Nand Android cho Touch HD
allstreet
IMPORTANT NOTES
try this at your own risk. thanks to MietasSR for the mod nbh and thanks to herrickwong and MietasSR for the mod recovery and boot.img and now kernels. people helping people guys, that is what is all about.
CHANGE LOG:
FIRST RELEASE
problem with nbh, recovery.img
2011.07.10
TIADROID NAND. delayed. waiting on nbh file. the rest of the files are ready. to all testers ready my PM
2011.07.16
-tiadroid-update.zip with boot.img and kernel inside the zip, so no need to flash the kernel update. only one file to flash.
-ADD IT THE NBH AND RECOVERY HERE ON THE FIRST POST. WHAT THAT HELL, LET GET MOVING WITH THIS STUFF
2011.07.17
things that is working now
-nbh
-recovery.img
-boot.img=problem with this
-working the the kernel-update.zip
2011.07.19
- herrickwong, files are here on the first post. he have a working kernel and recovery.img
-we are now booting into android but needs more work. the phone keep freezing at the boot animation and some users at the home screen. we are making progress.
2011.07.27
-testing new kernel by herrickwong
-we are booting into android
-Backlight can't wake up by touch screen, buttom ok.
-GSM or 3G not work.
-Halt on starting wifi.
FOR GUIDE ON HOW TO SET NAND, FOLLOW THIS THREAD
(special) GUIDE TO GET NAND WORKING (BLACKSTONE)
QUICK GUIDE ON HOW TO GET NAND INSTALL ON BLACKSTONE
1=setup
-need to have this working first ADB AND FASTBOOT,
-boot any sdcard build. download pdanet for android and install it (follow the guide)
-in android test if your adb is working (follow the guide)
-I like to keep everything organise, create 3 empty folder on your c: drive
1-ADB
2-RUU
3-TASK29
-download the adb files from the guide and add the recovery.img from here
-download your ruu for blackstone from the guide
-download task29 for blackstone, add the nbh file from here and add it to this folder.
2=flashing
-boot into bootloader. make sure usb driver works.
-do a task29 to erase wm, when the phone will boot to the htc screen. pull battery.
-flash the nbh file from here. the phone will boot, wait for the blue screen, then you will see fastboot enable.
-flash the recovery.img
-to enter into recovery type this command
fastboot boot recovery.img
3= install updates
-install tiadroid.zip first
-install kernel.zip second
4=reboot
that's all. let us know how far you get
notes:
downloads
update-TIADROID NAND-2011.07.19 Multiupload.com - upload your files to multiple file hosting sites!
new kernel .
update-TIADROID NAND Multiupload.com - upload your files to multiple file hosting sites!
KERNELS DOWNLOADS by herrickwong
update_Kernel_Blac_20110731.zip (4.58 MB) http://www.multiupload.com/LQ4V13E0A2
fix battery and lcd blacklight
update_Kernel_Blac_20110727.zip Multiupload.com - upload your files to multiple file hosting sites!
update_Kernel_Blac_20110719 Multiupload.com - upload your files to multiple file hosting sites!
Read more: http://tiad8.com/test-builds/164-te...-rom-tiadroid-2011-07-19-a.html#ixzz1TgulBBqg
hura..đợi mãi..đc xé tem lun ...:D..nhưng mà ko hiểu gì :(..ko biết cài sao vậy chủ thớt..
toàn tiếng Anh cao siêu không à, hic. Anh nào dịch dùm mớ chữ đó giúp với
Bạn nào dũng cảm làm chuột bạch rồi post bài hướng dẫn bằng Tiếng Việt cho anh em tham khảo và thực hiện nhé...
mình đang down về, chưa cài dc. Khi nào hoàn thành sẽ post hướng dẫn cho bà con, ae nào ham hố thì thử lun. Hì hì
:)):)) adv mod gì mà nhát quá
Hiện tại nhìu mem bên tiad8.com đang úp, đợi bên đó report thêm tí:D
Nhiều người đang gặp khó khăn vơi nand này,các bước thực hiện chưa được suông sẻ...
Nếu chạy được Nand Android trên HD thì vẫn còn nhiều việc phải làm lắm vì thấy còn nhiều chức năng chưa hoạt động...
update:
GUIDE INSTALL ROM NAND on BLACKSTONE BY SHADOW!
The first thing to do is install the libraries android can download them from installer_r11-windows.exe and install
Method alternative:
1) download the libreries r11.zip installer_r11-windows.zip and extrated it in C:\
2) entry C:\android-sdk-windows and run sdk manager.exe and Download all libreries
2.1) If you get error then do it
2.2) Close sdkmanager.exe and run again
Installation and files for it:
1) Download a rom
a) FROYO BLUE NAND by tiad for blackstone: eta: TBA
2) Download RUU and extract to C:\ (RUU.zip here to download)
for more info on this ruu [TOOL] Advanced ROM Update Utility for TOUCH HD / BLACKSTONE by Barin (asusmobile.ru) - xda-developers
3) Download ADB and extract to C:\ (for download here adb.zip)
4) Download some kernel list is here (I use the kernel-20110613_222536-update.zip)
Setting up your PC to ADB (Android Debug Bridge)
For window XP
1) Give right-click My Computer (on desktop)
2) Give properties
3) Then the Advanced tab
4) Then give the Environment Variables button
5) Then look where it says System Variables and find the line that says PATCH and give you double click to modify
6) Place this:
Variable Name: Path (leave SAME)
Variable Value: SOMETHING;C:\adb (that SOMETHING changes depending on the computer, you should just drop ";C:\adb" at the end of what you have there)
Example: to me I look like this: % SystemRoot% \ system32;% SystemRoot%% SystemRoot% \ Sy stem32 \ Wbem; C: \ Program Files \ Panda Security \ Panda Antivirus Pro 2012;C:\adb
Testing if we're running ADB
Now try "ADB" works for us or not:
1) Use any android (xdandroid or CWM) I use xdandroid froyo because CWM had deleted ...
Download it "PdaNet" from here install it and follow the instructions .. the program tells you to connect your phone and install driver .. I chose HTC and next next .. bla bla bla .. end disconnect the phone
NOTE: If you tell them adb.exe already running then go to task manager (ctrl + alt + delete), then the Processes tab and look for a process called adb.exe and end
2) Now from your android go to "Settings" then "aplications" and then "development" .. check that the option "Debugging USB" and "Allow mock locations" are marked
3) Now connect your phone to the USB again and we will give your computer click on Start, then Run and type in CMD to enter command prompt
4) Now write this adb devices and then give the enter key
5) If you get something like 000000000 device then congratulations you could run ADB
Removing Window mobile and entering "mode FastBoot"
Ok until it is safe here now for the next step must be installed "Hard-SPL" or will damage your phone. REPEAT VERY IMPORTANT
IF YOU DONT HAVE "HARD-SPL" INSTALLED ON YOUR CELL NO FOLLOW TUTORIAL MAKING ... (If you have already flashed a rom then it is already installed)
FOR INSTALL HARDSPL LOOK THIS [TUT][HSPL] Hard-SPL Unlocker for Blackstone
1) Format the SD fat32 ...
2) We put the rom there to use and the kernel (update.zip, root.zip (Optional) kernel.zip)
3) Now we flash and delete "window mobile", entered the "bootloader" (Phone off and press the volume down and turn on (red button) at the same time)
4) When you see tri-color screen then connect the phone to the usb (should say "USB" in the center of the screen and not SERIAL) expected to be installed the drivers
5) Disconnect the phone from the usb, remove the battery and then put back so we will enter FastBoot
6) FastBoot: Connect the phone in usb, enter the folder (RUU) and run "BlackstoneAdvanceRUU.exe." If you see a blue screen then went into "mode fastboot"
7) Ok if all you have done as I say we're probably about to end
Adb commands and installing android
1) Click on Start then Run and then type CMD to enter command prompt
2) Now let's run these commands ... should write in the console as follows:
2.1) cd C:\adb and press the enter key .. (with this we enter the folder adb)
2.2) fastboot flash recovery recovery.img (this command will install the recovery) and press the enter key
2.3) fastboot boot recovery.img (with the command entered the recovery) and press the enter key
3) At this point the phone must be in the recovery menu now select "update from SDcard aply" (To select using "End Call button (red button)" and to raise or lower the volume keys
4) Now install the rom, kernel and root should be in that order
**** update.zip
**** kernel.zip
**** Root.zip (optional, this is to enter administrator mode as there are applications that ask us to be root)
5) The phone will restart then disconnect the phone
6) WELCOME TO ANDROID NAND
Read more: http://tiad8.com/test-builds/164-te...om-froyo-x-ginger-ready-43.html#ixzz1QupK1OFz
:ar! mình đã làm dc tới bước cuối cùng như k úp dc rom android, lý do là file ruu_signed.nbh bị lỗi, nên k dùng phím end call để enter nạp rom dc. đang chờ bản fix
Phương pháp cho đến giờ vẫn còn ở giai đoạn test để phát triển,pp này còn phụ thuộc vào PC nhiều quá,mà mỗi PC mỗi khác nhau,người dùng cũng khác nhau.
vì vậy bạn nào có chút am hiểu PC mới nên vọc,hiệu quả thành công trên XP sạch khả quan hơn.
cám ơn allstreet đã cố gắng theo sát và giới thiệu với AE,tuy nhiên cố gắng dịch ra VNM thì tốt hơn nhé ;;)
:D tks mod góp ý, do vẫn chưa hoàn chỉnh nên mình k dịch hết ra tiếng việt, đỡ mất công ae làm theo rồi lại k dc. Tạm thời vẫn để như vậy, sau khi hoàn chỉnh sẽ post đầy đủ có ảnh minh họa. :D
Nghe tin có ban rom android cho blackstone mà sốt wa,mình cung dang mày mỏ jup các a e nhưng khó wa,van chua thành công,đây có bản tiếng việt a e xem rui gop suc cùng làm nhé.
http://tiad8.com/vi/test-builds/210-hƯỚng-dẪn-cÀi-tp-rom-nand-trên-2-a.html
http://tiad8.com/test-builds/207-special-guide-get-nand-working-blackstone.html
Sau vụ này mà thành công ngon nghe a e phai offline 1 buoi liên hoan ăn mừng mới đc. Ủng hộ HD1 chay rom android. a e cố lên......
Hiện nay cũng có bản andoid 2.2.2 và android 2.3.1 cho HD1 rui đó,cung ngon và mượt lắm.nhất là chay wallpaper hiệu ứng nước,chim,bể cá cực phê nhưng vẫn chi la bản trên SDcard mới đau chứ.a e gắng nghiên cứu bản rom đi,có rất nhiều thứ để khám phá đó.kekeke
Ai giỏi vụ cài đặt thì làm cho ae thưởng thức với. Có rom mà chưa biết làm gì chán quá.
Rất hào hứng khoản này, tiến hành xem sao :). ace cùng thử đi, mình thấy sướng nhất là khi test rom, chứ lúc hoàn chỉnh rồi thì...
