Zinc WM6.1 CE OS5.2.19202
ecoli
Một ROM khác của tác giả cruzzmz từ http://forum.xda-developers.com
Xin đọc bài #3 để có link download.
Mời các bạn xem một vài hình ảnh:
Boot Screen & About Screen
Theme (Aurora)
GoodBye Screen
Các điểm mới và các lỗi đã fix
Xin được trích dẫn nguyên văn (từ từ mình sẽ dịch sau):
Known Bugs (Till now)
Accheck Error after boot ---> Pls Install accheck.cab
For Network setting (MMS,WAP) pls use the cab @ Network settings
News Update
26/05/2008
The fastest way that I can do a rom, patched the 19202 CHT xip on the Lite version ... Hopefully everybody will be a lill bit happier :D
01/05/2008
19202 Rom Based on Lite Rom with NO Autoconfig, T9 & spbZip, Ext rom removed. Still using old Goodbye screen. Total storage around 42Mb
Better hv a card reader around in case u encounter poutlook error at startup ...
22/04/2008
I still got poutlook error ... still troubleshooting on it .... and now i am getting busier with my job
16/04/2008 MYT:1.51
Rom Released (based on Lite Rom).<--- Got Error :(
13/04/2008
Here is the deal ... autoconfig removed, so anybody wants MMS setting etc hv to do it manually.
13/04/2008
Still stuck with autoconfig wont work problem ....
Other than that almost a week wzout any major issue
So if u can live wz out network setting such as MMS, WAP & browsing, then I will post it
09/04/2008
2 days on new rom wzout any hangs & major problem :D
07/04/2008
Done new theme (aurora) for the new build
06/04/2008 MYT-3.30
I think I have succeeded in porting the Big Storage Lite version Rom from ver CE5.2.1437 to CE5.2.19202. Will test the stability for a few days then I will post the rom links.
Wish me luck ;)
Download links
Xin được trích nguyên văn (từ từ mình sẽ dịch sau):
WARNING: Flash at ur own risk !!!!!!!
Pls make sure u hv a card reader at hand, in case of a poutlook error. Copy back the working rom & Flash back ur Zinc
Using the base of Lite Rom. Wzout Autoconfig & Ext Rom. Free space: plus minus 40-42Mb
Pls post comments & screen shot of
1) About screen
2) System Info, Version Tab
3) Memory Storage
Happy Flashing :D
19202 Lite XIP Patch Version
Based on Lite rom which i patched the CHT 19202 xip on it.
This was the fastest way to do it & coz of no time to cook a new one :(.
After flashing, the auto config will show blank for operator, Tab on cancel.
If u need the setting, u only need to install Network Setting cab
MediaFire
19202 XLt
Based on Lite with NO AutoConfig, SPBZip, T9 .... wz original GoodBye screen & themes.
Pls install accheck.cab below for no accheck error after flashing ur Zinc with the new rom
RapidShare
MediaFire
Pls Install after flashing --> accheck.cab
Ext Links
GoodBye.gif <-- for goodbye screen
Aurora tsk <-- for Aurora Theme
Network MMS,WAP Setting cab<--- for Network MMS,WAP Setting
1) About screen
3) Memory Storage
Happy Flashing :D
MediaFire
19202 XLt
RapidShare
MediaFire
Ext Links
anh có up rom này chưa vậy,xài ổn định không anh:-?:-?:-?,em không dowload được ở trang (http://forum.xda-developers.com/showpost.php?p=2152683&postcount=70)
Bác nào có link của bản rom này up lại cho anh em xài ké với,em lục tung cả cái google lên mà toàn link cũ nên die hết cả.
Các link từ mediafire vẫn tốt mà bạn.
