XDA Mobile 6 Release 2 (Lite and Full Versions) - Taking You to the Limit
digikni
[WM6] XDA Mobile 6 Release 2 (Lite and Full Versions) - Taking You to the Limit
Copyright by mfrazzz
XDA Mobile 6 Release 2 (hay XM6r2) là phiên bản tiếp theo của bản XDA Mobile 6 cho dòng Wizard. Được sửa một vài lỗi và cập nhập các ứng dụng có trong phiên bản đầu tiên.
XM6 được xây dựng dựa trên bản ROM OS 5.2.318 Build 15342.4.0.01 rom được cung cấp bởi InGeNeTiCs từ Howard Forums. Một khác biệt lớn giữa bản original Release và Release 2 chính là phiên bản của ROM, SYS.
Base ROM Information
The base rom was an "Official" Wizard WM6 ROM that was part of the development cycle of WM6 inside of Microsoft (Dogfood as they call it). The base rom was not a port of another device rom with drivers and stuff pieced and parted onto this one, but this was an actual Wizard WM6.
* Windows Mobile 6, OS 5.2.318 Build 15342.4.0.01
* ROM Version: 10.1.0.811 WWE
* ROM Date: 08/11/06
* Protocol: 4.1.13.09
There is no Radio, IPL, SPL or Extended ROM.
What's In XDA Mobile 6 Release 2?
* Office 2007
* New 8 Button "Touch" Style CommManager (yeah only 8 buttons. If you want more then install one of the many 10 or more button ones )
* VoIP (See next post for instructions to set this up)
* SQLCE
* HTC X-Button v1.0
* Notepad editor
* Pocket RAR (ROM already has associations with .rar and .zip setup)
* SIP Config 2.0.1
* SynchroTime
* Total Commander Beta 2.5
* PIM Backup to 2.2
* Windows Live Search searches via Google
* WM5torage 1.75
* SIM Manager 6.13
* psShutXP (icon setup in the sys tray)
* dotFred TaskManager (with registry editor link setup and associations built in for .reg files)
* Regional Settings default to English (United States) and use a slash for the date seperator (M/dd/yyyy)
* Menu sounds work by default
* Pressing the "End Call" button does not disconnect GPRS but minimized the active application. Pressing and holding the "End Call" button for about 5 seconds will do a GPRS Disconnect
* Internet access over ActiveSync (USB) connection works (You must apply a registry fix on your PC first. See the next post for the fix)
Bản Full Release có thêm các phần mềm
* mUn designed onscreen Keyboard skin (grey/green one)
* Mobile Justice (a security app that will send an SMS if an unauthorized SIM is placed in your phone)
* TodayAgenda
* StartClean
* Pocket Screen Capture
* HTC Audio Manager
* CicleBT (Toggle BlueTooth on and off)
* 1-Calc Lite
* WiFiFoFum 2.2.9
* MoDaCo NoData (so you can turn off data sources)
* Smartskey 0.56 (DPAD is set to 0 in the .ini so the up and down scrolling works in the Phone dialer as expected in WM6)
* SMSDRFix
* DotFred's SoftKeyAppletEx
Yêu cầu
* bạn PHẢI có phiên bản IPL và SPL là 2.xx hoặc cao hơn.
* ban PHẢI chạy bằng ActiveSync 4.5 trên Windows XP.
Trước khi bắt đầu tiến hành việc up ROM. Hãy đọc kỹ các chủ đề trước về cách flasf ROM, CID unlock, và cách giải quyết các lỗi thường gặp.
Khuyến cáo
* bạn NÊN flash lại bản ROM official trước khi bắt đầu nâng cấp bản ROM này hay bất cứ bản ROM được chỉnh sửa nào khác. Bạn có thể dùng bản T-Mobile 2.26.
* Nếu bạn sử dụng BatteryStatus (nó không được tích hợp trong bản ROM này) để overclock, không nên để mức quá 260Mhz, và cài đặt CPUscaler trong BatteryStatus không nên để thấp hơn mức 143MHz.
* bạn NÊN dùng bản radio T-Mobile 2.19 UK (this is a must for Cingular/AT&T customers). bản radio mới hơn có thể làm bạn mất cuộc gọi và tin nhắn. Tuy nhiên, nếu bạn dùng bản radio mới hơn như 2.61 hay 2.69, bạn nên cài file sửa lỗi ở file đính kèm ở dưới
Credits
I would like to thank the following in help (directly and indirectly) with XDA Mobile 6:
* Faria for providing the initial ROM Kitchen that got me cooking
* anichillus for the fantastic Core ROM Kitchen which was exclusively used in the production of this ROM
* Dr Puttingham for the guides, information and giving me a pointer to the cool 8 Button CommManager in this rom
* Molski for having a nice tutorial on various cooking tools and providing easy access to info at http://www.molski.biz
* mattk_r for inspiration and pushing the envelope and for the fantastic set of OEM packages
* Those that took the time to help beta test XM6 Release 2. We worked out a number of issues with a nice long beta test!
* Everyone that installed and gave feedback and support on the original XDA Mobile 6 thread
* Everyone that I thanked in my other ROM releases!
Và cuối cùng, đây là link để download
Full Version
SendSpace
RapidShare
MegaUpload
Lite Version
SendSpace
RapidShare
attachment.php
source: http://forum.xda-developers.com/showthread.php?t=315178
