IPHONE PC SUITE - TỔNG HỢP CÁC PHIÊN BẢN
Anh em nào bị lổi thì đêm nay update lên bản 2.5.5.101 xem sao
Các lổi thường xuất phát từ các lý do sau:
+ Do cài Update lên Itunes 9.x
+ Do máy là FW trên 3.0
Bác đao phai này về giải nén ra rồi cop đè vào program files là được :)
Mã:
http://www.mediafire.com/?nxdqtwidznd
Update phiên bản mới iPhone PC Suite V2.5.5.101
Update Log:Sep. 15, 2009
[FONT=arial, helvetica, sans-serif]New Functions:[/FONT]
1.Support iTunes 9
2. Added support for .deb apps in Apps management
3. Added important data auto-backup function
4. Added eMagazines multiple tasks download and download management functions in Books management
5. Added “cancel current theme” function in Themes management
6. Added installed apps list backup and restoration functions in Backup & Recovery
7. Added search function in List view of Calendar management, supporting search by title, address or remarks
8. Support drag-and-drop to automatically create “new event” in Week and Day view of Calendar
9. Support double-clicking to create “new event” in Month view of Calendar
10. Added left and right arrow button in Month, Week and Day view of Calendar, allowing users to switch time backward and forward by clicking them
11. Added grouping by day function with event type shown in List view of Calendar
Function Improvements:
1. Improved the Month, Week, Day and List view, interface and operation in Calendar
2. Improved the date ActiveX of event editing in Calendar, supporting selecting date and modifying time
3. In Day and Week view of Calendar, applied new background color in event area when the label is scrolled close to current time automatically
4. In Record Manager, added support for filtering voice memo whose duration is 0 when you are importing voice memos
5. In SMS management, added contacts sorting, and search type display in the search box
6. In Books management, added sorting by file name
7. Adopted “Hour” as the unit of auto-update time of subscribed RSS news
8. In SMS chat, search and filter functions are supported whilst you are adding contacts
9. Automatically check and fix the SMS grouping problems occurred when you are sending or managing SMS
10. Added “SMS” button in SMS chat, allowing you to access SMS management function quickly
11. In Books management, auto-split won’t be done by default any more when you are adding new books
12. Other improvements
[FONT=arial, helvetica, sans-serif]Bug Fixes:
1. Fixed the problem that the program may crash when you are adding book name and the name you enter is too long
2. Fixed the problem that the display of voice memo duration may be inaccurate
3. Fixed the problem that books may not be imported from iPhone successfully when you are conducting “One-key Transfer”
4. Fixed the problem that picture editing and deleting may not be successfully conducted in full-screen preview mode of Pictures management
5. Fixed the problem that some pictures may keep rotating in full-screen preview mode of Pictures management
6. Fixed the problem that the sender and receiver may be reversed in dialogue box mode of SMS exporting
7. Fixed the problem that the window that reminds you to close the program may still pop up when you turn off the phone
8. Other bug fixes
[/FONT]
Mình thấy bbạn mình đã update lên pb 2.6.... rùi, cài dc file .deb lun nhưng sao PC suite của mình thấy update lên pb 2.6 này đc...ai có thông tin mới ko???? chia xẽ với:-/
Iphone PC Suite > Thuyền cưứ sinh cho 3GS Bị ăn táo do cài app từ Cydia
Său 1tuần nhìn táo chín mình đã hái dược táo(5Trái 32G) (Lưư Ý : Máy còn kết nối với Itunes và PC Suite) PC Suite Phải là PC Suite 2.5.5.101
Các bạn làm các bước său: (với điều kiện iphone còn kết nối vói PC Suite)
1-Bật PC Suite Lên chọn :
A-Tap System
-Chọn tiếp Reintall PhoneDaemon (cứ Yes hết)
-chọn Fix Startup (bước nằy nó hỏi Remove mobilesubstrate – cứ Yes)
-Chọn Icon Restoration (Yes)
-Chọn Software Package (Yes tất )
-Chọn One-key Transfer (Yes tất)
B-Chờ máy Restar-Hưởng Thành quả (Hái táo chin 99,99% Thành công)
Chú Ý : Nếu làm cách này o được thì bạn làm như său:
Chặy RedSn0w-Jailbreak Lại iphone . và làm lại cac bướ trên OK 100% (Có mọt cây mình phải làm theo cách này)
Minh sử dụng Firmware 3.0 nhung khi cắm vào máy tính thì PC Suite noi vẫn chưa cắm IP là sao hả các bác? Mình muốn thay đổi nhạc chuông và cài theme đều ko được? Ai biết chỉ dùm minh với hichic. Tks
PC Suite for iPhone update to V2.6.0.105
DOWNLOAD
Tính năng mới:
1. Cài và quản lý các ứng dụng .deb
2. Quản lý Cydia Source
3. Đồng bộ danh bạ, SMS, Call log từ các máy S60 sang iPhone
4. Chức năng quản lý Themes và Wallpaper mới. Cho phép xem Themes trực tiếp trên iPhone chỉ với 1 cái Click qua PC Suite.
....và nhiều cải tiến khác đang chờ bạn khám quá trong phiên bản mới này.
