[13/03/2013] ViperDHD v2.1.3 | Android 4.0.4 | Sense 4.1
hacbaoklhh
[video=youtube_share;Crb2no38gxY]http://youtu.be/Crb2no38gxY[/video]​
Thông tin bản ROM
Based on Android 4.0.4 + Sense 4.1
Deodexed & Zipaligned SDK r20
Persistent ADB enabled
Init.d support
Busybox
Memory optimizations
Ramdisk Tweaks
Venom Tweaks - HUGE collection of customizable tweaks
Venom HUB! - download themes/read news/send feedbacks directly from your phone
Venom OTA! - recieve automatic viper rom updates
Extended Quicksettings
Advanced Power Menu
CM statusbar brighntess mod
Disabled dtm and fast dormacy, possible battery drainers
Added secure and blocklist folders to message app
All Market apps Updated to latest
Latest hosts file (Adaway)
Choose between Apex or Nova launcher in desense
Venom File Manager
Custom Venom Package Installer
Custom Venom Download UI
Thông tin Tweaks
Statusbar:
Rearrange and hide Quicksettings
Quick quicksetting
Statusbar theming support - theme each icon individually!
Hide specific notifications icons
Battery Tweaks with MIUI Battery bar!
choose custom clock color
center/hide clock
hide am/pm
custom app for clock/weather click on Sense Clock widget
Carrier logo for statusbar
Replace the HSDPA icon with one of you choice. H+/4G/LTE...
choose transparancy or background for notifications pulldown
CM brighntess control
Hide date from notifications pulldown
Customize your carrier label
- custom app on pressing carrierlabel
- custom carrier caption
- show carrier icon
- show cpu info or other stuff on carrierlabel
- hide settings icon
- run custom app when pressing settings icon
choose between AOSP and Sense Recent apps dialog
Rosie Launcher:
Ultra/smooth Rosie toggles
Enable unlock animation
Enable landscape rosie
Enable infinitive looping on Home
Lock/unlock workspaces
Transparent navbar
Disable wallpaper scrolling
Choose icon packs for Rosie - Works also for most ADW Icon Packs!
Increase rows/colums in app drawer to 5x6 and 7x3
Use custom background image in the app drawer to downloads tab
Transparent clock toggle
custom app for press on clock of htc clock widget
custom app for press on weather of htc clock widget
Lockscreen:
ICS AOSP Lockscreen
Toggle to immediatly unlock aosp lockscreen on incoming call
custom carrier lockscreen text
Hide time on lockscreen
Hide apm/pm on lockscreen
Hide date on lockscreen
Hide operator on lockscreen
Custom shortcuts, independent from Sense shortcuts
Block notification pulldown on lockscreen
Choose back/home/menu to unlock
Slide 2 unlock: swype from back to menu key to unlock yor device
Buttons:
Custom 3 finger swype gestures! Remap 3 finger swype up/down right/left to 8 custom action or a custom app of your choice
Configure long press delay of buttons
Different capacitive backlight options to control when the leds shall turn off
Toggle for 3 dot soft menu
Remap longpress home/back/recent to TEN different actions
Longpress home on lockscreen toggles flashlight or camera
Music control with volume buttons
Disable volume keys on lockscreen
Use volume up to wake the device
Use volume down to shut screen off
use volume buttons to take a picture + headsetkeys
use capacitive buttons to take a picture
Disable volume sound when pressing volume buttons
Others:
Access hidden phone menu
Enable Cube animation
10 Different overscroll colors
Highly configurable autobightnesssettings, witth manual config of each sensor value
Hide different items on the APM
Mms screen on
Custom HTC Car app
Fast dormacy toggle
Disable HTC SmartSync
Hide arrows on htc ime
Advanced Tweaks:
Minfree configuration in tweaks
Fix permissions
zipalign apks
Mount system rw/ro
Disable logcat
Wipe cache/dalvik
Use custom fonts
Use custom bootsound
Use custom boot/downanimation
Changelog
ViperDHD v2.1.3
Fixed Venom HUB FC
ViperDHD v2.1.2
Fixed all remaining translation issues (really now!!) (mygamers)
Added option for Enhanced Sense 4+ Camera by lyapota resized from One X
New Pacha kernel as default kernel
Fixed that AROMA extracts wrong gps.conf
Fixed Venom SuperUser
Fixed Auto Brightness
Removed option for choosing kernel (caused some issue)
Added option for evernotes app as play store one does not work (Saluco)
Fixed OTA popping up even if on latest version
Other small changes performance related!!
(Full WiFi bar and touchscreen (lockring not following finger) is kernel issue, try others if it is not good for you)
No OTA for this one, I do this that all users are again on a clean base because many flashed patches from the thread etc. (easier for tracking bugs!)
ViperDHD v2.1.1
Fixed Music App
Fixed Weather
ViperDHD v2.1.0
Venom Equalizer: 20 different sound enhancers
Improved sound quality
Fixed DLNA FC
Fixed Auto-Brightness (after applying it needs reboot)
Fixed Translation bug for:
- Clock
- Connection to PC
- Contacts
- Dialer
- Sound Recorder
- Phone
- Wifi Hotspot
Added Smart Dialer in Dialer
Added option to sort contacts by last name
Added option in AROMA to choose between new BeastMod and Pacha Kernel (Full ROM)
Fixed Inspire 4G sound issue (Full ROM)
New Venom File Manager
New App Installer App:
- On fresh install added ability to skip scanning apps
- Fixed FC when rotating
New Venom HUB: Fixed FC when rotating
New VenomSuperUser: Bug fixes
ViperDHD v2.0.0
Totally rebuilt from scratch with latest tools
Ported these Sense 4.5 apps and hacks from HTC One X (3.14 base):
Gallery with TimeLine View and Map View from
Browser with some extras
Keyboard (with Arrows)
Message app:
- Changebale bubbles styles and backgrounds of message app(Settings->Main->Personalize or Open message->Menu->Personalize)
- Toggle between smiles panel button(new style) and attacments button(old style) in tweaks
- Option to turn off notifications for delivery reports
Dropbox player with lockscreen control: Play music directly from Dropbox
Music lockscreen
Battery stats & Battery Info
Powersaver:
- 10 options to toggle in powersaver(instead of 4 in original Sense 4.5)
- Toggle for add/remove notification(Sense 4.5 dont have it)
- Auto turn on power saver setting(Sense 4.5 dont have it)
- Horizontal powersaver quicksetting
- Vertical powersaver quicksetting
App Manager
FM Radio
Rosie:
- Partly merged with some Sense 4+ hacks
- 4x1 widget into statusbar bug fixed
- Fixed some minor resizing issues which were present
Totally new SystemUI (Statusbar) with some fixes and graphic optimization
New Statusbar tweaks
Added tweak to force enable WiFi N support
Added tweak for slide2unlock
New remapping of buttons
Added tweak for disable volume sound
A few other tweaks I can't remember, just play with the tweaks app a bit
Fixed Sense Recent Apps having bad quality
Improved Camera
Fixed HDR
Fixed Panorama
Added option to control sweep2wake behavior (no kernel supports it yet but one is coming soon!)
Cleaned Locations App and fixed some stuff
Cleaned up APM and EQS icons
Fully merged with 4.0.4 Ville C2 Base
New libs for better battery life!
Added Virtuous Widgets compatibility
New Lockscreen tweak (choose position of lockring):
- left
- right
- arc
- normal
Fixed, cleaned up and updated IdleScreen_Base (Music and no lock option)
Fixed messages dont save preview lines setting
Fixed font size not saving in messages app
Fixed cold condition animation in weather wallpapper
Fixed all sound enhancers and improved quality:
- Fixed Beats Audio
- Fixed WOW SRS
- Fixed Voice
- Fixed HTC Enhance
- Fixed HTC 5.1
- Fixed Classic
- Fixed Bass
- Fixed Custom Enhancer FC
Fixed BT-A2DP HeadSet
Fixed all other sound effects and enhancers
Fully fixed HTC DockMode (HTC One S port)
Updated VenomSuperUser
Updated Venom Package Installer
Added create button in downloads UI, now you can directly add downloads by URL
Updated Venom HUB (Add-ONs section)
Updated Venom Beats Notify
Updated all third party apps
Other changes
Link download
Nguồn: xda-developers
Bản Rom này tôi thích thật, có nhiều lựa chọn..., đã loại bỏ được lỗi tự động phát loa ngoài khi thực hiện cuộc gọi, loại bỏ các phần mềm không cần thiết trong các bản Rom khác.
Có vẻ hơi chậm, không mượt bằng 6.3.3, Beats Audio chỉ là bình thường trong DHD, nhưng cuối cùng tôi thấy bản này là OK, đáng dùng. hết.
Tình hình pin sao bạn?đang muốn test bản ROM này.Thanks
Nếu vọc nhiều: khoảng 1 ngày còn 20%-15%
Nếu gọi nghe, nhắn tin; chat, lướt web khi nghỉ trưa: khoảng 2 ngày.
Thông thường DHD tối nào tôi cũng sạc, đến ngày hôm sau dùng thoải mái hơn.
Tình hình là lỗi như thế này: Vào TinNhắn ->Menu->cài đặt thì bị lỗi làm out messages luôn.
Ai biết cách khắc phục không nhỉ,không vào cài đặt tin nhắn được.
Thanks!
Thanks!
Bạn thử khởi động lại máy xem có hết lỗi đó không nhé. Nếu không hết thì full wipe rồi cài lại rom.
bản này thật ok .vào phần cập nhật phần mền là máy tự tải và tự động cài đặt thôi .thật tuyệt vơi.
Có bạn nào test camera trên rom chưa vậy? Thấy ok không các bạn?
Camera working perfect. Ảnh chụp tầm 4mb 1 chiếc. Trừ nhận diện khuôn mặt, nụ cười ra tất cả ngon lành cảnh đào
sao tôi chụp thấy vẫn chưa ok lắm mặc dù t chụp ở ngoài trời với ánh sáng đầy đủ mà. Sensor camera của các bạn là gì vậy
