi bộ font này là mãn nguyện với công việc rồi công thủ full:D
:D Chờ mãi không thấy đâu! Còn bây giờ thì con Atom của Sonblack đã ra đi ròi. Lấy gì mà làm ROM đây :(
Hix bác coi lại dùm post link ngay sau đó chắc tại bác không để ý... thế có khộ tôi không!
i can't update my weather through gprs? how to fix this? thanx.
i've fix this problem.
Bác Sơn ơi, bác up lên link khác giúp em với được ko? Cả tháng nay trang mediafire có vấn đề rồi, lúc nhanh, lúc chậm. Em dow 2 cái ROM 20954 và 20764 của bác từ 5h chiều hôm qua đến bây giờ mà mới được có 20% nè :(:)(:)((
Để máy chạy online cả đêm luôn, đến giờ vẫn chưa tắt mà ko thể nào dow xong được. Hic
quá pro. em rất thích bản này, cảm thấy bản này hài lòng hơn mấy bản màu đen kia. có chức năng kéo như Iphone.
Ngàn lần cảm ơn bác Sơn nha :D:D:D
