SẮP RA BẢN NÀY: DL DesireZ v4.3, CHẮC NGÀY MAI LÀ CÓ
This is a very excited release, we spent so many time on making the new init, now, it eventually works, thanks for freak again.
new features for SuperInit v4.4 -- Buildin with IMG/EXT4/RAM support
--- by default will create a 16M RAMfs and use it as app_cache and cache.
--- once set the ram_data=1, will move the dalvik-cache of framwork into RAM
--- to roll back to normal status, use the ram_data=11
-- Optimize the nand_data, which will also be able to move the dalvik-cache of framwork into Nand.
-- add new backup_img=2 to back apps from data, which is used for changing the build, the backup_img=1 will back up the whole data, once restore to a new base, will incur the UID inconsistent issue. should use restore_img=2 to restore.
-- add more function for repair_mode
-- repair_mode=1 will rescue the data partition.
-- repair_mode=2 can use the MAGLDR load system to repair the Nand system and mount the Nand system to /mnt/rescue
-- repair_mode=3 will reset the system, all the modified app, framework, lib, fonts that caused the issue will be removed, system will be reset to the origin without losing data and settings.
-- Auto detect the phone modal(EU or TMOUS)
--- for EU modal, will auto enable the data.img if the 2nd partition can not be found.
--- for TMOUS, if doesn't have 2nd partition and set the data_img=1, will auto bypass all the relative code to reduce the boot time.
-- Auto detect the boot mode (SD/MAGLDR/NAND)
--- auto select the best configuration for each boot mode
--- for SD, no need to apply the mobile data fix anymore (need test)
-- Auto partitioning the SDCard if set the format_ext4=9 (need test)
-- Fixed a lot of bugs in previous version.
Features:
- base on the newest DesireZ 1.85.73.2
- modified with full languages and locations.
- add battery percentage.
- equipped with DL SuperInit v4.4
- equipped with freak kernel v1.3
- all work and more smooth.
- improved battery life
Chagelog:
- Recreate the build.
- Added the advanced power menu.- Added launchkey customization.
- Tuned the system performance again.
- Fixed many defects.
