Cập nhật Rom cho HTC WILDFIRE
ducthang
ROM 25/10 WildPuzzleROM v8.0.11
Changelog for WildPuzzleROM:
UPDATE:ROM 25/10 WildPuzzleROM v8.0.11
v8.0.11
  1. major update to screenscaling script
  2. 3 script in init.d that wasent loaded before
  3. apps2sd should be fixed
  4. fixes triangulation
  5. fixes handwriting
  6. new kernel, overclock (runs @652mhz but 768mhz is maximum), undervolt kernel by jacob v3 (flash standard kernel (0050) if rom doesent boot(or if it crashes/freezes))
  7. updated some apps
  8. updated host file
LINK:WildPuzzleROM_v8.0.11.zip
v8.0.10
  1. Fixed bootloop in 8.0.9
  2. Removed app from chinese rom (NetworkProviderService.apk)
v8.0.9
  1. unlocks even more languages
  2. removed apns from framework and added as plain-text in /system/etc/ instead.
  3. added Sympnotic`s tweaks to /system/etc/init.d/03tweak
  4. changed googleapps pack (less space used)
  5. added proxy support
  6. updated LauncherPro to LauncherPro-0.8.1.0
  7. Unlock Wifi-n, changing to WiFi n will NOT make your WiFi faster, Updating to WiFi n is mainly for stability/greater distances from your router.
link:_WildPuzzleROM_v8.0.10.zip
WildPuzzleROM v8.0.1 HTC-Sense-Froyo 2.2 MultiLang,
GoogleApps, Working
Features:
Android 2.2 with HTC SENSE
Based on HTCCN_CHS_2.10.1400.3
Multi Language, English, Swedish, Danish, Arabic, Thai, Chinise, Japanese, Vietnamise, Spanish, Italian, Polish, France, Rushia, Norwegian, Netlerlands, Thailand, Korea, Czech, German, Turkish
Rooted
Busybox
Apps2SD (Darktremor 2.7.5.1 Script) (Requires Ext Partition. If you want to move dalvik-cache, make sure you flash the patch to do so)
Activated data/app
Deodexed system/framework and system/app to support theme, for example supercircle batterymod
No bootsound
Hosts file to block ads!
And what i have forgotten
Changelog for WildPuzzleROM:hỗ trợ tiếng việt
v8.0.1
Added apps2sd, will start auto when found an ext-partition
Both sd-card and ext-partiton will be mounted even if system is running but still no write to system when system is running.
Modded framework, added 7stepsbattery, and colorful statusbar icones as default
Transparent notification area
Modded service.jar
Added hosts to block ads
WildPuzzleROM_v8.0.1.zip:
http://rom.tat.tw/wildfire/wildpuzzlerom/rom/v8/0001_WildPuzzleROM_v8.0.1.zip
ROM V7.1 UPDATE 14-9-2010
[ROM][14/09] WildPuzzleROM v7.1, WORKING, New base 1.28.1107.2, 3in1 reboot menu
v7.1
Fixed problem where users needed to reboot phone before they could make a call (modded framework removed and added as a package)
v7
New base, upgraded to 1.28.1107.2 from 1.25.405.1
Unlocks services.jar for possibility to install apps that otherwise needs certificates!
Added a 3-1 reboot menu then holding down powerbutton (reboot, reboot into bootloader, reboot into recovery). Thanx to snq-
Readded Dropbox
Added MyTouch Music app for streaming top-100 songs (would have needed a certificate to install)
Remade how apps2sd intregrated to rom. This time i have tested installing on 2 diffrent sd-cards. One with only fat32 and one with fat32+ext3.
Added a *huge* APN-list to framework from cyanogen! 1.28.1107.2 is otherwise locked to a handfull providers.
Included solid grey supercirklemod and transparent statusbar notification area.
Added screenstate_scaling - switch CPU frequency governor on screen state change
ROM 04/09 WildPuzzleROM v5, jbed, jit, ext4, apps2sd, system r/w "live wallpapers"
Features:
* Based on WWE_1.25.405.1
* Rooted (su +Superuser.apk 2.3.5 the apk can now be updated via MARKET added to /data/app)
* Several kernels to choise from with ext4 support, overclocked kernel is planned!
* Busybox
* Apps2SD (Darktremor 2.7.5 RC3 Script) (Requires Ext Partition. If you want to move dalvik-cache, make sure you flash the patch to do so)
* Activated data/app
* Deodexed system/framework and system/app to support theme, for example supercircle batterymod
* Nano text editor
* Bash shell support
* No bootsound
* Hosts file to block ads! in programs and games updated in /etc/hosts (this also speeds up phone as less memory is used and it can save money on internet traffic!!!)
* Moved Google Talk, Google Maps, and NEW Facebook 1.3.x to /data/app (saves some space)
* Adds Rom manager to /data/app (Choose BUZZ aka Wildfire as phone model when asked to download recovery)
* Wireless Tether
* Included extra apps: Estrong file and task manager, Spare Parts, Titatium Backup, Rom Manager, Alexander Blom gmail unreadcount widget and DropBOX
* And what i have forgotten
bản V5 rồi đấy update 4-9 :v5
1. Added Jbed
2. Added VoiceSearch
3. Removed apps2sd from this rom an added it as an own package! (The rom should now work regardless memoryconfig(sdcard))
4. Removed non standard apps but keept Rom manager and wireless theater
link:http://www.zshare.net/download/80068825ce37da9f/
v4
1. Removed old apps, redownloaded via wildfire this time and no rename of files, just moved them to /data/app
2. Updated su binary and superuser.apk to su-2.3.5-ef, working fine verifyed it with Titanium Backup.
3. Tested to download first random app that appear on market, worked just fine, and the second and third, all ended same way, working just fine.
link:http://www.megaupload.com/?d=1VXDKSRH
Hướng dẫn cài đặt:
Đầu tiên làm một sao lưu dữ liêu
wipe full "wipe data/factory reset"
Cài đặt zip từ thẻ sd
LINK V7.1:http://rom.tat.tw/wildfire/wildpuzzlerom/rom/v7/0001_WildPuzzleROM_v7.1.zip
Hướng dẫn cài đặt:WildPuzzleROM v8.0.1
Flat với Recovery Clockwork
Sao lưu trước khi up rom.
Wipe full
formated sdcard và không phân vùng ext copy rom WildPuzzleROM v8.0.1 Saukhi up xong chờ 7-10 phút
Dùng Rom Manager phân vùng thẻ nhớ live tren phone khởi động lai và thưởng thúc.
up kèm Radio_13.53.55.24H_3.35.19.25
http://rom.tat.tw/wildfire/wildpuzzlerom/radio/Radio_13.53.55.24H_3.35.19.25.zip
Tham khảo thêm tại đây để sử dụng các Mod:http://forum.xda-developers.com/showthread.php?t=761927
:(( cập nhật có gì mới vậy bạn... mình mới xài.. ko biết sao hết...
van de la trong wallpaper ko thay muc live wall, minh cung dang xai ss i5700 nen cung biet xai android chut chut. Sorry, post bai bang dt nen ko cco dau.
Xin chào bạn nhanthanhtruc bạn có thể hướng dẫn cho mọi người cách làm của bạn không ? Bạn có thể hướng dẫn cụ thể và upload những file cần dùng để mọi người tham khảo được không ? Mình đã vào trang web bạn đưa nhưng mình thật sự không hiểu nhiều lắm... xin cám ơn !
ducthang cho mình hỏi cái. Cài đặt Zip từ thẻ nhớ Sd là cài như thế nào ? Dùng phần mềm nào ?
Máy bạn đã hroot và cài recovery , bạn copy file rom có dạng đui .zip vào thẻ nhớ bạn đưa WILDFIRE về chế độ recovery tìm đến dòng update zip SD , trước khi cài đặt rom cook cần phân vùng thẻ nhớ .
máy bạn đã hack root rồi đúng không???bước tiếp theo bạn phải cài đặt recovery cho WF thì lúc đó mới up rom tứ SD card đc(cài đặt Zip từ thẻ nhớ Sd)bạn dùng chính cái thẻ 4G phân vùng EXT cho nó.
Cám ơn bạn Thoai_DakMil và ducthang. Phiền 2 bạn giúp mình 1 cái nữa nhé. Cài Recovery là tải từ Makert về phải không ? Nếu không thì mình phải làm thế nào ? Vậy là bây giờ mình không cần dùng đến các GoldCard nữa rồi phải không ? Phân vùng ẼT cho thẻ 4G là làm cách nào vậy bạn ? Làm việc này có tác dụng gì ?
Bạn có thể chỉ mình cách sao lưu dữ liệu không ? Mình không biết cách làm !
Xin cám ơn !
Xin cám ơn !
Bạn có thể lên Makert tìm và cài đặt Soft Rom Manager cái cài có thể dùng để phân vùng cho SD và có thể cho truy cập vào recovery , trước khi phân vùng SD nên copy hết data ra ngoài .
Sau khi mình up rom thì khi mình chọn Clear Store thì máy sẽ về tình trạng trước hay sau up rom ?
Việc uprom và up update lên bản 2.2 từ HTC có những gì khác nhau ?
Xin cám ơn !
Xin cám ơn !
trước khi up rom bạn nên Wipe full cho sạch sẽ nếu bạn up bản rom cùng CORE thì không cần wipefull làm gì
uprom và up update(cài lại hệ điều hành) không khác gì nhau đêu là cập nhật cho máy bản rom mới hơn tốt hơn khác up update lên bản 2.2 từ HTC thông qua OTA bản chính thức từ hãng HTC cập nhật cho máy ở đây là HTC WILDFIRE.
Đợi rom chính hãng thì rất lâu nên up rom cook là chính.
Mình đã up được rom mới nhưng không biết mọi người thấy sao chứ mình thấy bản này lúc khởi động chậm hơn so với phiên bản trược.
lúc đầu rom khởi động từ 5-10 phút lần sau khởi động nhanh thôi.
Có bản V5 rồi đấy update 4-9 :v5
1. Added Jbed
Bác nào có bản Rom ship 2.1 cho em xin với đề phòng bát trắc, em up lên 2.2 rồi nhưng hình như chữ không nét thì phải?
