BLACKSTONE - PDAVIET ROM WM6.5 (Core 23568) Manila 2.5.2012
TranMinhMan
Super V.I.P
PDAVIET ROM WM 6.5 CE OS 5.2.23568 Build 23568.5.5.0
By TranMinhMan
*** Only for HTC Blackstone ***
Đặc biệt cảm ơn - Special thanks to:
Man PhamQuang
PV Award Sonblack
Hình ảnh ROM - ROM Images:
Thông tin bản ROM - ROM Informations:
- CE OS 5.2.23568 Build 23568.5.5.0 PV.
- Dựa trên nền Rom Ship mới nhất của BlackStone 1.59.841.5
- Base on the latest BlackStone Rom Ship 1.59.841.5.
- Tích hợp phần lớn các OEM mới nhất từ Rom Ship HTC Leo 2.11.531.T1 TMOUS WWE, HTC Rhodium, HTC Topaz.
- Plug in almost the latest OEM from Rom Ship HTC Leo 2.11.531.T1 TMOUS WWE, HTC Rhodium, HTC Topaz.
- Pagepool 17Mb
- Manila 2.5_20121412_1
- NetCF 3.7.8345.00
- Office Mobile 2010 v14.0000.23568
- NeoS2007_Driverpack_3
- Advanced Configuration Tool v3.3.0.0 by Julien Schapman
- ClearTemp v1_3 by Vicott Wong
- ChangeScreen v2.78 (config sensor autorotate screen)
- dotFred Task Manager
- e-Natives WM6.5.x Position Fix
- htcAddicts cleanRAM v2.2 by ronenpg
- HTCPedia HD Settings Tool by Tom_codon
- Opera Mobile 10 Final
- PIM Backup v2.8.0.0 by FdcSoft
- PocketNotepad v4.0.10 by Tilanosoft
- PocketRAR v3_93
- PocketScreen v1.3 by JJM. Roseboom
- Slide2Shutdown v1.1 by Cythrelo
- Synchro Time v0.95 by Dennis Grachov
- Total Commander CE v2.52 beta 2 by Christian Ghisler
- X2 Taskmanager WM 6_5_3 - v2
- amarullzGreenBlack theme.
- WMP12 WVGA skin by BOGYSOFT
- Some small games.
Chương trình đã loại bỏ - Removed programs:
- WM 7 Titanium Project by Ibrythill
- G-Watch_0_6_4 by ageye
- m_carroll PureBlack3 Installer (W)VGA
- CHTEditor_v1_6_1 by John C Molyneux
- Chome Editor_Beta1_6 by Showaco
Link download đã được cập nhật!
Download link was available!
[DOWNLOAD]http://www.4shared.com/file/rMy3Y6HO/BLACKSTONE_-_PDAVIET_ROM_WM65_.html[/DOWNLOAD]
[PASS]TranMinhMan[/PASS]
Test FootPrints xem có bị lỗi nửa ko nhé!
Có add CHTEditor v1.7.1.2 multilingual
add ClearTemp v1.3.0.1 fix hổ trợ WM6.5.
Cảm ơn nhiều lắm!!
- Footprint lỗi do mình remove Titanium Weather, nó có Mortscript chạy cùng. Ở bản trước, chỉ cần chép lại MortScript.exe vào Device/Windows là chạy!
- Bản này nếu ai thích Cookies Home Tab và CHTEditor thì tự cài và config nhé!
- Dang lên Rom rồi anh àh, ClearTemp v1.3.0.1 để bản sau vậy!
Chúc vui!:D
xài ổn định và tốc độ thì cứ thế dùng thôi, ram cao ram thấp thì để làm gì khi mà mọi thứ đã trơn tru chứ bạn . hihihihi
Nhung gi hay nhat dang duoc support tren dong may HD2 hien nay, minh da dua vao Rom cua minh. Nen viec ton Ram va pin la kho tranh khoi, vi ban xem cau hinh HD2 va HD thi se ro.
Nhung theo minh thi van chap nhan duoc, vi no van chay tron tru do minh da config theo cach tot nhat co the.
Ngoai ra, con mot so cai se khac so voi Rom cua cac Cooker khac nen dung so sanh moi viec se khap khieng:
1/ Pagepool minh dua len 17mb so voi 12mb, dieu nay se lam Ram tong mat di 5mb so voi binh thuong, nhung bu lai HD se chay tron tru hon, it bi treo.
2/Build WM6.5.x cua COM5 va Manila2.5 (co Footprint tu Rom TMOUS) se kha ton ram, nhung bu lai no dep va rat tien dung.
3/ Cac ctr duoc plugin kha nhieu, nhung theo minh do deu la nhung ctr hay va can thiet ma WM con thieu. Vi vay, khi dung cac ban can quan ly cho logic thi Rom van chay tot (nen tat ctr khi ko dung va chay Clean Ram).
* Neu dung Manila, quan ly tot Ram free con ~ 50mb, khoang 30% so voi tai nguyen, dieu nay van chap nhan duoc.
* Neu dung Titanium, quan ly tot Ram free > 70mb.
Ko tinh neu cac ban bat tat ca chuc nang nhu ChangeScreen, dang nghe nhac WMplayer, xem Album, cai them ctr ve giao dien... thi potay khi xem freeram. Nhung Rom cung ko treo dau nhe, minh da test rui!
Sorry, vi post bai bang PPC, nen TV ko dau, se edit bai lai sau. Chuc vui!:D
Adv Mod T2M chỉ cách đặt Registry để set "Long End Key" sẻ chạy Lockscreen như bản Rom trước nhé!! Bản ROM này chức năng Long End Key ko tác dụng! Cảm ơn nhều!!
Cảm nhận: Rom mượt, free RAM tương đối nhiều, ko sục RAM dưới 30MB, GPS bản Rom này rất chậm, nhiều lúc ko thể bắt được sóng GPS so với bản ROM trước.
Vã lại .NetCF v3.7.8345.0 không hổ trợ một số ứng dụng củ!! .NetCF v3.5.0.xx thì ko thể cài vào được! cũng ko thể gở bỏ đi khi cài vào bị lỗi! .NetCF v2.0 thì lỗi thời! Vậy mong Adv Mod T2M xem lại chỉ đưa .NetCF v3.5 vào ROM thôi. Vì .NetCF v3.7 có thể cài sau, và có thể gở bỏ khi ko cần thiết!!
em vừa up lên xong, nhìn chung là giao diện và các chương trình chạy ngon nhưng hơi chậm ( máy đơ 1 lúc mới ăn ) và chả biết bị lỗi gì mà giờ nó hết kết nối active sync được luôn, ( cái mũi tên xoay hoài một hồi hiện thông báo ko kết nối được )
Thank TMM nhiều dạo này mọi người ít cookrom cho HD1 nhỉ, mình thấy bản room của Bác Quang có cài thêm phần gì đó khi up room nó ko phải căn chỉnh màn hình và tự cài một số ứng dụng trong foder autoinstall. Mong bạn có nhiều đóng góp cho anh em HD
tình trạng nói chung vẫn còn tồn tại các vấn đề của các bản trước. Sao T2M không thử. lúc đang build rom. lúc nó xuất \temp\dump. thử kill process eviruskitchen.exe để xử lí lại phần temp lại đã rồi build lại cho hoàn chỉnh nhỉ. Mình thấy vấn đề là ở chổ. rom của bạn có quá nhiều thành phần thừa thải. 1 Lần dump rom của bạn. mình đếm sơ qua cũng có đến gần 4000file không có liên quan j đến hạnh phúc và cấu thành kể cả nhiệm vụ hay giao diện cần thiết cho rom nữa. Theo mình, với một kitchen và OEM mà cooker đem về tạo rom cho riêng mình. Cũng phải có ít chỉnh sữa để tạo lại 1 cách hoàn chỉnh phù hợp với đối tượng là HD. Như mình đã góp ý cho bạn ở bài trước. Bạn có thể dùng PNGoutWin để xử lý lại toàn bộ PNG của ROM trước khi build. nó sẽ cải thiện tốc độ rất đáng kể về mặt đồ họa cả về dung lượng.
Bạn thử làm thế này nhé. Lúc chạy creat rom. lúc nó đã xuất toàn bộ vào \temp\dump\ bạn tìm tất cả file .png .bmp move vào một thư mục nào đó. sau đó kéo thả tất cả file .png vào pngoutwin. nó sẽ tự làm việc tất cả cho bạn. Lúc này bạn có thể chạy lại creat rom lại. và copy đè các file đồ họa đã được xử lý ngược đè vào \temp\dump\. Phải đảm bảo lúc đó. process đã xã hết file vào đã và đang bắt đầu tiến trình creaT .NB. lúc này nó đang đưa các file đầu tiên xxxxxx_manila vào rom nên bạn sẽ dư thời gian để copy đè .PNG đã xử lý và thay thế.
Với .bmp cũng tương tự. bạn hãy đọc tut trước đây mình đã giới thiệu. Mình cam đoan với bạn. nếu bạn làm hết như thế. bạn tiết kiệm được 60-70MB dung lượng rom. tức là = OEM manila 2.5 đó. đồng thời tốc độ cũng thay đổi đáng kể.
Thêm nữa. lần đầu khởi động rom của bạn thường rất lâu lý do là bạn để nguyên đường dẫn của các OEM (mình ví dụ opera đi. trong file insxxxxxxx.dat bạn dẫn đến \program file\opera. việc đó đồng nghĩa với lần đầu chạy rom đầu tiên. OS sẽ có nhiệm vụ copy oem opera vào programfile . nhưng thực tế nó nằm ở windows. tức là vô tình bạn đã mất 2 lần dung lượng opera. sao bạn không để yên cho nó nằm ở windows. đó chỉ là 1 ví dụ. chưa kể có gần chục cái oem như google map, pocket rar,Total Commander.... những cái này làm rom bạn khởi động lần đầu rất lâu mà lại tốn dung lượng gấp 2 lần. Nên mới up rom xong dù đã handset, bạn thử nhìn vào storage mà xem. đã ngốn hết mấy chục MB rùi đó. hehe
Hiện tại mình đã build rom thành công và đã kiếm được EXTrom cần thiết nên ko cần xin xỏ kitchen nữa. Nhưng hy vọng có thể trao đổi một chút kinh nghiệm cùng mọi người để có thể cho rom hoàn chỉnh hơn. Mình rất thích dòng có start menu nằm dưới nên rất quan tâm rom bạn làm như thế nào. nên mình chỉ hay vào đây để nghiên cứu thôi. chào bạn
bạn thử làm thế này nhé. Lúc chạy creat rom. lúc nó đã xuất toàn bộ vào \temp\dump\ bạn tìm tất cả file .png .bmp move vào một thư mục nào đó. sau đó kéo thả tất cả file .png vào pngoutwin. nó sẽ tự làm việc tất cả cho bạn. Lúc này bạn có thể chạy lại creat rom lại. và copy đè các file đồ họa đã được xử lý ngược đè vào \temp\dump\. Phải đảm bảo lúc đó. process đã xã hết file vào đã và đang bắt đầu tiến trình creaT .NB. lúc này nó đang đưa các file đầu tiên xxxxxx_manila vào rom nên bạn sẽ dư thời gian để copy đè .PNG đã xử lý và thay thế.
với .bmp cũng tương tự. bạn hãy đọc tut trước đây mình đã giới thiệu. Mình cam đoan với bạn. nếu bạn làm hết như thế. bạn tiết kiệm được 60-70MB dung lượng rom. tức là = OEM manila 2.5 đó. đồng thời tốc độ cũng thay đổi đáng kể.
hiện tại mình đã build rom thành công và đã kiếm được EXTrom cần thiết nên ko cần xin xỏ kitchen nữa. Nhưng hy vọng có thể trao đổi một chút kinh nghiệm cùng mọi người để có thể cho rom hoàn chỉnh hơn. Mình rất thích dòng có start menu nằm dưới nên rất quan tâm rom bạn làm như thế nào. nên mình chỉ hay vào đây để nghiên cứu thôi. chào bạn
Bạn có thể chia sẻ thành qủa của mình để anh em cùng chiêm ngưỡng đượcx ko vậy?
Như bạn HTC HD1 nói ở trên thì chắc hẳn bạn đã làm ra 1 bản Rom tối ưu cho HD1. Bạn có thể chia sẻ thành quả của mình cho Mem Hd1 cùng thưởng thức được không..? Cám ơn bạn nhiều.
mình cũng sẽ post lên nhưng không phải bây giờ. bây giờ thì thời gian mình tập trung cho bài học kì. tức là khoảng 1 tháng nữa. xong xuôi mình mới dám cắm đầu vào điện thoại. chư mình có cái bệnh là đụng vào nó là dính vô gở mãi không ra. lúc đó. học lại với thi lại các bạn có nộp tiền cho mình học $ thi lại ko. hix. hẹn đúng 1 tháng nữa. mình sẽ gia nhập cooker rom HD. còn bản mình đang dùng thì đang thử nghiệm nên lỗi toe loe. đưa lên thì lần đầu e rằng hơi mất mặt. hẹn các bác dịp khác
mình nghĩ bạn nên đưa Rom của bạn lên cho anh em chiêm ngưỡng đi! thay vì bạn giành thời gian để phân tích rom cho người ta build , giành thời gian để post bài phân tích rom! thì bạn nên dùng thời gian đó để build rom của chính mình rồi đưa lên diễn đàn để anh em cùng đóng góp cho nó hoàn thiện hơn! chúc bạn cho ra rom thật là chuẩn và nhanh!
Thành phần cấu tạo của 1 Kit ko biết bạn rõ nguồn gốc ko!? Kỹ năng build của bạn thế nào ko rõ!? Những điều bạn nói tôi biêt, nhưng để config tất cả và chính xác trên Kit là cả vấn đề. Trong Kit cấu thành chính cho OEM có 2 thành phần, OEM chính và EXT. OEM được dump ra và lấy từ Rom Ship của HD (VD ở đây là BlackStone Rom Ship 1.59.841.5), mà Ship Rom của HD ko dùng RunCC, mà dùng AutoInstall để config các setting cơ bản cho máy khi khởi động, RunCC được lấy từ HD2. EXT được dump ra và lấy từ HD2, Topaz, Rhodium tùy theo sở thích của tác giả. Còn các OEM plugin từ ngoài vào nữa. Vì vậy có thể nó trong Kit sẽ tồn tại rất nhiều rgu (set reg cho Rom) và dat (txt hoặc provxml) file để config việc chép file như thế nào để loading file ko lỗi. Những cái bạn nói là lý thuyết cơ bản, nhưng bạn hãy vào config sao cho Rom chạy thật trơn tru, ko lỗi khi bạn loại bỏ bớt thành phần thì hãy nói. Và cũng có thể nói nếu bạn cứ đi xóa file thay vì kiếm cách chỉnh sửa và đọc Kit thật tốt thì bạn sẽ chẳng bao giờ có Kit hoàn chỉnh đâu, vì có cái bạn xóa bạn tưởng nó chỉ liên quan tới cái này nhưng thật sự nó cũng sẽ liên quan cái khác và tới lúc đi tìm lỗi thì vĩnh viễn sẽ dò ko ra.
Manila do 1 group được MS thuê để phát triển từ nhiều năm nay, bạn vẫn chê họ! Có lẽ bạn có cách làm hay hơn họ!? Cách thay thế image của mình chỉ đơn giản là dùng 1 file hình cần thay và replace fie cũ, ko cần chạy tới từng thư mục như Kit ngày xưa ko thể overwrite được, còn nhiều vấn đề có lẽ bạn cứ build đi từ từ rồi sẽ rõ.
Xã hội đã phân chia lao động, mỗi người có công việc và nhiệm vụ khác nhau, ko thể chỉ có 1 người kiêm nhiệm và làm nên tất cả!
Chúc bạn thành công theo cách của bạn!
htchd1 Nói thì nghe có vẻ hiểu biết đấy. Nhwng mình nghĩ để buil một room chạy mượt thì ko đơn giản. Bằng chwsng bạn nói room của bạn đang lỗi toe toét. Nói vậy để mọi người nên tôn trọng các cooker room, mong bạn sớm buil bản room tốt cho anh em thử
Thành phần cấu tạo của 1 Kit ko biết bạn rõ nguồn gốc ko!? Kỹ năng build của bạn thế nào ko rõ!? Những điều bạn nói tôi biêt, nhưng để config tất cả và chính xác trên Kit là cả vấn đề. Trong Kit cấu thành chính cho OEM có 2 thành phần, OEM chính và EXT. OEM được dump ra và lấy từ Rom Ship của HD (VD ở đây là BlackStone Rom Ship 1.59.841.5), mà Ship Rom của HD ko dùng RunCC, mà dùng AutoInstall để config các setting cơ bản cho máy kh................................
ý của mình không phải chê bai hay có ý châm chích rom của bạn. Mình chỉ muốn tham gia trao đổi kinh nghiệm với nhau thôi.
như mình đã ví dụ ở trên về phần EXT: mình ví dụ OEM opera mobile 10 có trong bản rom này. Có phải sau khi úp rom. opera mặc định của bạn được đặt vào \program files\opera\ của máy không? Ý của mình là bạn nên chỉnh sữa lại 1 ít OEM của opera trước khi build rom. Bạn có thể thấy trong OEM của opera có chứa 2 file app.regapp.dat. Bạn chỉ cần mở bằng notepad sau đó chỉnh sữa thay thế dòng "program files\opera" lại thành "windows" thì tất cả sẽ khác. Cái này mình giải thích thế này. tất cả các file sau khi đưa vào rom nó sẽ được mặc định nằm ở \windows\. các thư mục và file khác muốn nằm ở thư mục khác. sẽ có runCC hoặc hệ thống hoặc chương trình khác tùy mỗi dòng copy hoặc tạo ra. Vì thế. Khi bạn không chỉnh sữa OEM opera nói chung và các soft khác nói riêng. sẽ vô tình mất thêm dung lượng dành cho nó. Để bạn dể liên tưởng hơn. Mình xin đưa ra các thay đổi trong các file ví dụ mình nêu trên (EXT opera 10):
file 1: app.dat (gốc)
Directory("\Program Files"):-Directory("Opera Mobile 10")
Directory("\Program Files\Opera Mobile 10"):-Directory("profile")
Directory("\Program Files\Opera Mobile 10\profile"):-Directory("locale")
Directory("\Program Files\Opera Mobile 10\profile"):-Directory("skin")
Directory("\Program Files\Opera Mobile 10\profile"):-Directory("bream")
Directory("\Program Files\Opera Mobile 10\profile"):-Directory("fonts")
Directory("\Program Files\Opera Mobile 10\profile"):-Directory("styles")
Directory("\Program Files\Opera Mobile 10\profile"):-Directory("images")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-Directory("images")
Directory("\Program Files\Opera Mobile 10\profile\styles\images"):-File("root.png","\Windows\root.png")
Directory("\Program Files\Opera Mobile 10\profile\styles\images"):-File("bar.png","\Windows\bar.png")
Directory("\Program Files\Opera Mobile 10\profile\styles\images"):-File("center.png","\Windows\center.png")
Directory("\Program Files\Opera Mobile 10\profile\styles\images"):-File("top.png","\Windows\top.png")
Directory("\Program Files\Opera Mobile 10\profile\styles\images"):-File("opera.png","\Windows\opera.png")
Directory("\Program Files\Opera Mobile 10\profile\images"):-File("delete.png","\Windows\delete.png")
Directory("\Program Files\Opera Mobile 10\profile\images"):-File("forward.png","\Windows\forward.png")
Directory("\Program Files\Opera Mobile 10\profile\images"):-File("open.png","\Windows\open.png")
Directory("\Program Files\Opera Mobile 10\profile\images"):-File("drive.gif","\Windows\drive.gif")
Directory("\Program Files\Opera Mobile 10\profile\images"):-File("oom.png","\Windows\oom.png")
Directory("\Program Files\Opera Mobile 10\profile\images"):-File("question.png","\Windows\question.png")
Directory("\Program Files\Opera Mobile 10\profile\images"):-File("file.gif","\Windows\file.gif")
Directory("\Program Files\Opera Mobile 10\profile\images"):-File("blank.gif","\Windows\blank.gif")
Directory("\Program Files\Opera Mobile 10\profile\images"):-File("link.gif","\Windows\link.gif")
Directory("\Program Files\Opera Mobile 10\profile\images"):-File("folder.gif","\Windows\folder.gif")
Directory("\Program Files\Opera Mobile 10\profile\images"):-File("error.png","\Windows\error.png")
Directory("\Program Files\Opera Mobile 10\profile\images"):-File("info.png","\Windows\info.png")
Directory("\Program Files\Opera Mobile 10\profile\images"):-File("trash.png","\Windows\trash.png")
Directory("\Program Files\Opera Mobile 10\profile\images"):-File("reload.png","\Windows\reload.png")
Directory("\Program Files\Opera Mobile 10\profile\images"):-File("warning.png","\Windows\warning.png")
Directory("\Program Files\Opera Mobile 10\profile\images"):-File("stop.png","\Windows\stop.png")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("info.css","\Windows\info.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("contentblock.css","\Windows\contentblock.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("about.css","\Windows\about.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("message.css","\Windows\message.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("mathml.css","\Windows\mathml.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("search.css","\Windows\search.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("certinfo.css","\Windows\certinfo.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("plugins.css","\Windows\plugins.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("dir.css","\Windows\dir.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("image.css","\Windows\image.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("bookmarks.css","\Windows\bookmarks.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("config.css","\Windows\config.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("im.css","\Windows\im.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("cache.css","\Windows\cache.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("wml.css","\Windows\wml.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("drives.css","\Windows\drives.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("history.css","\Windows\history.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("debug.css","\Windows\debug.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("warning.css","\Windows\warning.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("small-wml.css","\Windows\small-wml.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("error.css","\Windows\error.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("webfeed.css","\Windows\webfeed.css")
Directory("\Program Files\Opera Mobile 10\profile\styles"):-File("mime.css","\Windows\mime.css")
Directory("\Program Files\Opera Mobile 10\profile\fonts"):-File("AHEM____.TTF","\Windows\AHEM____.TTF")
Directory("\Program Files\Opera Mobile 10\profile\bream"):-File("qvga.rsc","\Windows\qvga.rsc")
Directory("\Program Files\Opera Mobile 10\profile\bream"):-File("vga.rsc","\Windows\vga.rsc")
Directory("\Program Files\Opera Mobile 10\profile\bream"):-File("hvga.rsc","\Windows\hvga.rsc")
Directory("\Program Files\Opera Mobile 10\profile\bream"):-File("a","\Windows\a")
Directory("\Program Files\Opera Mobile 10\profile\skin"):-File("standard_skin.zip","\Windows\standard_skin.zip")
Directory("\Program Files\Opera Mobile 10\profile\skin"):-File("windows_skin.zip","\Windows\windows_skin.zip")
Directory("\Program Files\Opera Mobile 10\profile\locale"):-File("english.lng","\Windows\english.lng")
Directory("\Program Files\Opera Mobile 10\profile"):-File("encoding.bin","\Windows\encoding.bin")
Directory("\Program Files\Opera Mobile 10\profile"):-File("html40_entities.dtd","\Windows\html40_entities.dtd")
Directory("\Program Files\Opera Mobile 10\profile"):-File("opera.ini","\Windows\opera.ini")
Directory("\Program Files\Opera Mobile 10\profile"):-File("input.ini","\Windows\input.ini")
Directory("\Program Files\Opera Mobile 10\profile"):-File("xmlentities.ini","\Windows\xmlentities.ini")
Directory("\Program Files\Opera Mobile 10\profile"):-File("config.ini","\Windows\config.ini")
Directory("\Program Files\Opera Mobile 10"):-File("opera-wince5-armv4i.dll","\Windows\opera-wince5-armv4i.dll")
Directory("\Program Files\Opera Mobile 10"):-File("Opera10-armv4i.exe","\Windows\Opera10-armv4i.exe")
Directory("\Program Files\Opera Mobile 10"):-File("setup.dll","\Windows\setup.dll")
Directory("\Windows\Start Menu\Programs"):-File("Opera Mobile 10 Beta.lnk","\Windows\_Opera Mobile 10 Beta.lnk")
đổi lại thành
Directory("\windows"):-Directory("profile")
Directory("\windows\profile"):-Directory("locale")
Directory("\windows\profile"):-Directory("skin")
Directory("\windows\profile"):-Directory("bream")
Directory("\windows\profile"):-Directory("fonts")
Directory("\windows\profile"):-Directory("styles")
Directory("\windows\profile"):-Directory("images")
Directory("\windows\profile\styles"):-Directory("images")
Directory("\windows\profile\styles\images"):-File("root.png","\Windows\root.png")
Directory("\windows\profile\styles\images"):-File("bar.png","\Windows\bar.png")
Directory("\windows\profile\styles\images"):-File("center.png","\Windows\center.png")
Directory("\windows\profile\styles\images"):-File("top.png","\Windows\top.png")
Directory("\windows\profile\styles\images"):-File("opera.png","\Windows\opera.png")
Directory("\windows\profile\images"):-File("delete.png","\Windows\delete.png")
Directory("\windows\profile\images"):-File("forward.png","\Windows\forward.png")
Directory("\windows\profile\images"):-File("open.png","\Windows\open.png")
Directory("\windows\profile\images"):-File("drive.gif","\Windows\drive.gif")
Directory("\windows\profile\images"):-File("oom.png","\Windows\oom.png")
Directory("\windows\profile\images"):-File("question.png","\Windows\question.png")
Directory("\windows\profile\images"):-File("file.gif","\Windows\file.gif")
Directory("\windows\profile\images"):-File("blank.gif","\Windows\blank.gif")
Directory("\windows\profile\images"):-File("link.gif","\Windows\link.gif")
Directory("\windows\profile\images"):-File("folder.gif","\Windows\folder.gif")
Directory("\windows\profile\images"):-File("error.png","\Windows\error.png")
Directory("\windows\profile\images"):-File("info.png","\Windows\info.png")
Directory("\windows\profile\images"):-File("trash.png","\Windows\trash.png")
Directory("\windows\profile\images"):-File("reload.png","\Windows\reload.png")
Directory("\windows\profile\images"):-File("warning.png","\Windows\warning.png")
Directory("\windows\profile\images"):-File("stop.png","\Windows\stop.png")
Directory("\windows\profile\styles"):-File("info.css","\Windows\info.css")
Directory("\windows\profile\styles"):-File("contentblock.css","\Windows\contentblock.css")
Directory("\windows\profile\styles"):-File("about.css","\Windows\about.css")
Directory("\windows\profile\styles"):-File("message.css","\Windows\message.css")
Directory("\windows\profile\styles"):-File("mathml.css","\Windows\mathml.css")
Directory("\windows\profile\styles"):-File("search.css","\Windows\search.css")
Directory("\windows\profile\styles"):-File("certinfo.css","\Windows\certinfo.css")
Directory("\windows\profile\styles"):-File("plugins.css","\Windows\plugins.css")
Directory("\windows\profile\styles"):-File("dir.css","\Windows\dir.css")
Directory("\windows\profile\styles"):-File("image.css","\Windows\image.css")
Directory("\windows\profile\styles"):-File("bookmarks.css","\Windows\bookmarks.css")
Directory("\windows\profile\styles"):-File("config.css","\Windows\config.css")
Directory("\windows\profile\styles"):-File("im.css","\Windows\im.css")
Directory("\windows\profile\styles"):-File("cache.css","\Windows\cache.css")
Directory("\windows\profile\styles"):-File("wml.css","\Windows\wml.css")
Directory("\windows\profile\styles"):-File("drives.css","\Windows\drives.css")
Directory("\windows\profile\styles"):-File("history.css","\Windows\history.css")
Directory("\windows\profile\styles"):-File("debug.css","\Windows\debug.css")
Directory("\windows\profile\styles"):-File("warning.css","\Windows\warning.css")
Directory("\windows\profile\styles"):-File("small-wml.css","\Windows\small-wml.css")
Directory("\windows\profile\styles"):-File("error.css","\Windows\error.css")
Directory("\windows\profile\styles"):-File("webfeed.css","\Windows\webfeed.css")
Directory("\windows\profile\styles"):-File("mime.css","\Windows\mime.css")
Directory("\windows\profile\fonts"):-File("AHEM____.TTF","\Windows\AHEM____.TTF")
Directory("\windows\profile\bream"):-File("qvga.rsc","\Windows\qvga.rsc")
Directory("\windows\profile\bream"):-File("vga.rsc","\Windows\vga.rsc")
Directory("\windows\profile\bream"):-File("hvga.rsc","\Windows\hvga.rsc")
Directory("\windows\profile\bream"):-File("a","\Windows\a")
Directory("\windows\profile\skin"):-File("standard_skin.zip","\Windows\standard_skin.zip")
Directory("\windows\profile\skin"):-File("windows_skin.zip","\Windows\windows_skin.zip")
Directory("\windows\profile\locale"):-File("english.lng","\Windows\english.lng")
Directory("\windows\profile"):-File("encoding.bin","\Windows\encoding.bin")
Directory("\windows\profile"):-File("html40_entities.dtd","\Windows\html40_entities.dtd")
Directory("\windows\profile"):-File("opera.ini","\Windows\opera.ini")
Directory("\windows\profile"):-File("input.ini","\Windows\input.ini")
Directory("\windows\profile"):-File("xmlentities.ini","\Windows\xmlentities.ini")
Directory("\windows\profile"):-File("config.ini","\Windows\config.ini")
Directory("\windows"):-File("opera-wince5-armv4i.dll","\Windows\opera-wince5-armv4i.dll")
Directory("\windows"):-File("Opera10-armv4i.exe","\Windows\Opera10-armv4i.exe")
riêng với dòng bôi đỏ ở trên opera-wince5-armv4i.dll Opera10-armv4i.exe có thể xóa đi vì nếu để thì cũng coi như tốn dung lượng storage
tương tự với file chứa regedit. mình đổi lại thành với cấu trúc thay đổi như trên. với thay đổi như trên trừ 2 file opera-wince5-armv4i.dll Opera10-armv4i.exe này có size ~ 10MB. các file kia nhỏ thì tốn thêm dung lượng.
bạn thường xuyên build rom chắc biết file app.dat này có ở đâu của mỗi EXT hay OEM. nhiệm vụ của nó là j và cách hoạt động thế nào chắc bạn cũng biết. Directory đó tạo hay là j đi nữa. nhưng cũng làm storage phình ra. Ý mình là như thế. Còn Manila hay những thành phần còn lại. mình có nói qua. nhưng để hoạt động được chắc bạn cũng phải biết thêm sau khi thay đổi bạn thường nhấn chuột phải /sento/set sys.....bat. cái này làm j chắc bạn biết. thì nó mới hoạt động được. Như mình giới thiệu PNGoutwin. nó không những nén PNG tốt. mà ở phần settings. mình có chỉ rỏ là tương thích với hệ của mobile. nên yên tâm là mặc dù nén. nhưng nó không phải giải nén khi chạy.
Mình chỉ muốn trao đổi với bạn. đặc biệt là lần trước mình có xin kitchen của bạn để đở phải đi tìm các OEM và EXT mới. vì mình mới build rom cho HD. trước đó mình cũng đã build rom cho nhiều dòng khác. nên mình cũng có ít vốn hiểu biết về cấu thành rom. Nếu bạn xem mình vào đây để trao đổi học hỏi thêm kinh nghiệm thì cùng chia sẽ. Còn bạn cứ nghĩ mình nói ra chỉ để huênh hoang khoe trình độ hay thành tích thì có lẻ mình đã không trao đổi thêm ở đây.
Tất nhiên mình cũng post rom mình lên. Nhưng còn vài điều mình còn chưa làm xong và mắc ôn tập để thi nên không có thời gian làm hoàn thành được. Hẹn 1 tháng nữa sẽ có rom cho bạn thấy những j mình trao đổi với bạn. THANK T2M. G.luck!
PS: rom mình lỗi toe loe là do mình dùng UPX để nén các file .exe và dll nên có vài chương trình bị lỗi. ví dụ GPS bật là treo máy vì mình nén trúng rilphone.dll. hehe. thế đó.
tốt nhất bạn nên cho ra 1 Rom của riêng bạn để AE test đi bạn! dù lỗi hay không lỗi gì cũng nên chia sẽ cho ae! mình muốn trao dồi kinh nghiệm thì mình nên đưa ra sản phẩm của mình để cho người ta coi chứ! ở đây bạn chỉ toàn nói thì ko ai nghe hết!mình nói thật tuy mình không biul được Rom (có thể mình thua bạn về cái đó) nhưng mình ko thích những người chỉ biết nói mà không chứng minh được mình nói là đúng , cái đó ai làm cũng được!
