NexusHD2-KitKat 4.4.2-CM11.0 V4.2 Tytung
ranmoi
Đã có NexusHD2-KitKat 4.4.2-CM11.0 V4.2 cho anh em! Nhưng hiện tại rất khó dowload do bị đứt Cab quang. Anh em nào xui xẻo đã kéo về được thì chia sẽ cho anh em. (Mình chưa kéo được)
link đây nhé các bác: http://nexushd2android.tytung.com/nexushd2-kitkat-cm11-0
Changelog
V4.2 (Jan. 1, 2014)
Updated CM-11.0 source code.
Included LowSoundFixer_v1.0.8.apk for fixing the low sound issue for legacy devices. (Credit: tytung)
Decrease date's font size in the lockscreen so that date won't be cut. (Keyguard.apk) (Credit: tytung)
Fixed H/W video encoding (smooth video recording via GPU with 640x480 15 fps MPEG4) for CM-11.0 (Credit: tytung)
Fixed native WiFi Tethering for CM-11.0 (frameworks_base and netd) (Credit: tytung) (not fixed yet)
V4.1 (Dec. 21, 2013)
Updated Android ROM to KitKat 4.4.2 (KOT49H)
Updated initrd.gz to KitKat 4.4.2 (CM 11.0) version (Credit: tytung)
Updated Google apps to KitKat 4.4.2 version (Credit: Google)
Fixed WiFi legacy bcm4329/wext driver (wpa_supplicant v2.1 and init.htcleo.rc) (Credits: jianC, npz and tytung)
Added WiFi Ad-Hoc Network support for CM-11.0 (wpa_supplicant v2.1 adhoc and Settings.apk) (Credit: tytung)
Fixed MediaProvider crash by setting the valid UUID (Credits: drewis and tytung)
Added modified HWUI framework patch for CM-11.0 to support HWUI deny app HwaSettings.apk (Credits: tytung and royale1223)
Fixed black screen/box in the browser, email, gmail, etc. by forcing to activate HWUI framework patch (Credit: tytung)
Included LowSoundFixer_v1.0.7.apk for fixing the low sound issue for legacy devices. (Credit: tytung)
Fixed legacy EGL issue for HD2 for CM-11.0 by merging cm-10.2 source code (Credit: tytung)
Fixed Screenshot (Credit: tytung)
Fixed recent apps not displaying preview (Credit: tytung)
Fixed H/W video decoding (native 720p video playback) for CM-11.0 (Based on Legacy QCOM OMX Mods) (Credits: tytung and Ganster41)
Fixed native USB Tethering for CM-11.0 (frameworks_base) (Credit: tytung)
Fixed the glitchy preview of Camera by adding JB 4.1.2 version (Gallery2.apk and libjni_legacymosaic.so) (Credit: tytung)
Updated to Gmail 4.7.1
Updated to Google Calendar 201308023
Updated to Google Keyboard 2.0.19133
Updated to Google Maps 7.5.0
Updated to Google Play Store 4.5.10
Updated to Google Play services 4.0.34
Updated to Google Search 3.1.24.941
Updated to YouTube 5.3.28
Updated to the latest hosts file (December-06-2013) for blocking ads.
Decreased the required system space to 270 MB (Full installation).
V4.0 (Dec. 8, 2013)
Upgraded to Android KitKat 4.4.1 (KOT49E)
Upgraded to CM-11.0 source code
Updated Google apps to KitKat 4.4 version (Credits: Google)
Updated initrd.gz to CM 11.0 version (Credit: tytung)
Fixed legacy display for HD2 (Credits: tytung, Evervolv, CM, etc.)
Fixed phone call for HD2 (Credits: tytung and Evervolv)
Fixed mobile data (3G/HSDPA) for HD2 (Credits: tytung and Evervolv)
Fixed VPN for HD2's legacy 2.6.32 kernel (Credits: tytung and marco.palumbi)
Added a default wallpaper from Nexus 5
Removed or replaced some CM apps and libs which are not suitable for HD2
Camcorder, USB/WiFi Tethering, WiFi, and 720p Video Playback are broken or NOT natively supported after upgrading to CM11.0
Đang dùng được 2 ngày rồi, nói chung là ổn, nhưng có vẻ hơi chậm, kéo chuyển qua lại các trang ko được mượt cho lắm, để dùng 1 tuần thử xem sao.
Nhưng nếu có phân vùng swap thì cải thiện đáng kể.
Mình đang up lên mediafire cho anh em đây, tầm 1 giờ nữa sẽ có.
Hiện tại chưa thấy gì hơn 4.3V3.3, chỉ thấy giao diện thay đổi, theme cũng khác. Một vài tính năng bị bỏ đi, setting cũng ko tùy chỉnh được nhiều như 4.3 (chắc cho nhẹ máy), chạy app lâu lâu hay bị stop.
Khi nãy em vừa kéo về . đang cài, mà sao lúc boot vào nó cứ ở cái màn hình của CM . sao thế nhỉ
ko ai bình luận nữa ta . nghe nói bản này tiết kiệm pin hơn nhiều . ai cài được và test cho anh e, ý kiến
bản này còn nhiều lỗi như là lỗi low sounf fixer stop thường xuyên khi gọi điện thoại. Pin thì vẫn vậy, ko thấy tiết kiệm như quảng cáo.
mỗi lần thay pin mới khỏi động rất lâu phải 2 phút mới vào được.
Hi,
Sau một thời gian cài rom (từ 2.3 -> 4.22, MIUI, ...) chắc mình quay lại 2.3 GB xài cho nó nhanh. Mấy version sau này lúc mới cài thì chạy mướt lắm nhưng cài thêm ứng dụng vào là ì ạch ngay. Mình không cài gì nhiều cả, chỉ
  1. exDialer
  2. contacts+
  3. dialer+
  4. message+
  5. call recorder
  6. sms backup
Textra sms nhẹ, nhanh nhưng bị mất sms. Hix
Nên quay lại với CM 2.3 hay MIUI 2.3?
Mọi người góp ý giúp nhé. Thanks all.
Hi,
  1. exDialer
  2. contacts+
  3. dialer+
  4. message+
  5. call recorder
  6. sms backup
Nếu thích vọc phá thì nên cài CM, còn lười có sao dùng vậy thì Miui thẳng tiến
Riêng em thì khoái CM hơn. 2.3.7 là phiên bản android ổn định nhất trên HD2
seting vẫn như bình thường mà có thấy gì khác đâu
bác cứ cài 1 máy 4.3, 1 máy 4.4 sẽ thấy khác, mình nêu 1 ví dụ nhỏ thôi như là background giữa màn hình lock và màn hình sử dụng 4.3 có thể làm 2 cái khác nhau. trong khi 4.4 ko làm được, còn nhiều cái khác nữa.
Mình nghĩ chắc bác cũng chưa hiểu hết tất cả setting của máy đâu nhỉ. Hãy tự tìm hiểu và khám phá nhé.
Vâng . cõ lẽ là nhứ thế / nhưng sau khi cài thì em thấy . tuy còn nhiều lúc bị stop nhưng mà có vẽ nó chạy nhanh hơn 4.3 /
Bây giờ links 2.3.7 trên xda đều die hết rồi.
Cho mình xin links bản rom 2.3.7 nào ổn định nhất nhé. Cám ơn nhiều.
Lúc trước mình hay xài 2.3.7 của
  1. tyween
  2. Xylograph
  3. pongster
  4. dorimanx
  5. tweakos
  6. sundawg
  7. tytung
Sau 1 tuần sử dụng 4.4.2 mình đã quay về 4.3
Cho đến lúc này thì 4.3 dù sao vẫn ổn định hơn.
Tiếp tục đợi 4.4.x xem có sự thay đổi nào mới hơn ko rồi up tiếp.
