CÁC THỦ THUẬT, ỨNG DỤNG DÀNH CHO MÁY ĐÃ HACK.
Patch: Khóa xem tin nhắn
Lúc trước mình có up 1 patch khóa cả mục Message luôn. Hôm nay mình mới tìm thấy patch này, vẫn vào được Message, vào luôn Inbox nhưng sẽ ko xem được nội dung tin nhắn. Test ok trên N95-1
Mã:
rel:sys\bin\SmsViewer.exe:00000003:10:00
rel:sys\bin\SmsViewer.exe:00000000:7a:00
Cách cài cái path này thế nào hả Anh em...:)..
Khám phá các folder hệ thống của OS9.1 và 9.2 nhé. Bằng tiếng Anh nhưng cũng dễ hiểu nên mình không dịch :p
WARNING :
This guide here is only for hacked phone.
Please use this guide only for learning.
We do not take any responsibility for damage caused if you modify these files/folders. Please make sure u know exactly what u are doing
Inside C:\Private folder there are some sub folders :
\1000295\
DBS_100065FF_Contacts.cdb - Contacts Database
DBS_100069CC_btregistry - Bluetooth device List
DBS_10207216_SWinsLog.db - Instalation log of Softwares
\1000395b\Calendar - Calendar File
\10003A73\Cntmodel.ini - Speed dial Numbers
\1000484b\Mail\ - Mail Folder (SMS)
\101F413C\SIPprofiles.dat - SIP (Session Initiation Protocol) Profiles
\101F4668\UnitConverter.ini - Stored Exchange Rates in the Converter
\101F8530\Cookies - Browser Cookies
\101875a\Startup\ - Startup Files ?
\102072CC\SIMLanguage.dat - Current selected language of the SIM
\20003252\Menuketserver.ini - (This File is in the Startup List)
\10003A3F\import\apps\ - All your shortcuts to installed applications are saved in here in .RSC format, simply rename the .RSC to .RSCX to temporarily remove them from Menu, you can rename .RSCX back to .RSC later on.
\101f401d\Logdbu.dat is the log file.
\101F4CD2\Applications.dat is the file that holds the settings and locations of icons and custom folders located on your phone's MENU.
C:\resource\apps - The MIF files (Icon Files) Of the Softwares Installed in the phone,
C:\sys\data\mmcstore - This file has the Memory Card Password, Open with a text editor to view the current memory card password.
Some interesting facts. not yet tested on all phone but please test yours and let me know the result here.
1. C:\private
\10000850\
contains the mbm file of operator logos
2.
C:\private\100059c9\start.dat
some kind of autorun trigger. I couldnt decode this file, but it is it, I'm sure.. Why I think so? Because only after renaming or moving this file, autorun doesnt work. In all other cases apps start.
3. C:\private\10202be9\20001079.txt
this location.. in this text file there is code, and a line which says :
Mã:
0x00040006 string "clockspeed" 0
0x00040007 int 332 0
on line 41 and 42 of the file.. overclocking possibility maybe?
also in this file is loads of settings with the graphics processor too, maybe even OC this check it out, im not the experianced when it comes to this, and i do have a spare n95 which i wouldnt care if it blows up, i willing to test it
Mã:
0x00A00000 string "/hardware/graphics/displays/0/ngageorientations" 0
0x00A00001 int 0x00090000 0
0x00A00002 string "ngageorientationscount" 0
0x00A00003 int 3 0
0x00A00004 string "defaultngageorientation" 0
0x00A00005 int 0x08 0
0x00A00006 string "useroptions" 0
0x00A00007 int 0x0B 0
0x00A00008 string "wsinimodes" 0
0x00A00009 string "0x01, 0x02, 0x08" 0
ngage stuff there
Mã:
0x00090000 string "/hardware/graphics/displays/0" 0
0x00090001 int 0x00080000 0
0x00090002 string "nativewidth" 0
0x00090003 int 240 0
0x00090004 string "nativeheight" 0
0x00090005 int 320 0
0x00090006 string "pixelsperinchx" 0
0x00090007 int 154 0
0x00090008 string "pixelsperinchy" 0
0x00090009 int 154 0
0x0009000A string "nativecolorformats" 0
0x0009000B int 0x00050000 0
0x0009000C string "brightnessadjustable" 0
0x0009000D int 0 0
0x0009000E string "contrastadjustable" 0
0x0009000F int 0 0
0x00090010 string "gammaadjustable" 0
0x00090011 int 0 0
graphics settings there..
4. In Z/private/101f51f2/PKI/96b7db19a4d...../
it has files in called
Mã:
 devicecert.der
deviceprivatekey.der
signningcert00.der
 signningcert01.der
or in Z/private/10203636/security/trustroots/device/certificates/
nokia content signing
Mã:
nokiaonlineca.cer
 PCA3ss_v4.der
 thawtepremium.cer
  UTI_Root.der
click on any of them it says save certificate.
then when you click save it says new cert might be unsecure save anyway? i ant got round to clicking save yet lol
5. C:\PRIVATE\101F4CD2\Content\appshelldata.xml
this file contains the whole menu layout (N82)
6. I found some huge file in phone, c:/private/102072c4/reserved.bin, 4.5 Mb size of plain 0xff.
Deleted it and free up phone memory check if your phone has one.
the files are for FOTA (firmware over the air) coz when i remove it, and go to the device mgr. app it reapears, so its safe to remove it, we wont need it as we never get any FOTA updates.
MÁY mình đã hack ròi, nhưng khôn truy cập vào trong thư mục Private và SYS đc,, vậy là sao? mình dùng HelloOX 2.03 để hack?!!! Máy mình là N95 8gb, còn một lỗi nữa là hack xong thì fonts tiếng việt bị lỗi,, anh em xem hộ cái bệnh náy nhé
bạn nói bạn hack bằng hello ox bạn muốn truy cập vô Private và SYS thì bạn mở rompath lên chọn ok tích chọn Open4All_RP+ thì có thể truy cập vô Private và SYS rồi đơn giản mà bạn
còn bạn nói font tiếng việt bị lỗi là do bạn lúc úp filmware chọn filmware không hỗ trợ tiếng việt chứ gì
cách khắc phục tạm thời là bạn cài thêm font hỗ trợ tiếng việt vô là ok rồi --->đọc tiếng việt phà phà
thân chúc thành công
Sao máy N85 mình hack rùi mà khi cài files R.viewer trình diễn ảnh hoàn tất rùi chạy thử.được thời gian vài 3 phút thì bị văng ra. Chỉ mình cách khắc phục nó với nha.thank'.
K dùng dc Resco.Photo.Vieuwer.thì dùng photosbook đi b.mà khuyên b dg nên dùng file nhạc có dung lượng qúa lớn.vì m cũng đã bị như thế khi thử với nhưng file nhặc lớn.cũng N85 luôn
Xóa bỏ Icon Wifi và Ghi chú trên Standby không cần ứng dụng!
Cái này mình sưu tầm được trên một diễn đàn ở nước ngoài, thấy hay và hữu dụng nên post lên cho anh em test thử! Mình đã làm thành công trên N82 ver 35.0.0.2.
Các bạn tải file về giải nén!
Thoát Standby của màn hình.
Dùng trình MODO hoặc x-plore, copy file này và dán vào c\resource.
Kích hoạt Standby
Thưởng thức kết quả!
(rất mong nhận phản hồi của các bạn)
Nhớ Thank mình 1 phát để cổ vũ cho các lần post sau nha!
Để wifi ở ngoài desktop là quá tiện khi cần tìm hótpot để online mà xoá chi cho mất công vậy:O
Patch làm ẩn logo mạng
Patch làm ẩn ngày tháng và tên Profile màn hình Stanby
Patch làm ẩn tên Profile màn hình chờ
Patch làm ẩn thông báo khoá phím​
Test ok trên N95-8G​
Chú ý : Patch làm ẩn ngày tháng và tên Profile màn hình Stanby và Patch làm ần tên Profile màn hình chờ đụng nhau nên đừng sử dụng chung
CLICK HERE TO DOWNLOAD
mình dùng pm để hiện ra còn chẳng xong đây lại còn xóa đi nữa chứ. Vẫn thank @@
hihihihih, thấy vậy chứ đôi khi kích hoạt standby mode, các icon hiện diện bít chịt màn hình nhìn bức rức lắm! dùng tip này để làm sạch màn hình standby mà! Nếu không thích nó, thì vào đúng đường dẫn C\resource, xóa đi file đó là xong!!!!
CLICK HERE TO DOWNLOAD[/CENTER]
Có cách nào làm ẩn số Imei khi bấm *#06# không bạn:-?
Patch: Messaging lock
Patch dùng trong RomPatcher nhằm ngăn ko cho truy cập vào Messaging. Test ok trên N95.
cái này khồng dùng dươcdj cho N78 à bạn? mình apply không được, chỉ thấy dấu X màu đỏ thôi
các bác cho e hỏi có ai biết phần mềm nào hay có cách nào chơi game trên E75 bằng bàn phím qwerty ko ạh
hì hì, vothien hỏi để đùa anh em hả!? làm gì có thứ đó, chỉ có khóa số version thôi! Bạn thử làm một bản patche che số imei cho anh em nhờ! khà khà khà
