Số là 5800 red khởi động không lên chỉ rung 1 cái rồi im re.
Mình dùng navifrim down fw v51 red về dùng jaf để chạy nhưng toàn báo lỗi. Mấy bửa trước mình hack con 5800 fw v51 black thì ok .ko biết sao nửa .làm cả chục lần mà ko được .kể cả dùng phoenix cũng ko được .mong ae giúp đỡ
JAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 99.99%
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.29.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for phone...Detected P-KEY: 90009699
Init usb communication...
Not found!!!
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-356\
Searching for default location of ini...
Checking path: \Products\RM-356\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_51.0.006_prd.core.C00
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_51.0.006_prd.rofs2.V20
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_51.0.006_C01_prd.rofs3.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_51.0.006_026_000_U01.uda.fpsx
Languages in ppm: English,Vietnamese,Tagalog,Chinese Simpl,Chinese Trad
Backing up CRT...
Reading IMEI...
Failed! Aborting!
Failed to backup CRT...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 009.012.005
Elf2flash 09.11.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
....................Loader Sent!
Stage 2 starting..................PUBKEYS already sent...
...........Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 626, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_51.0.006_prd.core.C00...
Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000
Erasing cmt zone 00083400 - 003FFFFF ... Erase result: 0000
Erasing cmt zone 00400000 - 007FFFFF ... Erase result: 0000
Erasing cmt zone 00800000 - 00D5FFFF ... Erase result: 0000
Erasing cmt zone 00D60000 - 09E5FFFF ... Erase result: 0000
Partition result: 0014
Processing C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_51.0.006_prd.rofs2.V20...
Erasing cmt zone 07180000 - 0915FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_51.0.006_C01_prd.rofs3.fpsx...
Erasing cmt zone 09160000 - 09E5FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_51.0.006_026_000_U01.uda.fpsx...
Erasing cmt zone 09E60000 - 0F71FFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
cmt->PAPUB keys already sent...
Sending CMT HASH for SOS*UPDAPP
Sending CMT HASH for SOS*ENO
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS*ISASW
Sending CMT HASH for SOS+CORE
Sending CMT HASH for SOS+ROFS1
Sending CMT HASH for SOS+ROFS2
Write result 27: 1701
Sending CMT HASH for SOS+ROFS3
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
Phone not found...
Done!
Các bác cho em hỏi,sao máy của em mới hack xong,ban đầu em cop ảnh và video vào trong thẻ nhớ của máy thì vẫn thấy máy load được các file đó,nhưng hum nay tự nhiên vào trong bộ sưu tập thì không thấy hiển thị ảnh hay video nào cả,nhưng nhạc thì vẫn hiển thị bình thường là bị làm sao vậy ? Em tìm trong thẻ vẫn còn nguyên ảnh và video.
Có thể do thẻ lỗi, bạn thử chụp 1 tấm hình xem, rồi vào bộ sưu tập sẽ thấy đầy đủ như cũ. Nhưng cách này chỉ tạm thời, sẽ bị lại. Muốn hết thì phải format thẻ.
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-504\
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_31.0.005_prd.core.C00
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_31.0.005_prd.rofs2.V06
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_31.0.005_C01_prd.rofs3.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_31.0.005_007_000_U001.uda.fpsx
Detected P-KEY: 9000A016
PRESS POWER ON NOW!
Error reading phone init data...
ai biết chỉ mình với lỗi này là bị như thế nào
PRESS POWER ON NOW!
bị lỗi này thì đừng thoát vội. ấn flash thêm 1 lần nữa rồi thực hiện theo quy trình flash tiếp xem sao.
Máy em là con 5800 màu xám, em đã làm theo y chang hướng dẫn trên 4rum, down đầy đủ tất cả file của fw 5.1 là bản "Vietnam Black (0573800)" và copy vô đường dẫn "C:\Program Files\Nokia\Phoenix\Products\RM-356" nhưng khi tiến hành nhấp vào phần "Use INI" trong J.A.F thì nó lại có thông báo như vầy :((
No ini files found...
Như vậy là sao ạ, em đã thử lại rất nhiều lần mà vẫn bị vậy, xin chỉ em chi tiết 1 chút, hix, thanks nhìu :)
xem lại đã đủ file FW chưa?
trong đường dẫn FW của bạn có bao nhiêu files?
bạn thử lại qua đường dẫn này
C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\
JAF version 1.98.62
Not found!!!
Backing up CRT...
Reading IMEI...
Failed! Aborting!
PRESS POWER ON NOW!
Using 009.012.005
Elf2flash 09.11.000
CMT RAW loader...
Status byte: 8000
Result: 0000
Erasing cmt...
Send CMT CFG...
Writing cmt...
Rebooting...
Restarting CMT...
Pooling phone...
Phone not found...
Done!
Bạn sử dụng Interface là FBus hay là USB vậy.nếu để Fbus nên chỉnh lại là USB nha.ở trên cửa sổ chính của JAF đó.một điểu nên nhớ là bạn nên sạc đầy pin,dùng cổng usb đằng sau.cáp chính hãng,Khi JAF bạn cài NSU,PC suite để lấy driver.Khi JAF bạn tick vào các ô như trong video của mình.cái này là mình dùng 5800 giúp 1 bạn trên 4rum.giờ không dùng 5800 nữa nhưng thấy ae vẫn mắc mấy vấn đề này.
http://www.mediafire.com/?eb20kn4gjm1
bạn không hiểu có thể PM vs mình qua Y!M duongtuanviet_hl hoặc sdt 01685928481
các bạn cho mình hỏi N97 UNLOCK vậy có hack và up FW được không và nếu được có bị lock lại hay không .
bạn ơi mình cũng bị lỗi như của ban ngocchuc1 nhưng mình làm như bạn bảo thì JAF báo lỗi rồi out luôn :(
mấy anh cho em hỏi
em hack con 5233 lúc gần xong thì nó hiện lên như thế này
bấm yes hay no cũng nó hiện ra
mặc dù vẫn mở máy lên được nhưng em muốn biết là nó bị như thế là sao???
bạn vẫn finish quá trình là ok rồi.đó là do phone bị treo tạm thời thôi ( Phone đi't respond) đó.chỉ cần cài đủ driver và sài cáp ngon là ok
đã cài đủ PC suite và NSU chưa?
em đã cài đủ rôi mà. lúc trước vừa bắt đầu nghịch hack thì nó không bị như thế đâu. chẳng hiểu làm sai cái gì mà nó bị như thế nữa :(
mình theo con đường Sign = cer và key là ổn nhất, update fw thì cứ nokia nó có mới thì mình up ko thì thoai. hack máy nhầm nhọt sang bia bọt cái là mệt đứt hơi.
Cho em hỏi chút.em dùng 5230 mang từ nước ngoài về.ko có tiếng viêt.em mún đổi lại ngôn ngữ tiếng viêt có fải là chỉ cần down file rof2 cua fw tiếng viêt về chép đè lên fw gốc rùi fash là đc fải ko ah.em mún hỏi cho chắc ai biết trả lời giúp em tý nhé
chơi nguyên 1 bộ FW gốc của Việt Nam cũng chả sao bạn ơi? :D
Giúp e với : 5800 chết phần mềm
tình hình là e sử dụng bản phần mềm C6 của JokerB trong diễn đàn mình, do sử dụng lâu rùi nên có nhu cầu muốn thay đổi về lại v51 nên e đã cập nhật lại phần mềm = PC suite, quá trình cập nhật diễn ra êm xuôi thành công, nhưng khi khởi động lại máy thì máy đã bị locked :(( có ai đã bị như e chưa? ai biết cách khắc phục thì giúp e với :((
