BLACKSTONE - PDAVIET ROM WM6.5 (Core 23518) by T2M
TranMinhMan
Super V.I.P
PDAVIET ROM WM 6.5 CE OS 5.2.23518 Build 23518.5.5.0
By TranMinhMan
*** Only for HTC Blackstone ***
Đặc biệt cảm ơn - Special thanks to:
Man PhamQuang
Adv Mod Sonblack
Hình ảnh ROM - ROM Images:
Thông tin bản ROM - ROM Informations:
- CE OS 5.2.23518 Build 23518.5.5.0 PV.
- Dựa trên nền Rom Ship mới nhất của BlackStone 1.59.841.5
- Base on the latest BlackStone Rom Ship 1.59.841.5.
- Tích hợp phần lớn các OEM mới nhất từ Rom Ship HTC Leo, HTC Rhodium và HTC Topaz.
- Plug in almost the latest OEM from Rom Ship HTC Leo, HTC Rhodium and HTC Topaz.
- Pagepool 17Mb
- Manila_2_5_19222911_0
- NeoS2007_Driverpack_3
- Advanced Configuration Tool v3.3.0.0 by Julien Schapman
- ClearTemp v1_2_3 by Vicott Wong
- dotFred Task Manager
- e-Natives WM6.5.x Position Fix
- G-Watch_0_6_4 by ageye
- HTCPedia HD Settings Tool by Tom_codon
- htcAddicts cleanRAM v1.9.3 by ronenpg
- Office Mobile 2010 v14.0000.23518
- Opera Mobile 10 beta 2
- PIM Backup v2.8.0.0 by FdcSoft
- PocketNotepad v4.0.10 by Tilanosoft
- PocketRAR v3_91b1
- PocketScreen v1.3 by JJM. Roseboom
- Slide2Shutdown v1.1 by Cythrelo
- Synchro Time v0.95 by Dennis Grachov
- Total Commander CE v2.52 beta 2 by Christian Ghisler
- WM 7 Titanium Project by Ibrythill
- amarullzGreenBlack theme.
- m_carroll PureBlack3 Installer (W)VGA
- WMP12 WVGA skin by BOGYSOFT
- Some small games.
Part 1
[DOWNLOAD]http://www.4shared.com/file/191583586/2fdf3c86/BLACKSTONE_-_PDAVIET_ROM_WM65_.html[/DOWNLOAD]
Part 2
[DOWNLOAD]http://www.4shared.com/file/191601678/515442f3/BLACKSTONE_-_PDAVIET_ROM_WM65_.html[/DOWNLOAD]
[PASS]TranMinhMan[/PASS]
Another great rom from Pdaviet.
I'm still trying the PhamQuang v88 (which work right !) but after, i will try yours !
Thanks TranMinhMan !
Hi TranMinhMan,
Can it show Chinese correctly like "PDAVIET ROM WM 6.5 CE OS 5.2.28014 Build 28014.5.5.0"?
I still downloading, like you ROM much more than other.
Thanks for you hard work.
Tested, it can show correctly at the dialing screen, Thanks
Bác có thể Up lên mediafire đc ko?Ở đó nhanh và hầu hết anh em download đều tốt.Bản ROM của bác nhìn đẹp quá ^^!.
Cám ơn ná
Ok, i have this rom and it works great EXCEPT in some applications the touch screen doesnt work.
One example is file explorer where tapping on folders doesnt make any response. I know i had similar
problem with one of roms on xda-developers.com but i cant find it. There was also a solution for a problem.
Anyway, great rom... just fix it ;)
Vẫn là bản ROM tốt, bổ sung Tab Documents trên Home, bộ Office Mobile 10 với cả OneNote.
Hi
i got this rom and works very nice i am very happy with it but i got 2 bugs i am not sủe ì these are bugs or not but here they are:
rotation not working in music and image tabs or better to say auto rotation not working at all
when i receive a call display not covering all screen so some part of home background is visible
Thử UP từ thì cái tab DOCUMENTS của ROM này vẫn bị treo mổi khi mở file từ thẳng trong Home Screen. Ngoài ra YouTube không chạy được, báo VIDEO can not play.
Có bác nào bị giống mình không?
Tab Document trên Home Screen của mình, khi duyệt preview các văn bản như doc hay pdf rất tốt, nhưng khi mình mở xem thì treo cả máy. Chả hiểu sao
