XDA ATOM EXEC - PDAVIET ROM WM6.1 (Core 20954)
Sonblack
Super V.I.P
PDAVIET ROM WM6.1
CE OS 5.2.20954 Build 20954.1.5.0 PV
=== Only for XDA ATOM EXEC ===
Lời cám ơn - Thanks:
Super Mod PhamQuang
Super Mod BatKid
Admin Kawaguchi
Adv. Mod Dvha79_ddt
Mod Lamson, TranMinhMan, Hoangdat_vista
Trial Mod PhamNhatThanh, khacduy1978, nhattoai
VIP Medkid, nhocbanme
Member demen72
herg62123, poorlyduck from xda-developers
Thông tin - ROM Information:
- CE OS 5.2.20954 Build 20954.1.5.0 PV
- Pagepool: 6M
- Rom date: December 29, 2008
- ROM Version: 20081229B8WWE
- Well supported A2DP
- Transcriber included.
- Manilla 2D with
Blue Skin also included.
- Remove all help files.
- XIP & SYS from xbeta.cn
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- AudioManager v2.0 Build 1820.1321 (Elfin)
- Outlook Enhancement (Elfin)
- Picture Enhancement (Elfin)
- Comm Manager v2.7.2.8
- ArcsoftMMS v5.0.31.63 (Elfin)
- Enlarge Start Menu (Moderate from Elfin)
- Enlarge TitleBar (Elfin)
- YouTube v1.5.1820.2325 (Elfin)
- Manila2D from Elfin (Moderate)
- HTC Sim Manager for Pocket PC v6.58
- .NET Compact Framework 3.5.7283.0
- Windows Media Player 10.3 Build 20954
- Office Mobile 6.1
- Office Note
- HTC Album (Moderate from Elfin)
- Google Maps (automatically run)
- Opera Browser (automatically run)
- SIPChange (automatically run)
- Advanced Configuration Tool v3.3 by Schap
- Pocket RAR v3.80 by Alexander Roshal
- ClearTemp v1.1 by Vicott Wong
- PIM Backup v2.8.0.0 by FdcSoft
- Pocket Screen v1.3 by JJM. Roseboom
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.2.0.0 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
Hướng dẫn - Guides: Vui lòng đọc kỹ - Please read carefully
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn - The link is available now
Link nằm trong file đính kèm ở cuối bài - Link put under attached file at the end of this post
UP ROM VỚI TÙY CHỌN "OS+ExtendedROM".
FLASH THE ROM WITH OPTION "
OS+ExtendedROM".
Chúc vui vẻ!
Enjoy it!
link bên mediafire đó anh, Báo lỗi ! Thank
(When a file is set to private by its owner only the owner of the file can access it. If you are the owner of the file please log into your account to access this file.)
Mình đã kiểm tra mọi thứ lại lần nữa, tất cả đều OK bạn à!
Hãy thử lại các bạn nhé và phản hồi để còn biết :D
link down vẫn bình thường , mình vừa down xong
Uh link vẫn bình thường, tải vù vù,
thỉnh thoảng dùng IE vào mediafire lỗi thì chuyển qua dùng fireFox đi, đợt gì mình cũng bị, chuyển sang fireFox cái ok liền!
Test thui test thui! chắc bản rom này ko vẫn đề gì nữa rùi!
Thực sự thì vẫn thích dùng cái HTC home hơn!
potay.com rùi A.sơn ơi! up rom xong xuôi máy khởi động lại , đến muc cleanup rùi đứng ngó luôn đến giờ, tôi đã chọt nút khởi động lại, chỉ thấy cái hình O2 đẹp dễ sợ nhin tôi thui a?
Mong Anh chỉ giáo, cám ơn rất nhiều!
Không được thì Hard Reset bằng tay, xong ngay thôi. :))
:D được rùi Anh ơi! đang check thử đây! ,thấy dung lượng có ít hơn ko biết có khác nhiều ko?
Ủng hộ Anh Son nghe =D>
Xin trân trọng cảm ơn anh SON!
Em vừa mới test bản 20764 nhưng có vẻ vẫn bị lỗi Reset vài lần mới được, bản này tối nay em sẽ thử và hi vọng là ngon. Nhưng cho dù thế nào đi nữa thì em rất khâm phục anh=D>
test sơ sơ rùi, nhìn chung chạy mượt, không khác nhiều so với các rom trước nhưng nó có mấy vấn đề như này:
Muốn mở cái thông báo tin nhắn mới, sóng, pin, chỉnh âm lượng trên task bar, ấn vào cái Taskbar nó lại hiện ra cái system status, lại phải thêm 1 thao tác nữa, hơi bất tiện!
Cái SMS/MMS thay vì thông báo đã gửi tin nhắn thì nó lại request tổng đài gửi lại tin nhắn báo là đã gửi, lại phải đi xoá, vào mesage option thì không thay đổi được tùy chọn này, trong setting cũng không có cái mục SMS/MMS viewer nữa nên ko chỉnh được cái này, cũng ko được tiện lắm
Bị một cái giống một số rom trước là khi nghe nhạc bằng WMP thì lúc bắt đầu vào bài hát vài giây nó hay bị dừng lại 1 lúc để buffering, ko hiểu cái gì bị làm chậm mà lại phải buffering thế nhỉ?
Cái menu start trông nó không được ổn lắm, vừa to vừa ...ấy, không lưu được nhiều cái recent
Không có cái "Network Wizard for PocketPC v1.0 để cài GPRS"
Cái
Thanks for building rom cho anh em!
tình hình là vẫn còn bị lỗi reset pác SonBlack ạ, sau khi up xong thì phải reset vài lần mới được, trong khi sử dụng reset đôi khi bị dừng luôn ở cái màn hình O2 ban đầu, phải chọc reset vài lần mới được. Mình đang down lại file rom và sẽ up OS Only xem sao.
Ngoài ra thì bản rom chạy mượt mặc dù lượng ram còn lại khá thấp, chỉ 15Mb
Nhưng trên hết, năm mới, chúc sức khỏe pác và liên tục cho ra lò những bản Rom mới pác nhé! =D>
Đây là những điều sơ đẳng mà người dùng bất kỳ dòng PPC nào cũng phải biết. Vì vậy nó chẳng là vấn đề hay gì gì cả mà chỉ vì bạn là người mới, vì vậy, hãy tự tìm hiểu trên diễn đàn có đủ hết để xử lý. Hơn thế nữa, trong bất kỳ ROM nào của Sonblack cũng đều có các ứng dụng cơ bản hỗ trợ việc này.
Túm lại, hãy vọc ROM nhiều và cũng phải đọc nhiều để có thêm nhiều điều mới. Hãy tùy chỉnh như ý mình bằng các công cụ sẵn có. ROM chỉ mang đến những điều cơ bản chung cho nhiều người dùng. Mỗi người sẽ lại tùy chỉnh theo ý mình. Mình Sonblack không thể đáp ứng cùng 1 lúc nhiều yêu cầu khác nhau cho chung một vấn đề.
Network Wizard có sẵn, cũng chạy tự động và dữ liệu của nó được đặt trong ExtendedROM. Vì vậy nếu bạn không up rom với tùy chọn "OS+ExtendedROM" hoặc "All" thì nó cũng không hoạt động. Bạn không làm đúng hướng dẫn của mình rồi còn gì.
Đây mới là cái mình cần khắc phục. Đúng như bạn nói. Lý do vẫn chưa thể khắc phục được điều này vì mình không có máy, thỉnh thoảng anh em cho mượn thì build luôn mà thôi.
Sẽ cố gắng khắc phục nếu có máy trong thời gian dài.
Chúc vui.
Như vậy là nhưng vẫn đề này trong cái rom nó có sẵn hết các thứ để chỉnh hết à? Khổ wa' mới vào không biết gì mà, tìm chỉnh mãi trong cái "Advanced config" cả Registry Editor mà chẳng có chỗ nào chỉnh mấy cái này cả!
Vấn biết là không chọn "OS+ExtendedROM" hoặc "All" thì sẽ không còn cái ExtendedROM nhưng để "OS only" thì cái ExtendedROM cũ từ trước vẫn còn nguyên, liệu bây giờ mình up cái bản rom 5 gốc của O2 sau đó mình úp tiếp bản rom này để "OS only" thì sẽ được 1 bản rom "tinh khiết" phải ko?
