Hoangcuong115
ANh em cho hỏi với! Em đang change CDA của P1i sang bản GW2 thì nó ko cho change. em copy phần Xs3.2++ như sau cho các bác xem và cho ý kiến chỉ đạo nhé:
XS++ v3.2 Dev1 (Crystal) Ready !
13:10:46| Executed on Microsoft Windows XP
13:12:16| Executing SEMC Smartphone Operations!
13:12:16| Please hold boot key ('@' or 'C') and connect device...
13:12:31| Master Port detected: COM6
13:12:31| Slave Port detected: COM7
13:12:31| Opening Port!
13:12:31| INIT MASTER...OK!
13:12:31| PHONE INFO SAMPLED...OK!
13:12:31| EPOC APPLET HEADER SENT...OK!
13:12:31| APPLET BODY SENT...OK!
13:12:31| SHUTTING DOWN MASTER...OK!
13:12:33| Baseband ID: 7100
13:12:33| Protocol Version: 3.1
13:12:33| NEW SECURITY PHONE DETECTED! SWITCHING...
13:12:34| Speed set to 460800
13:12:34|
13:12:34| Sending db2000_cid03_prodid_p3b.bin...
13:12:36| Applet ID: 070410 1354 NPACXC125871_DB2000_PRODUCTIONIDLOADER_P3B
13:12:36| This is a PRODUCTION_ID loader
13:12:36| Activating GDFS...
13:12:36| Warning: IMEI name does not match GDFS name (IMEI:NULL GDFS
1i)
13:12:36| ...using GDFS name
13:12:36|
13:12:36| Profiling EPOC smartphone...
13:12:36| Platform: DB2001
13:12:36| OTP CID: 49
13:12:36| EROM CID: 49
13:12:36| EROM Color: Brown
13:12:36| IMEI: 00460102xxxxxx
13:12:36| Phone ID: P1i
13:12:36| Part Number: FAD-3022015-BV
13:12:36| Phone smartphone version: R1D01
13:12:36| Phone software version: CXC162037 R9G006
13:12:36| Processing Unit: CXC162175 R2A03
13:12:36| Bluetooth:
13:12:36| Organizer: CXC162108 R6E21
13:12:36| CDA: CDA162022/1 R6E21
13:12:36|
13:12:36| ... and the phone lock code is: 1618033F (only 7 digits)
13:12:36|
13:12:36| Ready for operation!
13:13:53| A Brown Smartphone? Joking?
13:13:53| Error: Failed to send CSLoader!
13:13:53| FSX Shutdown!
13:13:55| Disconnected... Unplug the phone
Mà các bác xem cho em bản CDA của em đã là mới nhất chưa nhé: CDA: CDA162022/1 R6E21. Mà sao e up firmware nó cứ báo là phần mềm mới nhất rùi.
Chăgn hiểu thế nào nữa
Thanks các bác trước nhé
13:12:34|
13:12:36|
13:12:36|
13:12:36|
