Hướng dẫn Update Firmware Nokia S60v3, S60v5 bằng Phoenix 2010
nó báo lỗi : "error :Failed to set phone to flashmode"
Có bảng đỏ : Product flashing failed với nội dung - " The flashing failed. Do you like to retry the flashing?
HRESULT 0x84210027 (-2078212057)
Firmware: Firmware updating failed. Error 0x8401F148 - Flash: Internal connection error. Check USB connection to phone and/or application's installation."
giúp tôi
nó chạy được thế này đây :Flashing started
Creating product data items list
Product data items list created
Backup not required
Flashing phone
Initializing
Asic CMT: Verifying communication to device...
Getting product info...
Scanning image files...
AdlServer: Flashing Update Server Data: 214912 bytes
AdlServer: Flashing CMT UPS data 1%
AdlServer: Flashing CMT UPS data 11%
AdlServer: Flashing CMT UPS data 21%
AdlServer: Flashing CMT UPS data 30%
AdlServer: Flashing CMT UPS data 40%
AdlServer: Flashing CMT UPS data 50%
AdlServer: Flashing CMT UPS data 61%
AdlServer: Flashing CMT UPS data 71%
AdlServer: Flashing CMT UPS data 80%
AdlServer: Flashing CMT UPS data 90%
AdlServer: Flashing CMT UPS data 100%
AdlServer: UPS data loaded
AdlServer: Update Server code succesfully sent to phone
AdlServer: Flashing Update Server Data: 1504256 bytes
AdlServer: Flashing APE UPS data 0%
AdlServer: Flashing APE UPS data 10%
AdlServer: Flashing APE UPS data 20%
AdlServer: Flashing APE UPS data 30%
AdlServer: Flashing APE UPS data 40%
AdlServer: Flashing APE UPS data 50%
AdlServer: Flashing APE UPS data 60%
AdlServer: Flashing APE UPS data 70%
AdlServer: Flashing APE UPS data 80%
AdlServer: Flashing APE UPS data 90%
AdlServer: Flashing APE UPS data 100%
No Update Server Running. Phone is in an unknown state. Unable to flash.
ERROR: Failed to set phone to flashmode
All operations completed
Product flashing failed.
XOng báo lỗi như trên ..........
Có ai ở nha trang - khanh hòa có thể làm được không? giúp tôi với, tôi không làm được.... lần đầu làm mà nản thế này chứ...
Bó tay rồi, thua, ngồi cả ngày ở mạng rồi, anh em ai có thể giúp đươc vấn đề này gửi email cho tôi với , tôi sắp thi rồi, không lên ngồi như thế này được nữa...: chuasonlam113@gmail.com Thank, cho tôi hỏi 1 chút, n95_1 hỗ trợ thể nhớ ngoài đến mấy G? Có người bảo 2 có người bảo 8... bó tay, thông tin mù mịt...
Bạn ghost bản win đang dùng, cài lại một bản win mới cài lại xem thế nào. Chịu khó đi bạn ơi, ChuyenGia mà!
giúp tôi
tình trạng này thường xảy ra khi máy bác đã hackphone vĩnh viễn , vì thế Phoenix không thể chuyển phone sang chế độ flash được ....
Tớ là tớ cứ NSU mà làm,dễ làm,chứ mình thấy mấy cái vụ up kiểu này kiểu j` í. Chọn code,đổi code rôi` lằng nhằng. Lại sợ chọn nhầm code nữa chứ. NSU N0.1
Phoenix mới là số 1 , NSU gắn cáp cứng ngắt vậy mà đang chạy FW giữa chừng nó báo không thể kết nối ,còn Phoenix thì chạy liên tục , chừng nào kết thúc 100% thì thôi ....
Đúng là Phoenix là số 1. Hôm qua em mới vọc cái nay. Và cũng reup fw máy em. May quá anh Habaolinh chỉ bảo chọn đường dẫn fw mới đc.Chọn đường dẫn y hệt trên 4rum chả đc j` cả.
Có bác nào trả lời dùm em câu này: Em xài E71 xám, bấm *#0000# thì nó báo là RM-346, nhưng cắm vô rồi chạy Phoenix thì nó báo RM-407...và em ko thể up được vì nó ko kiếm được RM-407 thì phải (em down RM-346)...có ai giải thích và chỉ em hướng giải quyết được không zậy hix...
Lịch sử em nó như sau: Hàng xách tay, mới đầu em ko biết RM gì, vì lúc đó ko chú ý lắm, đổi code vietnam 0560655 và up bằng JAF, từ 100 lên 210 rồi lên 300, giờ muốn lên 410 thì ra như thế này...chẳng lẽ phải down RM-407 sao ta...ai giải thích giúp em nhá, trong thời gian chờ đợi em down RM-407 zậy...hix...
Hix...em search bang Navifirm thi RM-407 không thấy Vietnam...có anh em nào hướng dẫn em với không, ghét chắc xài 300 quá hix...
Em làm được rồi, xin trình bày lại như sau: down Nokia Ovi Suite về, nó sẽ cài hết driver cho con E71, sau đó bật Phoenix lên thì nó nhận RM-346 như trước. Cái này em cũng ko hiểu, nhưng nói chung là do thiếu driver, anh em nào mở lên mà ko thấy RM-xxx của mình thì coi chừng giống em, (con của em mở đít ra coi thì là RM-407, nhưng em đổi code).Vài lời...
Minh up len firmware moi nhung chay cham.bay gio minh down firmware phien ban cu bang phan mem nay dc k? (post bang n73 nen bac mod thong cam :D )
Được, cứ vô tư đi, ưu điểm của pm là đây!
Bạn ơi fille .EXE là file gì thế? " - Sau khi load FW về các bạn chạy file setup bình thường (đối với FW dạng .exe thì các bạn không phải tạo đường dẫn "C:\Program Files\Common Files\Nokia\DataPackage\Products")" là thế nào?
Mình thử cài rồi nhưng đang cập nhật thì nó báo là bị ngắt kết nối với PC Suite là thế nào? nếu mình tháo cáp ra liệu máy có bị làm sao không thế? giúp mình với
Thanks các bác nhiều!!!!!!!!
mình ko cài được cái này là sao vậy?????
mở ra nó cứ báo lỗi như hình ấy
