CHUYÊN ĐỀ CẤP CỨU KHẨN CẤP CHO MỌI LOẠI MÁY DÒNG UIQ 3.0
Ở đây nhé: http://www.pdaviet.net/showthread.p...ết-cứu-UIQ3-bị-shock-flash-khi-update-bị-lỗi-!!!! . Lần sau nhớ tìm trước khi yêu cầu nhé.
Có tìm rồi nhưng link down không được, hôm nay tự nhiên down được
nhưng sau khi làm theo đúng hướng dẫn thì nó ra như vầy:
21:11:33| XS++ v3.1 (Darwin) Ready !
21:11:33| Executed on Microsoft Windows XP
21:12:01| Executing SEMC Smartphone Operations!
21:12:01| Please hold boot key ('@' or 'C') and connect device...
21:12:10| Master Port detected: COM5
21:12:10| Slave Port detected: COM6
21:12:10| Opening Port!
21:12:10| INIT MASTER...OK!
21:12:10| PHONE INFO SAMPLED...OK!
21:12:10| EPOC APPLET HEADER SENT...OK!
21:12:10| APPLET BODY SENT...OK!
21:12:10| SHUTTING DOWN MASTER...OK!
21:12:12| Baseband ID: 7100
21:12:12| Protocol Version: 3.1
21:12:13| Speed set to 460800
21:12:13|
21:12:13| Sending db2000_cid03_prodid_p3b.bin...
21:12:15| Applet ID: 070410 1354 NPACXC125871_DB2000_PRODUCTIONIDLOADER_P3B
21:12:15| This is a PRODUCTION_ID loader
21:12:15| Activating GDFS...
21:12:15| Cannot open GDFS
21:12:15| Warning: IMEI name does not match GDFS name (IMEI:p990 GDFS:n/a)
21:12:15| ...using IMEI name
21:12:15|
21:12:15| Profiling EPOC smartphone...
21:12:15| Platform: DB2001
21:12:15| OTP CID: 49
21:12:15| EROM CID: 298909995
21:12:15| EROM Color: Unknown
21:12:15| IMEI: 35959300xxxxxx
21:12:15| Phone ID: P990
21:12:15| Part Number: n/a
21:12:15| Phone smartphone version: R2D01
21:12:15| Phone software version:
21:12:15| Processing Unit:
21:12:15| Organizer:
21:12:15| CDA:
21:12:15| Ready for operation!
21:12:29|
21:12:29| Parsing package contents...
21:12:29| IGNORING: CCPU_Signaling_SW_R9GA001_prgCXC162037_R6E28_RED49.babe
21:12:44|
21:12:44| SMARTPHONE WILL BE FLASHED IN 1 PHASE!
21:12:44|
21:12:44| [---------- PHASE 2 ----------]
21:12:44| Sorry, your phone is NOT SUPPORTED
21:12:44| Flashing CCPU_Signaling_SW_R9GA001_prgCXC162037_R6E28_RED49.babe
21:12:44| Header type: BABE
Nhờ các bác khám
CongVoi
CongVoi bác cứu em với
máy em dùng p1i
em chép giao dien nghe nhac "WALKMAN BẢN 3.0 DÀNH RIÊNG CHO P1i"
dùng rất ok
sau đó chép thêm "Vista Full Icon for Only P1i _ Nhiều mod cải tiến Icon mới"
và rồi sau đó : không cần khởi động lại máy thì đã thấy các icon đổi
mà và tinnhan không được : báo lỗi
và em đã tắt máy và mở lại
kết quả là ko lên gì hết luôn
giờ em phải làm sao anh congvoi oi.
o dâu có thể chạy lại sw máy em
mail namhaicor@yahoo.com.vn
phone 0986393868 Hải
CongVoi
máy em dùng p1i
dùng rất ok
Bạn vào trang chủ của Sony Ericsson tải về bản PCSuite mới nhất rồi tiến hành update lại FW là dc. Phần mềm PCSuite hỗ trợ 100% tiếng Việt nên bạn cứ theo hướng dẫn của phần mềm mà tiến hành update lại FW thôi, mất khoảng 20-30' tùy theo tốc đọ của đường truyền internet mà bạn đang sử dụng. Chúc bạn may mắn. Bạn luôn nhớ câu này: Xài UIQ3 mà không update FW là kể như chưa xài :D:D
Sau khi cài supersound mod thì máy w960 khi gắn loa vào thì nghe nhạc bt( âm phát ra từ loa) nhưng khi chạy báo thức thì âm thanh bị chia ra làm đôi - từ máy và từ loa, cái nào cũng nghe nhỏ xíu. Có ai biết cách khắc phục làm âm chỉ phát ra từ loa mà to rõ như trước ko?
Gắn loa rời hay headphone? Khi nghe nhạc bằng headphone mọi âm báo sẽ chuyển qua headphone, không có cách nào chỉnh lại để phát ra loa ngoài khi sử dụng tai nghe. Với lại bạn cũng nên nói rõ là sử dụng bản mod sound nào Full hay Lite để mọi người cùng biết mà giúp đỡ.
Ý mình là cái loa gắn jack 3.5mm như loa máy tính đó và nghe nhạc thì bình thường nhưng mỗi khi đặt báo thức thì âm thanh bị chia ra: vừa trên loa ngoài của máy, vừa trên cái speaker cắm thêm vào, cái nào nghe cũng nhỏ xíu khó chịu lắm. Mình đang xài bản SuperSound(TM) - Mod Sound v4 kèm sound mod full v1.1
ai cứu hộ con p990i..
do nghịch quá sâu vào hệ thống nên mình chép fonts lỗi vào ổ C , h máy khởi động lại liên tục ko cách nào mở máy được , up lại firmware thì update sever không thấy mẫu P900 nữa , có ai có cách up offline chỉ mình với .. help :(:)(:)(:)((
Mình xài W950,Hôm qa cài mấy cái skin Starting và Shutdown... rồi sao sao , bị lỗi luôn , giờ mở máy lên nó sáng đèn , rồi ko lên hình nữa. Mình thì nghĩ chỉ còn cách là Update Service lại cho máy , nhưng bản US cũ thì khi mở nó báo lỗi "phiên bản" nên không được , còn bản mới trên web Sony thì Bước 2 "Chọn sản phẩm" lại không có W950... Mình cũng đã thử Emma để Update lại máy , nhưng lại không có Tài Khoản @@" Có bất công vs W950 thế ko ? Sony bh còn không có mục của W950 , Ai có cách nào giúp với nha , cần GẤP lắm
hic con G900 cua e bi do.gio cu nkhoi dong len roi chay lai.e da hasreset nhung k dc ai giup minh dc k.tks
cấp cứu, còn G900 của em bị liệt cảm ứng, giờ bấm nút call mà nút more trên màn hình ko được, đang cần các anh chị cho em cái soft để chuyển phím call và more trên màn hình thành các nút bấm để tiện sử dụng, soft nào mà install nhé, chứ kiểu copy pass thì chịu tại máy liệt cảm ứng mất rồi, huhu.
Em cảm ơn các anh chị nhiều
